Old 10-05-2022, 05:33 PM   #1
2016 28' International
Alabaster , Alabama
Marinco 50 Amp Easy Lock Shore Power Inlet - Alabama
Marinco 50 Amp Easy Lock Shore Power Inlet Like new off of our 28' Serenity
Marinco stainless steel power inlets are solid cast marine grade 316 stainless steel. Featuring a robust construction and corrosion resistant materials, Marinco's Power Inlets are built for a long life in harsh marine environments. This model includes a heavy duty cap strap for strength and durability.
Features:
  • Easy Lock Marinco's Easy Lock system is designed to make hook up quick and easy. With the Easy Lock locking ring installed, connect the cordset to the inlet and turn the locking ring less than a quarter turn. The tabs on the locking ring lock into the inlet for a positive watertight hook up, while eliminating any chance for cross threading. Easy Lock inlets have a threaded boss that will accept threaded cordsets as well.
  • Each cover on Marinco power inlets is designed to stay hinged open when the cover is lifted up.
  • Blades are nickel plated brass for maximum corrosion resistance.
  • Interior hardware is marine grade stainless steel.
Sells new for 165.00, will sell for 75.00 shipping
View this ad at Airstream Classifieds - Marinco 50 Amp Easy Lock Shore Power Inlet - Alabama
gmattingly is offline   Reply With Quote
SOLD: Marinco 30 Amp 125 Volt SS Power Inlet - California israelj Airstream Classifieds 0 03-11-2021 10:40 PM
Used Marinco 30 amp inlet and Marinco Cable/Phone Inlet montanablue Airstream Classifieds 0 11-16-2018 04:09 PM
Marinco 125v 30 amp power inlet - Stainless RMB Exterior Restoration Forum 1 12-31-2013 03:20 PM
Marinco power inlet RoadHungry Electrical - Systems, Generators, Batteries & Solar 2 07-13-2011 04:16 PM
What is advantage of Marinco type power inlet? SilverHoot Electrical - Systems, Generators, Batteries & Solar 5 07-15-2009 01:58 PM
