Old 05-13-2022, 02:41 PM   #1
Ebb and Flo
davidlbriggs's Avatar
Tulsa , Oklahoma
Where is the inverter
I'm hoping one of you will know where the inverter is located in at 2012 30' Serenity rear bed Queen.. I checked with customer service at JC, but they seem to be clueless.
I believe I just need to hit the reset button.
Any help would be greatly appreciated
David
David Briggs
Ebb - 2015 F-150 3.5L Ecoboost
Flo - 2012 30' International Serenity
davidlbriggs is offline   Reply With Quote
Old 05-13-2022, 04:34 PM   #2
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
One of the "fun" things you do with any new (to you) RV is go looking everywhere. Under this / behind that / over there / back up under the whatever ..... This may involve pulling some access panels. It certainly means taking out all of the drawers. After this exercise, you will not only know where everything is, you also will know how to get to it.
Best guess, the inverter is up front, mounted on the floor, under this or that.
In some cases, the location of this or that varies as the year goes on and they "learn" more about building this or that model....
Old 05-13-2022, 05:14 PM   #3
2019 30' Flying Cloud
Grass Lake , Michigan
In our Ď19, 30 footer, it is under the front couch, driverís side.
oldenavy is offline   Reply With Quote
Old 05-13-2022, 07:20 PM   #4
s1000pre's Avatar
2021 30' Flying Cloud
2020 25' International
minneapolis , Minnesota
It will be close to the front. If you have a front compartment, that’s where it will be. Look for 14awg Romex and 4 or 6 awg black & red wires. They will lead you to the inverter.
- Stewart
s1000pre is offline   Reply With Quote
Old 05-13-2022, 07:50 PM   #5
Ebb and Flo
Tulsa , Oklahoma
Ok. I will keep looking.
David Briggs
Old 05-14-2022, 09:28 AM   #6
ckerrick's Avatar
2013 25' International
Monrovia , California
Whereís the Inverter
On our 2013 25í rear bed Intl, the inverter is under the bench seat on driverís side. At the left end of the bench seat (next to refrigerator) there is an access port cut into the bench seat if you remove all cushions. You can access it from there, or by pulling the converter which is mounted under the left side of the bench seat. Our original inverter died recently so we had to replace it.
ckerrick is offline   Reply With Quote
Old 05-14-2022, 10:06 AM   #7
greenflag's Avatar
2016 30' International
Quartz Hill , California
On our 2016 30 footer it is under the front couch on the drivers side. You may need to stick your head a little into the storage compartment to see it.
greenflag is offline   Reply With Quote
Old 05-14-2022, 02:40 PM   #8
Hermes's Avatar
2016 28' International
Trois-Rivieres , Quebec
David
Under the L couch in front, on the driver side; it will be on it's side (not lying flat on the floor). You can try the reset, or check the small fuse on the unit, or check the large fuse by the 12V bus bars on the front inside wall under the couch (as a newbie I blew that fuse by plugging in a compressor, it's not cheap!). Good luck!
2016 International Signature CCD (Oyster/Ebony), Dual A/C, 28'
2018 GMC Sierra SLE 2500HD, 4x4, Crew Cab, Duramax Diesel, Leer cap
DIY Solar: 500W Renogy panels, AM Solar hardware, Blue Sky MPPT controller and monitor, 470ah (C20) Rolls battery bank.
Hermes is offline   Reply With Quote
30RB Inverter Needs AC Power For Passthrough to Inverter plugs dsatwork 2011 - 2015 International 1 04-28-2021 10:50 AM
Flashing inverter light (Multiplex primary panel) inop Inverter ... ScottP Sprinter and B-van Forum 8 12-29-2019 08:37 PM
Question? Replacing factory converter & inverter with 2k watt inverter charger cptdzl Batteries, Univolts, Converters & Inverters 1 06-23-2019 07:55 AM
prep for my solar future: Inverter charger/inverter-converter combo wonderlust87 Electrical - Systems, Generators, Batteries & Solar 1 09-13-2017 10:50 AM
Parallel non inverter generator with inverter generator? mtbguy Generators & Solar Power 3 07-15-2015 01:48 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
