Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Registry Discussions
Old'57
Old57 Old57 is offline
Airstream Registry
Airstream Name Old'57
Year 1957
Make Airstream
Model Overlander
Length 26
1957 Airstream Overlander
Exterior
1957 Airstream Overlander Exterior 1957 Airstream Overlander Exterior 1957 Airstream Overlander Exterior
There is definitely some rust (She has been sitting for 10 years) and there are a few places where the aluminum has been torn.. Overall in ok condition considering her age.
Interior
1957 Airstream Overlander Interior 1957 Airstream Overlander Interior 1957 Airstream Overlander Interior
Most of the interior works, except the fridge. Electrical is all running. Propane works too.
Old 09-19-2020, 03:30 PM   #2
57Vintage's Avatar
1958 26' Overlander
Battle Ground , Washington
Images: 22
To you know what the serial number is? It should be on a plate by the door. The endcaps don't look correct for a 1957. Also, the 'bath tub' isn't correct for a 57, maybe a 58, unless it was special ordered.
Harold & Rebecca
Our thread:
https://www.airforums.com/forums/f97...er-172124.html
57Vintage is offline   Reply With Quote
Old 11-15-2020, 11:21 AM   #3
66Overlander's Avatar
1962 22' Safari
2016 30' Classic
Southeast , Michigan
Images: 41
This is an Ohio built Airstream and Ohio switched from 13-panel to 7-panel endcaps approximately July 1, 1957, but did not switch to the 1958 model year until mid-September 1957. However, I see the rear window is a Hehr Clearview, not a Hehr Standard, which suggests this is likely a 1958, as Airstream switched from Hehr Standard to Clearview windows on the front and back (only) on most of the larger models for the 1958 model year (approximately). The serial number would clear this up for sure as the window change may not have occurred exactly at model year change.
Joe
WBCCI/VAC #702 & #6768
66Overlander is offline   Reply With Quote
Old 11-15-2020, 11:31 AM   #4
1960 22' Safari
in the wilderness , The great Mojave Desert
I like it!
What are your plans? and more pictures would be a treat.
I'd rather be boon docking in the desert.
WBCCI 3344 FCU
AIR# 13896
CA 4
Yes, we have courtesy parking for you. About an hour North of Los Angeles.
Goin camping is offline   Reply With Quote
