Old 02-02-2020, 06:38 AM   #21
Overkill Specialist
GMFL's Avatar
2020 30í Globetrotter
2014 23' International
Dadeville , Alabama
Originally Posted by Rocinante View Post
Would love to see a picture of your SureCall antenna mount, when you get a chance.
Here’s how I mounted mine. I sandwiched the factory mount between two opposing faced 1.5” angle aluminum pieces 3” long. Stuck it to the roof with VHB and bedded it in Sika 221.
ID:	360396   Click image for larger version
ID:	360398   Click image for larger version
Old 02-02-2020, 09:40 AM   #22
Wolfwhistle
Fair_Enough's Avatar
Margaritaville , Banana Republic
I have the Weboost with a directional single YAGI antenna, bolted to the arm. I fished coax into the overhead cupboard where the DVD player is or was, which is quite close, but not an easy job, for sure. Then added a 12v automotive plug to power the 4G booster. Recently upgraded to the 8800L hotspot and find most of the time, I get better speeds by itself or with a simple Netgear X2 (MIMO) antenna in a window, works well. Remember to test speeds and not depend exclusively on strength of signal. But, when on fringes of coverage, the booster makes a big difference. Also, I used the simple "hershey bar" antenna and place the hotspot directly to it to eliminate oscillation and to get maximum boost. Note the pic of the booster, was before the 8800L and other work.
WW
ID:	360405   Click image for larger version
Name:	coax at crankup antenna.jpg
Name:	pulling coax3.jpg
Is taking it all with you, really getting away from it all?
Fair_Enough is offline   Reply With Quote
Weboost install chaeha Electronics & Connectivity 221 09-12-2018 07:13 AM
Weboost external antenna The Colonel Computers, Internet & Satellite 15 11-02-2016 09:50 AM
Pepwave MAX BR1 / MobileMark / weBoost install Ohiobrits Computers, Internet & Satellite 17 09-27-2016 07:26 AM
Verizon Jetpack external antenna vs. Weboost? DarrellT Computers, Internet & Satellite 13 09-07-2016 06:08 PM
Update: WeBoost Drive 4G-X BoldAdventure Computers, Internet & Satellite 8 10-22-2015 02:30 PM
