Title: Add New - Airstream Trailer Classifieds - Airstream Trailers For Sale
I just posted a new ad on Airstream Classifieds.
Tongue weight (TW) - 1400lbs, G.T.V.W. - 14,000lbs. The only Air Receiver specifically engineered to be used with weight distribution. Sold steel 2” shank, Nuts and Bolts, Four steel Tie-Rods rated at 16,200lbs each ensuring a 64,800lbs shock and shear rating. **Eight hole adjustable mount plate allowing for multiple height adjustments accepts weight distribution brackets, ball mounts, and pintle mounts.** No bearings to crush or wear out, instead military tough Nylon, which is self-lubricating. See this hitch @
www.AirSafeHitch.com. Includes a bladder (info).
You can contact us by filling in the form on the right hand column of the ad listing:
http://www.airstreamclassifieds.com/...ution-bracket/
