03-18-2020, 08:11 PM
2015 25' Flying Cloud
Bettendorf
, Iowa
Blown hitch fuse?
For some reason, my hitch lift stopped working and the light doesn’t work. I have seen blown fuses before but I’m not sure about this. Can anyone tell me if this is blown based on the picture. If it isn’t blown, any suggestions. I hitched to my truck drove a couple of miles in the rain and now I don’t have any power on the lift. If this helps, I have a 2015 25’ flying cloud. Thank you for any input.
03-18-2020, 08:14 PM
2007 22' International CCD
Corona
Originally Posted by Rltports
For some reason, my hitch lift stopped working and the light doesn’t work. I have seen blown fuses before but I’m not sure about this. Can anyone tell me if this is blown based on the picture. If it isn’t blown, any suggestions. I hitched to my truck drove a couple of miles in the rain and now I don’t have any power on the lift. If this helps, I have a 2015 25’ flying cloud. Thank you for any input. Attachment 363494
Only way to be sure is with a ohmmeter. That said, it’s showing signs of overload, so a new one is in order. The melted silver metal is from the slow blow element being overheated
03-18-2020, 08:30 PM
Bettendorf
, Iowa
Thank you. I will replace it.
03-20-2020, 10:37 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Do NOT hit the up-down bump stops.
That's the reason for the slow-blo fuse. The motor's trying but the gear stop 'sez no.
Make sure the wiring harness that runs under the LP cover has not shorted.
03-20-2020, 01:10 PM
2019 25' Flying Cloud
Newmanstown
, Pennsylvania
Mounting bolts tight?
Double check your three mounting bolts. The jack gets its ground through the frame connection. Only 15 to 20 foot pounds of torque though.
03-20-2020, 03:10 PM
Sag Harbor
, New York
Make sure you get the correct slow blow fuse.
https://www.google.com/search?q=Hitc...=airforums.com
https://www.airforums.com/forums/f44...se-151073.html
Our 2014 FC20 hitch jack uses this fuse FWIW:
[From the 20-footer thread in 2016 — click on orange arrow to go directly there]
Originally Posted by OTRA15
I guess you can order online, but your NAPA store should have them IMO. The label on the end of the small box does not indicate Slow-blow, so the counter clerk did not find them right away. A search of the catalog yielded the right SKU.
http://www.napaonline.com/napa/en/p/...335/BK_7821335
On end of small box:
782-1335...QTY
MDL-30........5
This spec may not be the correct one for your trailer.
Good luck,
Peter
FYI
FWIW
