RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 02-23-2020, 06:40 AM   #1
Electronic Controls OEM
Micro-Air's Avatar
Allentown , New Jersey
Micro-Air EasyStart 364 Soft Starter
Title: Add New - Airstream Trailer Classifieds - Airstream Trailers For Sale
I just posted a new ad on Airstream Classifieds.
It's 2020, and to celebrate EasyStart's UL Compliance achievement, Micro-Air is bringing back the $40 COUPON exclusively for our Airstream Customers only!
Retail price is $299. Enter “AIRSTREAM” Coupon Code at checkout for $40 off!
EasyStart is a one-of-a-kind, custom-developed soft starter for single-phase motors. It can support both 115V and 230VAC motors. (A specialized model now exists for 115V-only RV applications, at a reduced cost!) EasyStart employs a 4-part start ramp sequence that is self-optimizing, resulting in the lowest possible start-up current. EasyStart can deliver up to 75% start current reduction as compared to a compressor’s LRA (locked-rotor amperage). It also has numerous specialized fault checks not found in any other soft starter to provide further protection for your compressor.
EasyStart is the perfect solution that allows an air conditioner or refrigeration compressor to operate on a generator, inverter, or limited utility power when it would otherwise not have functioned. It can also be applied to air compressor and fluid pump motors.
The EasyStart 364 is capable of supporting up to a 36000 BTU (3 ton) compressor. It includes a fully-weatherproof (IP65), flameproof, plastic enclosure with an integrated mounting flange and wire harness. Specialized models exist for various applications.
*** MONEY-BACK GUARANTEE ***
EasyStart will allow to start and run your Dometic Penguin II (commonly used on Airstreams) on a Honda EU2000i generator. Of course, we expect you will be willing to work with us to help you troubleshoot it if it does not initially work for some reason. If after that, it still does not work and/or you still want to return it, we will refund you the purchase price.
You can contact us by filling in the form on the right hand column of the ad listing:
http://www.airstreamclassifieds.com/...oft-starter-2/
Micro-Air is offline   Reply With Quote
Old 02-23-2020, 08:10 AM   #2
2013 30' Flying Cloud
Kingwood , Texas
Great product and easy to install. I purchased two on Jan 20, 2020 and got the $25 per unit AIRSTREAM discount. Still worth the price to make the AC/Heat Pump startup easier, quieter, and allow one of my units to run on my Westinghouse 2,500 Inverter/Generator.
DoubleR is offline   Reply With Quote
Old 09-14-2020, 09:42 PM   #3
2019 27' Globetrotter
But is it worth installing if your camping is at state parks or RV parks with shore power? I understand if your are on BLM / Boondocking with an inverter generator. And why does it void the Dometic warranty unless installed at the mothership? What if your local AS 5-RIVET dealership does the install?
Lhenry83 is offline   Reply With Quote
Old 09-15-2020, 07:04 AM   #4
2019 25' Flying Cloud
Houston , Texas
If you have two A/C's and camp at Texas state parks with 3- amp service, it is well worth it in my opinion. You can run both A/C's if you install this on both. You do have to be careful with other electrical loads. You can search here for the warranty discussions and consider Micro-Air's warranty. I do not see why it matters who installs it on that discussion. Your dealer is an Airstream dealer and the A/C is a Dometic product. The issue remains the same
DCPAS is online now   Reply With Quote
Old 09-15-2020, 07:45 AM   #5
turk123's Avatar
2019 30' Classic
Canfield , Ohio
I think you meant to say 30 amp service!
x\x/x\x/x\x/x\x/x\101970\x/x\x/x\x/x\x/x\x/x\/x\x/x\x/x
2017 Airstream International Signature 27FB Twin
2019 Airstream Classic 30 Twin
turk123 is offline   Reply With Quote
Old 09-16-2020, 07:36 AM   #6
Houston , Texas
I also have specially treated magnets you attach to your fuel line. 49mpg* while towing! And its your all yours for the modest price of $249! Cash only.
*Tests conducted in 9% grade downhill with tailwind. Real world!
Old 09-16-2020, 07:48 AM   #7
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Do you reverse the magnetic polarity if its on a diesel?
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is online now   Reply With Quote
Old 09-18-2020, 06:55 PM   #8
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
After all of our custom wiring for power was done in the summer of 2014 to our 2014 Airstream 31’ Classic built in January 2014, the stock Dometic thermostat with two air conditioners could not consistently make both units run at the same time. We tried all kinds of resetting and initialization tricks to no avail. Nothing worked for more than a few cycles. We lived with this issue until August 2020 when we installed the new MicroAir thermostat. We can now operate both air conditioners or heat pumps at the same time with no issues.
A bonus is that the new thermostat displays the (sometimes erroneous) outside temperature information coming from the Dometic logic boards mounted in our air conditioner. The factory model did not. I learned that Dometic and Coleman put in these sensors primarily because they don’t want our heat pumps trying to do impossible work after freezing at 0 degrees Celsius and 32 degrees Fahrenheit. At the least it gives a relative idea of outside air temps to determine whether to use heat pumps or furnace. The furnace also sends hot air under the floor to heat the three water storage tanks so if the temperatures are close to freezing, we use the furnace.
At the same time as the thermostat was installed, we installed EasyStart 364s on both Dometic air conditioners. The ramp up of the compressors is so smooth and quiet that we needed to check air flow to see if cooling is actually happening. I see that story repeating itself on the forums and on Facebook.
2014 31' Classic model 30 twin beds, 50 amp service, 900 watt solar system, Centramatics, Tuson TPMS, disc brakes, 16" tires & wheels
Micro-Air EasyStart Installation RMD Electrical - Systems, Generators, Batteries & Solar 0 07-18-2019 04:12 PM
Micro-Air EasyStart 364 Soft Starter Micro-Air Airstream Classifieds 3 08-10-2018 07:03 AM
Additional info for anyone installing Micro-Air EasyStart Driftin Di Electrical - Systems, Generators, Batteries & Solar 7 04-29-2018 11:27 AM
Micro-Air EasyStart 16 Sport Peanut Electrical - Systems, Generators, Batteries & Solar 1 11-26-2017 08:51 PM
