Weight: 7 lbs
Dimensions: 11.2 x 6.7 x 4.0
DC Connections: DC Lugs no expensive ring terminal required
AC Connections: Vertical push in connections only no GFCI
AC Knockouts: Removable by hand
Remote Control Panel: Full control same as on board control
Remote Control Location: Up to 50 wired connection
Display Data: DC Volts In, AC Volts Out, AC Power Out, Error Codes
Display Indicators: Low Bat Warning, Fault, Shore, Power
Display Sleep Mode: After 30 seconds, Display turns off, Power indicator remains on
RV C Compatable: Yes
- Reverse battery protection
- Thermally controlled fan speed
- Unit can be monitored by remote control
- Auto Restart after power interrupt
- Easy AC hardwire hookup
- Remote included
- Conforms to UL STD 458, Certified to CSA STD C22.2 No. 107.1
- DC lug connection
- Unit weight: 7 lbs
- Unit dimensions: 11.2 x 6.7 x 4.0
- 1,000 watt continuous power
- 2,000 watt peak power
- Pure Sine Wave.
View this ad at Airstream Classifieds -
Progressive Dynamics 1000W Pure Sine Wave Inverter 1610J - T...
