Old 10-02-2023, 11:49 AM   #1
2011 16' Sport
2022 20' Bambi
woodinville , Washington
12V LiFePO4 460AH Battery Bank, 200A BMS, Heating, Bluetooth GONE - Washington
This is self build 460AH Battery bank with low temp protection and heating function. Doesn't include Victron stunt or cable in some pictures. Our space for battery is limited, and the commercial LiFePO4 battery bank is usually bulky and lack of features such as heating at low temperature, We built this 460AH battery bank with less than the space for 200AH battery
Battery: 8 EVE LF230 230Ah 3.2V LiFePO4 Battery; EV quality Grade A cell from Chinese Factory;
BMS: JBD 4S 12V 200A BMS Lifepo4 Battery Smart Balance Protection Board With Bluetooth, Heating Function with balancer
It has configurable low temperature protection and heating feature. Peace of mind charging in cold environment. While charging voltage applied below low temperature threshold, the heating pad will be heated, once desired battery temperature is reached, the battery then start to charge.
The battery bank was built on April 2022, verified with full 460AH in battery test. We did the capacity test on Sep 21st 2023 again, scored 472AH with BMS, 450AH with Victron smart stunt with 10.56v cutoff, so the true capacity should be still around 460AH.
I spent a lot of time to build this battery bank for our Airstream, and it performs flawlessly. Due to to high electric demand of usage, we decided to build the exact battery bank again but with bigger capacity, and let this one to go.
Feel free to stop by and take a look of build quality of this battery bank, it has high capacity but really small footprint.
We are in Seattle area and prefer local pickup, not sure how to ship this since it's more than 80Lbs.
BMS Spec:
JBD BMS SP04S034
This BMS has a continuous current of 200A, heating function H , Bluetooth, 2 NTCs
Package BMS Bluetooth Balance Wires NTC
For 3.7V Li ion/ 3.2V LiFePo4 batteries
Continuous Current 100 200 A / Balance Current 50 150 mA
Size 192 2 105 0.5 20 1 mm
"H" Heating Function,
3 Temperature Sensors Detect battery temperature
Support Bluetooth, Phone Xiaoxiang BMS APP
Battery Spec:
Typical capacity: 230Ah at 0.5C discharge Discharge current 0.5C with 2.5V cut off. 25 2
Typical Voltage: 3.2V Discharge current 0.5C with 2.5V cut off. 25 2
AC Impedance Resistance: 0.30m
Standard charge and discharge: Charge/Discharge Current 1C/1C
Pulse Charge/Discharge Ccurrent 30s : 2C/2C The maximum charge current of the battery does not exceed 1C under 0 45 .
Charging Temperature: 0 60 Reference Continuous/Pulse Charge/Discharge Current Map
Storage Temperature: 20 45 Battery can work at specified temperature range with capacity loss in tolerance.
Typical dimension Width 173.93 0.5mm Height 207.3 0.5mm Thickness 53.85 0.4mm Thickness 300 20kgf 40 SOC
Weight: 4.11 0.22kg
View this ad at Airstream Classifieds - 12V LiFePO4 460AH Battery Bank, 200A BMS, Heating, Bluetooth...
miamipanther is offline   Reply With Quote
Old 10-03-2023, 11:59 AM   #2
2011 16' Sport
2022 20' Bambi
Battery capacity test file attached.
File Type: xls Battery Capacity Test_20230921-0000_to_20230921-2359.xls (231.0 KB, 11 views)
Old 10-24-2023, 11:41 AM   #3
2011 16' Sport
2022 20' Bambi
My new set of battery arrived and I started to build the new battery bank. Reduced the price for this bank
Old 10-24-2023, 02:50 PM   #4
Boise , ID
Man, thatís cool. If I wasnít already down a rabbit hole Iíd probably head this direction.
Bunker is offline   Reply With Quote
Old 10-24-2023, 10:50 PM   #5
2011 16' Sport
2022 20' Bambi
Due to the limit space under the bed, that's only way I can pack the highest quality and capacity of LIfeop4 battery
Old 11-01-2023, 05:48 PM   #6
2011 16' Sport
2022 20' Bambi
It's GONE
12v
Shunt vs Lithium w/BMS & Bluetooth Dr. Ohat Electrical - Systems, Generators, Batteries & Solar 11 09-26-2022 03:29 PM
Solar for 27' Globetrotter 12V or 24 battery bank TCY Airstream Lifestyle 0 06-14-2021 07:11 PM
Use of PI 30A bms in 50A plug kmrice Batteries, Univolts, Converters & Inverters 1 03-15-2021 02:47 PM
wiring Housepower BMS momentary switch northfielder Airstream Motorhome Forums 0 01-14-2017 10:53 AM
