Title: 2007 Airstream International CCD 19’ - Ohio
We just listed our 2007 Airstream International CCD for Sale on Airstream Classifieds.
Year: 2007 Make: Airstream Model: International CCD Length: 19'
Airstream is in excellent condition.
Trailer has been completely inspected and serviced at Jackson Center in January 2013. Also had entire roof, windows and door resealed.
CHASSIS: 4500 Lb. GVWR • 4300 Lb. Axle System • 3715# UBW • Styled Aluminum Wheels • Radial Black Wall Tires, Load Range D 15″ • 12″ Electric Drum Brakes • Electric Hitch Jack • 4 Stabilizer Jacks • Steel Step.
EXTERIOR: Bright Aluminum Finish – White Finish on Roof • Polished Rear Bumper w/Storage • Bambi Medallion • License Plate Bracket • Grab Handle • LPG Bottle Cover • Enclosed/Insulated Underbelly • Patio Awning Curb Side 9’8″ • Insulated & Heated Tanks • Wrap Protectors • Solar Stone Guards.
WINDOWS & DOORS: Opaque Window in Door • Keyed Deadbolt at Entry Door • 18″ Stack Windows • Refrigerator vent Doors (2) • S.P. Solar Gray Front Panoramic Windows.
INTERIOR DECOR: Pull Roller Shade • Full Close-Out Drapes at Panoramic Windows • Wood/Steel Drawer Boxes • Overhead w/Sliders • Aluminum Interior Skin • Entrance Mat • Laminated Counter-tops • Interior Grab Handle • Magazine Racks (2) • Vinyl Flooring Throughout.
BATH DECOR: Towel Bar • Roll-Away Shower Door • Hinged Bath Door • Fiberglass Shower w/Soap Dish • Mirrored Medicine Cabinet • Robe Hook • Stainless Steel Round Sink.
BEDROOM DECOR: Corner Double Bed 48″ x 75″ w/Storage under Bed, Road Side Wardrobe & TV Shelf • Removable Storage under Bed • Quilted Bedspread • Folding Privacy Door.
GALLEY DECOR: Laminated Galley Top • Spice Rack • Sink Cover (1) • Stainless Steel Single Bowl Sink • Aluminum Inserts on Refrigerator • Fixed Dinette 40″ x 74″ • Overheads with Slider Doors.
ENTERTAINMENT & SOUND: Front Overhead w/Radio • Radio Antenna • 4 Speakers Wired & Mounted • Sony AM/FM CD Receiver w/CD Controller: 35W x 4 High Power Output, 12 FM/6 AM Presets, Auto Memory & Quartz Clock • TV Ready Includes Antenna & Outlet • Cable TV & Telephone Hook-Up • Satellite Prewired.
ELECTRICAL: Two Batteries • 7-Way Trailer Cord With Junction Box • 110V/12V Power Center With 55 Amp Converter •
12 Volt ATC Fuses • Incandescent Lighting • TV Jack w/12 Volt Outlet (1) • 1 Telephone Jack • 120 Volt Exterior Outlet • GFI Protection for Kitchen • Exterior Lighting Package Includes: Dump Valve, Compartment Lights • Water Pump Switch • Electronic Battery Disconnect • Solar Pre-Wire • Dinette Reading Lights • Door Light.
APPLIANCES: 11,000 A/C w/Heat Strip • 16,000 BTU Furnace w/Electronic Ignition • 3-Burner Cooktop •Convection Microwave Range Hood w/Vent & Light • Ceiling Vents (Non-Powered) • Bath Exhaust Fan (12 Volt) • 4.0 Cu. Ft. 2-Way Refrigerator • Probeless Tank Monitoring System (Wall Mounted) • 6 Gallon Water Heater w/Electronic Ignition • Fire Extinguisher • LPG, Smoke & Carbon Monoxide Detectors • Fantastic Fan with Rain Sensor.
SYSTEMS: 30 Lb. Steel LPG Bottles w/o Gauges (2) • Automatic 2-Stage Regulator • Water Heater By-Pass Kit • Water Fill • Water Pressure Regulator • Toilet • 23 Gallon Fresh Water Tank w/Drain Valve • 18 Gallon Black Water Tank • 21 Gallon Grey Water Tank • Exterior Height w/AC – 9′ 5″ • Interior Height – 6′ 4.5″ • Exterior width – 8′ • Interior Width – 7′ 7″ • Exterior Length -19′ 2″ • Hitch Ball Height -17 1/4″ • 460# Hitch Weight • Safety Chain Hook 11,700# Rating • Heated Tanks – Forced Air • Sewer Hose Storage Tube • No Fuss Flush Black Tank Rinsing System.
Added Factory Options
600 W Inverter
Window Awning Package
Trailer comes with Reese WDH.
You can contact us by filling in the form on the right hand column of the ad listing:
http://www.airstreamclassifieds.com/...l-ccd-19-ohio/
