Old 06-19-2019, 09:07 AM   #1
1974 29' Ambassador
Somerville , MA
1970's KT Lock for Airstream
Title: Add New - Airstream Trailer Classifieds - Airstream Trailers For Sale
I just posted a new ad on Airstream Classifieds.
Hi folks. I have a rare KT lock for sale from my 1974 Ambassador. It has the key and strike plate. It is missing the inside handle and locking pin, but these are easily available at VTS (https://www.vintagetrailersupply.com...kset-s/229.htm). There is also some damage to the finish on the outside handle that should be repairable with some sanding and refinishing. When pulling on the handle, the locking shaft does not retract all the way. I believe this is because the lever spring is missing. I have this part, however could not figure out how to replace it so I ended up changing the lock. I understand the roll pins on the vertical handle shaft and the shaft itself need to be removed in order to replace this spring. As you’ll know if you’ve been looking for one of these locks, they retail for $830 (https://inlandrv.com/product/part-22008/). I’m selling this one for $300 so you can get a bargain and I can fund my A/S renovation.
You can contact us by filling in the form on the right hand column of the ad listing:
http://www.airstreamclassifieds.com/...for-airstream/
thatfeybabe is offline   Reply With Quote
Old 02-09-2020, 12:48 PM   #2
1970 31' Sovereign
American Fork , Utah
Do you have pictures of the exterior of the lockset?
MrArmageddon is offline   Reply With Quote
Old 02-09-2020, 12:50 PM   #3
1970 31' Sovereign
Do you have pictures of the lockset exterior?
1970 Airstream Overlander :: 1970 Airstream Overlander Argosy4 Airstream Registry Discussions 0 08-19-2016 12:34 PM
Updated keyless entry lock BAUER LOCK sc17842 Doors & Locks 6 03-22-2016 09:53 PM
Caravanner :: 1970 Airstream Fishbowl Airstream Registry Discussions 0 12-29-2012 12:45 PM
Door Lock Loose interior Lock Pin.. Bootsinister Doors & Locks 12 10-08-2012 10:19 AM
