Old 06-18-2021, 04:38 PM   #1
Airlock's Avatar
2019 16' Sport
Vista , California
Nearly new Yamaha EF2000i Sv2 inverter generator - California
About 1 hour run time on engine. Just had a soft start installed on my Airstream AC so I no longer need two generators. Runs perfect.
The Yamaha 2000 Watt EF2000iSv2 incorporates a completely new controller with advanced programming, allowing the EF2000iSv2 the ability to power a much wider range of applications. It weighs in at 44.1 pounds, making it easily portable. Among the quietest portable generators in its class, the EF2000iSv2 features Smart Throttle technology which allows greater fuel efficiency and noise reduction.
  • Prevents stale gas problems and gummed up carburetors.
  • Allows quick fuel level inspection without turning off the unit and removing the fuel cap.
  • Varies engine speed based on load, improving fuel economy as well as reducing noise and engine wear.
  • Prevents generator damage, in case of overload.
  • Prevents engine damage caused by low oil, avoiding costly repairs and minimizing down time, adding customer confidence and peace of mind.
  • Hook up two EF2000iSv2 generators for up to 30 amps of maximum power requires accessory
View this ad at Airstream Classifieds - Nearly new Yamaha EF2000i Sv2 inverter generator - Californi...
Airlock is offline   Reply With Quote
Yamaha Inverter Generator EF2400iS Zia Airstream Classifieds 0 01-20-2018 06:12 PM
Run time for tri fuel honda eu2000i or yamaha ef2000i jackvosney Electrical - Systems, Generators, Batteries & Solar 6 08-11-2016 06:24 PM
Parallel non inverter generator with inverter generator? mtbguy Generators & Solar Power 3 07-15-2015 01:48 PM
Yamaha 3500 watt inverter generator NEW Michael06 Airstream Classifieds 0 03-27-2014 08:17 PM
Question on Yamaha EF2400iSHC - 2000 Watt Inverter Generator. Ditter Generators & Solar Power 22 02-19-2013 06:31 PM
