New stone guard
New stabilizers
Rebuilt all double pane windows
Replaced all screens
Replaced all exterior lights with LEDs
New power jack hitch
New outside shower
Replaced fresh water access point
Added new rub rails & rub rail blue plastic
Et cetera
Interior
Completely new inner aluminum skin
Completely new electrical, AC + DC
All lights changed to LED, with all overhead lights on dimmer switches
Custom dinette with custom-made Sunbrella fabric cushions
Added Atwood dual water heater
Added water tank monitor and Shurflo pump / components
Converted to custom-built composting toilet, with black tank cleaned and repurposed into extra gray tank
Created a custom-built fiberglass shower with seat (over the driver’s side wheel well)
Installed new DC-power fridge (so closed off fridge exterior venting)
Switched to induction hot plate for cooking in prep for solar / boondocking
Used Baltic Birch as primary wood for walls, with pine facings. Oak in a few places where structural strength required.
Et cetera
Customization
See above.
Switched this twins/ rear bath to a bathroom near the middle of Airstream. Bedroom moved to back with a short Queen instead of twins
One of the biggest 2023 challenges was building the new custom fiberglass shower pan and seat.
Systems and Running Gear
3 Fantastic Fans
Coleman Mach A/C
[will add to this later with power panel, etc.]
Other Information
Cleaned/ rust guarded every piece of metal we could access (including underside, water and waste tank frames, etc.)
