Go Back   Airstream Forums > Airstream Community Forums > Full-Timing, Winter Living & Workamping > Working on the Road
Old 09-18-2020, 07:10 AM   #1
s1000pre's Avatar
2021 30' Flying Cloud
2020 25' International
minneapolis , Minnesota
Weboost drive X RV install in newer airstreams
I have a 2020 Int and had no interest in drilling holes in my new roof To install a booster. The other issue is attempting to route the wires through the walls. Here was my solution. Use the existing pre wired Satellite connection found behind the stereo in the upper locker. Then plug the exterior antenna into the exterior outlet. I included a link to a package of adapters you will need. Purchase 2 small c-clamps from Home Depot to attach your antenna. I attach mine to the awning in either the open or closed position. Also, be sure to protect the connection between your antenna & 20’ coax. Use heat shrink tube and liquid electrical tape to seal the top seam.
I set my iPhone close to the interior antenna. Then hotspot my laptop or Apple TV to my phone. Works great!!!
Adapters: https://www.amazon.com/dp/B0814BQHJN...t_b_asin_title
ID:	378902   Click image for larger version
ID:	378904   Click image for larger version
s1000pre is offline   Reply With Quote
Old 02-06-2021, 06:44 AM   #2
2019 28' Flying Cloud
Ashby , Massachusetts
This is exactly what was looking for! We have a 2019 28' Flying Cloud and I wasn't about to drill any holes into her. I was hoping I could use the existing satellite connections for the wiring. I was thinking of some sort of hitch mount for the antenna pole but attaching to the awning looks like a simple and easy on/off approach.
We're traveling from VT to TX in late February for a few months staying mainly at state parks along the way and and this setup should fit the bill.
I see your original post was in September 2020. How's your experience been to date with WeBoost? Any modifications/suggestions from your original install setup?
Thanks!
my3sons_nh is offline   Reply With Quote
Old 02-06-2021, 08:25 PM   #3
twbucksr's Avatar
2015 22' FB Sport
2018 27' Flying Cloud
2021 30RB Classic
Fredericksburg , Texas
What do you do when it is too windy to deploy your awning?
twbucksr is offline   Reply With Quote
Weboost 4G-X Drive RV Antenna Install Placement LvngTheStrm Electronics & Connectivity 32 04-13-2020 12:58 PM
27FB- WeBoost Drive 4G X roof install experiment J-Dog 2009-2015 Flying Cloud 27 09-12-2019 02:36 AM
How I installed my weBoost Drive 4G-X OTR on International 27FB tot2learn Electronics & Connectivity 18 07-10-2017 02:53 PM
Update: WeBoost Drive 4G-X BoldAdventure Computers, Internet & Satellite 8 10-22-2015 02:30 PM
