Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Special Editions and Limited Releases > Eddie Bauer - All Models
Old 10-05-2018, 09:52 PM   #21
1960 28' Ambassador
Libertyville , Illinois
BTW thank you very much eganwh!
Short563 is offline   Reply With Quote
Old 10-06-2018, 08:10 AM   #22
eganwh's Avatar
2016 27' Eddie Bauer
Billings , Montana
Install complete. Hatch action is smooth and I do not observe any flexing of the brackets when closing. On to the next fix/upgrade.
ID:	324558   Click image for larger version
ID:	324560   Click image for larger version
eganwh is offline   Reply With Quote
Old 10-23-2018, 05:15 PM   #23
Senior Member
sheriff1's Avatar
2012 27' FB Eddie Bauer
Sparks , Nevada
Originally Posted by eganwh View Post
mefly2,
Greetings from Billings, MT. We are hoping to make to your side of the state next summer for a week in GNP and maybe a trip through the Bitterroot Valley.
Threaded ball studs are due in today. Thanks Amazon Prime! So, I should be able to make it out to the shop this evening and complete the install.
What size threaded ball stud did you use? 10mm?
Thanks!
sheriff1 is offline   Reply With Quote
Old 10-23-2018, 09:58 PM   #24
eganwh's Avatar
Billings , Montana
Thanks!
Yep. 10mm.
Old 11-01-2018, 03:50 PM   #25
mefly2's Avatar
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town , *** Big Sky Country ***Western Montana
Thanks for the info ... we will have to make mods to ours to stop the excessive flexing...just want to see a TB in person, first.
Old 11-01-2018, 03:52 PM   #26
mefly2's Avatar
We have a spot for you - just south of Missoula.
Old 11-06-2018, 08:26 AM   #27
StagrLee's Avatar
2012 25' FB Eddie Bauer
the overhung bracket acts as a lever and puts expansive force on the attachment points (rivets). This is likely why all the rivets were slightly loose (stretched) on the upper brackets. She recommends redesigning the bracket – widening the base and re-orienting the ball stud direction which should put the bracket in compression and eliminate the lever effect..
Okay - when I read this last month it went over my head. The ball mount now points to the outside and not the inside of the hatch putting the upward force squarely into the center of the new bracket. Genius! Should be fixed forever with the extra metal in the bracket and ball stud.
Question for you, can you go with the shorter 1/2 long shank ball studs or do you need the 3/4" shanks. I see some extra threads coming out of the securing nut.
"Stagr" Lee
2012-1/2 25' Eddie Bauer
StagrLee is offline   Reply With Quote
Old 11-07-2018, 06:33 AM   #28
eganwh's Avatar
Billings , Montana
Absolutely. Go shorter if using the same thickness bracket material. I wanted 5/8-inch length ball studs, but these were out of stock when I ordered, so I went a size (3/4-inch) up. At some point I will grind off the extra threads.
Old 11-12-2018, 07:18 PM   #29
mefly2's Avatar
Eganwh-
That is an unusual looking bear paw under the MT flag in your avatar ???
Old 11-12-2018, 09:07 PM   #30
eganwh's Avatar
Billings , Montana
Well, I certainly got a good chuckle out of that. Should be a decent game Saturday as they look evenly matched this season. Best of luck.
A state divided. Unfortunately, I live in a "maroon" county.
Go Cats!
ID:	327679   Click image for larger version
Old 08-11-2021, 07:53 AM   #31
2015 27' FB Eddie Bauer
Spring Branch , Texas
I own a 2015 Eddie Bauer and the rear hatch brackets on the door have bent on both sides. Very similar to some of the other pictures on this thread. I am hoping that that someone that has fixed this in their Airstream can assist with some guidance. I have ordered some new brackets, but need help understanding how to best get the old rivets out of the bent bracket. I don't want to drill them out and find out later that I really screwed them up. Any help would be greatly appreciated. Thanks in advance.
dickdawson is offline   Reply With Quote
Old 09-15-2021, 10:28 AM   #32
JayleNBob's Avatar
Box Elder , South Dakota
I, too, own a 2015 EB and have replaced all four brackets since purchasing in 2016. I acquired the new brackets from Jackson Center while having the rear and street side awings added. I drilled out the original rivets and opted to replace them with stainless panhead screws on the hatch, and stainless steel bolts/nuts on the jamb. You might want to contact the factory and request the updated hatch strut brackets as they did make a change in them following the 2015 MY.
JayleNBob is offline   Reply With Quote
Old 09-29-2021, 03:00 PM   #33
Thanks so much for the information. Hopefully, I can get the factory to send me the updated brackets. I bought some off of Amazon and they are now starting to bend too.
New axles and shock Brackets theOrca Axles 25 03-18-2015 10:10 PM
Bolt on Shock Brackets? Silverflames Axles 13 11-21-2012 09:11 PM
Lower Shock Brackets 1963tradewin Shocks 1 07-29-2011 07:05 PM
Mounting Brackets for Folding Table?? Navigator Cabinets, Counter Tops & Furnishings 38 04-25-2008 10:50 PM
