01-14-2020, 05:27 PM
2012 25' FB Flying Cloud
popka
Leveling
Newbie here. When leveling is it necessary to put leveling blocks under the forward and rear wheel or will raising one to level suffice
01-14-2020, 05:29 PM
1986 31' Sovereign
Miami
I do both. Probably no scientific reason for it it just seems reasonable to spread the weight over both axles rather than one.
Sorta new (usually dirty) Nissan Titan XD (hardly paid for)
Middle-aged Safari SE
Young, lovely bride
Dismissive cat
01-14-2020, 05:31 PM
2007 22' International CCD
Corona
I agree that its better to spread the load evenly. Better for tires and axles.
01-14-2020, 07:37 PM
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach
We have also always done both tires.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
01-14-2020, 07:46 PM
2018 27' Flying Cloud
Easton
, PA
I assume doing for both wheels would probably result in less wobble, even with the stabilizers down -- more contact points with the ground.
VeloBuckeye
2018 Flying Cloud 27FB - "The Shoe"
01-14-2020, 07:47 PM
Registered User
2016 25' Flying Cloud
Fairfield
If you only do one tire the trailer will rock more. Got in the trailer once when changing a flat, was not a goid idea.
01-15-2020, 05:47 AM
2017 25' International
Niagara-on-the-Lake
, ON Canada
For help with levelling, especially left/right, I would recommend a LevelMatePRO. This device connects to your phone via BlueTooth so you can easily see which side and by how much the trailer is out of level. It makes levelling, when by yourself, much easier and accurate.
Another device that eases levelling is a pair of Andersen Levellers. Two will work with a tandem axle Airstream and allow you to precisely level as the curved ramp allows for infinite adjustment (up to 4") and work great in conjunction with the a/n LevelMate.
Ray B.
01-15-2020, 06:26 AM
2018 30' Classic
Williamsburg
, VA
I used both of these and recommend them.
2018 Classic 30
2012 F250 6.7l
US Army Watercraft Engineering Officer
01-15-2020, 07:04 AM
Around
, Town
It depends.
If the site is relatively flat with just minor slope, both wheels. Doing just one will not have full effect.
If there is significant slope from the front to rear where side to side is relatively flat or minor side to side slope, I will add more (usually one) to the downhill tires than what the uphill tires have.
01-15-2020, 07:29 AM
1984 31' Airstream310
Ajo
We use one of these, works great!
01-15-2020, 07:43 AM
2002 25' Safari
Dewey
We will often fine tune the level with a different number of legos on each wheel, but never more then one different. The stabilizers take care of any wobble.
Richard
01-15-2020, 08:12 AM
Ajo
For long term storage in dirt/gravel, Michelin suggested I build these pads using 3/4 ply then inflate tires to max pressure. I drilled holes in them to be able to move them around with my awning fork
Tampa
I recently added the "Level Mate Pro".
Rather than drill screws into the bulkhead, I mounted it with VHB tape. I put it right inside the door so I could switch it on as needed.
It doesn't need to be mounted perfectly level because you tell it, "This is what I call level."
It does a good job, but it's not exactly what I expected.
You set the parameters and the distances between wheels and wheels to hitch. The bluetooth connectivity is very good, even though mine is near the floor, it reads from 50' away.
I wish I could check settings on the phone from home, but it's first move is to connect to the transmitter. No connection, no access.
I think it will be a great asset while backing into a spot. I already used it at a campground, and moved the trailer a foot or so to find a almost perfectly level spot. (.4 deg.)
There's also a feature "Recall hitch position" where you set it to remember where the coupler is just over the ball. No more banging into the ball.
You'll find the floor doesn't match the table, and the table doesn't match the countertop, and none match the fridge. so just pick one.
No one puts a 3/8" board under the wheels, so it's a moot point.
01-15-2020, 09:01 AM
IM Streamin
Austin
Hi Chris,
Welcome to the AS world!.
I like using the Andersen levelers, always on both wheels. make sure you include rubber pads or similar solution to add grip on slippery surfaces.
I take lego style blocks and extra 2"x10" lumber segments for more aggressive leveling.
In addition, I've found the x-block stabilizers help with stability and add confidence to any lack of chocking.
Best Wishes,
Mark
01-15-2020, 09:04 AM
Alamo Heights
This. When I'm feeling extra-picky about getting the level just right, one more block under just one of the wheels on that side gives about a half increment. I've never done more than +1.
David
Zero Gravitas 2017 Flying Cloud 26U | WBCCI# 15566
07-23-2020, 03:03 PM
Billings
, Montana
What is the distance between tires on the front axle and tires on rear axle? I want to buy some 2 x 8 lengths of lumber so I can put both tires up on the side that I am leveling. My 2013 28 FC is in storage a ways away and trying not to drive there for one measurement. Thanks.
Tom
