Old 11-03-2024, 04:56 PM   #1
2024 25' Trade Wind
Bothell , Washington
CAMPAIR High Flow Spot Diffuser Air Vents - Arizona
Qty 6 sold as set. Used for one month. Works as described. Decided I did not like the look. Some minor scratches due to normal use.
SUPERIOR AIRFLOW: CAMPAIR Air Vents are engineered to double the airflow in your Airstream travel trailer, reducing restrictions and enhancing overall comfort for a more enjoyable experience.
PREMIUM STAINLESS STEEL CONSTRUCTION: Made from high quality stainless steel, CAMPAIR Air Vents perfectly complement the modern and sleek finish of your Airstream's interior, adding both style and durability.
ADJUSTABLE AIR DIRECTION amp; CONTROL: The innovative pivoting nozzle head allows you to direct airflow in any direction, while the integrated air baffle lets you precisely control the amount of air or shut it off entirely.
ADJUSTABLE AIR DIRECTION amp; CONTROL: The included trim ring makes installation quick and simple, covering old mounting holes for a clean, professional look without the need for modifications.
DESIGNED FOR AIRSTREAM S QUIETSTREAM HVAC: Specifically crafted for Airstream models with the "Quietstream" HVAC ducting system, CAMPAIR Air Vents provide an ideal upgrade to improve airflow and interior comfort.
View this ad at Airstream Classifieds - CAMPAIR High Flow Spot Diffuser Air Vents - Arizona
charlesk is offline   Reply With Quote
Air conditioning vents screens not the ducted vents. We are trying to locate them and cegardner General Interior Topics 3 04-25-2021 08:06 PM
50% off - SPOT Satellite Messenger and SPOT Trace Adventure.AS Electronics & Connectivity 0 04-23-2019 12:12 PM
Replacement Light Diffuser theterrells General Interior Topics 10 09-03-2012 10:37 PM
Bathroom light diffuser sarasafari General Interior Topics 2 09-07-2011 09:06 AM
Burner/diffuser ring Magic Chef oven from 1971 Safari edirwin Stoves, Ovens & Microwaves 0 03-02-2010 02:46 PM
