07-01-2022, 08:22 AM
30 amperes outlet not working
Hello Airstreamers,
I need your help. 2 days ago, my travel trailer was connected at an electric 30 amp pedestal with my 30 amp rear exterior outlet. It works well but suddenly my surge protector cut off the power. After my investigations, all my appliances, my interior outlets and 30 amp exterior front outlet worked well except my rear 30 amp outlet. Since 2 days, I change for a new campground, all works well except my 30 amp exterior outlet.
So, how to fix my 30 amp exterior outlet? Do to change the 30 amp fuse situated on the A frame?
Thank you in advance to help me.
07-01-2022, 09:33 AM
2019 27' Globetrotter
McHenry
Payan, sorry to hear about your electrical trouble. What year and model Airstream do you have? I didn’t see it listed on your profile.
Knowing what unit you have will help the forum members to offer ideas.
Thanks!
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
07-01-2022, 09:39 AM
Hello again,
I have a 2013 FlyingCloud 25 RB.
07-01-2022, 09:46 AM
Alamo Heights
By "rear 30 amp outlet" do you mean the service inlet where the shore power cord attaches?
It SEEMS like you're saying the front 30A inlet is working and can supply power to the trailer but the rear inlet is not.
IF my interpretation is correct, the 2 most likely things are a loose connection in the wiring of the rear 30A inlet, and some issue with the automatic transfer switch that switches between the front and rear shore-power inlets. I wouldn't be surprised at an EMS cutting off the connection if something bad was happening with the inlet wiring.
— David
07-01-2022, 09:50 AM
Yes, I mean that rear inlet is not working.
07-01-2022, 10:19 AM
Home of Vortex tuning
2013 27' FB Eddie Bauer
Spearfish
, South Dakota
Transfer switch issues, the fix was to put power into the other power in port, to reset it.
Otherwise they burnout and fail, mine failed eventually.
I added solar and dropped the front power port (disconnected) and transfer switch gone.
"Chip Tank" is in Westwood Ca.
07-04-2022, 03:10 PM
:SPACE A" S/O 11 Air19745
2006 34' Classic S/O
Fort Worth
A few years ago Airstream used some poor grade transfer switches. You may have gotten one. I would pull it out anskmgd inspect the contacts snd relays with a ohm meter. Replace it with well known name brand.
guskmg
07-04-2022, 04:33 PM
1994 25' Excella
Waukesha
, Wisconsin
You might also find that the reason your EMS cut off power was a loose connection in the transfer switch. Wouldn't hurt to unplug from shore power and then confirm all the connections to the transfer switch are tight, clean, and show no signs of damage from overheating.
Richard
11018
1994 Excella 25 Follow the build on Gertie!
1999 Suburban LS 2500 w/7.4L V8
1974 GMC 4108a - Custom Coach Land Cruiser (Sold)
07-05-2022, 08:55 AM
Thank you everyone. Sorry for the delay. I am in Newfoundland and Labrador for vacation and there are few spots for phone ans internet. I will check the connection and transfer switch.
Thank you again
