Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 11-27-2021, 05:20 AM   #1
RMNummi's Avatar
2014 23' International
Saint Petersburg , Florida
Viking Composite Propane Tanks
Anybody swap out their propane cylinders for the Vikings? Iím trying to reduce tongue weight on Intíl Serenity 23D. Already swapped out batteries for lithium. Anybody else wonder about huge tongue weight disparity on 23D vs 23FB?
RMNummi
2014 AS23D
TV #1 2017 Mercedes AMG GL63
TV #2 2017 Lexus LX570
RMNummi is offline   Reply With Quote
Old 11-27-2021, 06:38 AM   #2
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
I have heard, but can neither confirm nor deny, that composite tanks are not legal in RVs, moho or trailer. Aluminum tanks weigh about 7 lbs less than steel tanks. Not a lot.of.weight difference until you lift them manually.
Old 11-27-2021, 07:58 AM   #3
OrangeCrush's Avatar
2017 25' Flying Cloud
Longmont , Colorado
I checked into them briefly a few years ago and concluded then they were not legal for RV use. Their marketing material indicates otherwise now so maybe something has changed and they are now DOT approved for RVs. They are only a few pounds less than aluminum which is another expensive option that saves you 10lbs per tank max. I believe with the Viking tank you have to go down to a 22lb size tank to fit in the Airstream tank box.
I see the spec tongue weight discrepancy you are talking about with 23D=720lb and 23FB=467lb. Are you saying the 23FB is significantly more than spec?
OrangeCrush is offline   Reply With Quote
Old 11-27-2021, 09:18 AM   #4
Antsville , FUBAR
If the weight of the tanks is worrisome, it may be time for a lash-up evaluation.
Go for aluminum, they are lighter, and and look better longer. (most fill stations will question a rusty tank, AMHIK)
Old 11-27-2021, 09:22 AM   #5
Riveted...?
Justinhb's Avatar
2004 25' Safari
Central Valley , California
@Robertcross...love how you keep updating your signature line...lol!
- Lots of people are engaging in risky behavior, but most of them just don't know how risky their behavior really is...
2013 Ram, 2500, Crew Cab, Cummins, 4x4, SRW, Short Box
2004 25', Safari LS w/ 3" Dexter Lift Kit on Henschen Axles,
Blue Ox
Justinhb is offline   Reply With Quote
Old 11-27-2021, 09:31 AM   #6
Antsville , FUBAR
Let the 'mod's' know, they've let me know several times that 'it's not a signature' and is too long"
Old 11-27-2021, 10:17 AM   #7
RMNummi's Avatar
Yeah Mine are nearing their Recert and are looking long in the tooth. I was looking for other options but like the 30ís so probably swap for aluminum.
Vis a vis the tongue weight, was just tryptophan sleepy curious. Thatís a pretty wide variation in tongue weights between my 23D and the 23FB. They both weigh the same. Same tankage. Was wondering design wise how I got such a fat tongue weightÖitís accurate, Cat Scale tested. The real reason is curiosity if I stray to far from OEM spec handling/sway etc. if I start monkeying w/ lighter weight lithiums and composite tanks it will take off about 100lbs right at the hitch ball.
RMNummi
2014 AS23D
Old 11-27-2021, 10:40 AM   #8
2017 23' Flying Cloud
Mesquite , Nevada
How propane dependent are you? Can you get by with 17# exchange bottles? You pay a little more but get the convenience of exchanging nearly every where and no big cash layout for aluminum.
Ken G is offline   Reply With Quote
Old 11-27-2021, 10:53 AM   #9
2019 30' Flying Cloud
Grass Lake , Michigan
I got curious about this and found that they are DOT approved: https://vikingcylinders.com/support/faq/
Also found this thread on Forest River forum discussing some refillers not wanting to refill the composite tanks:
https://www.forestriverforums.com/fo...ls-231272.html
I've thought about these or Aluminum as well, but in both cases the price scares me away. Maybe when my steel tanks expire...
oldenavy is offline   Reply With Quote
Old 11-27-2021, 11:26 AM   #10
2021 27' Globetrotter
Tallahassee , FL
Maybe you just need a vehicle with the load capacity for your set up. 1 gallon of water will eat up the weight savings of that composite or aluminum tank.
Kawboy01 is offline   Reply With Quote
Old 11-28-2021, 03:29 AM   #11
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Even with no batteries in the battery box (315 amp hour lithium battery is just forward of wheel well street side under sofa and Dexter hydraulic brake pump is in battery box), our tongue weight is just over 900 pounds on our 2015 23D. Our 23D also scales 6,060 pounds camping ready. The two new 3,600 pound rated Dexter axles with 3" lifts and 12" dual puck disc brakes are are big improvements over the OEM equipment with 10" drum brakes.
Adding to the tongue weight is the inverter/charger just forward of the furnace along with other solar charging equipment and auto transfer between the front and stock rear 120Vac power inlets.
2014 31' Classic model 30 twin beds, 50 amp service, 900 watt solar system, Centramatics, Tuson TPMS, disc brakes, 16" tires & wheels
Old 11-28-2021, 05:33 AM   #12
RMNummi's Avatar
We travel relatively light, OEM everything, empty black and grey, 10% fresh water, we donít really cook so always light on the supplies too! Ours came w/o the street side ZipDee awning and was relatively optioned lite. Our last scale was spec at 5895 and 652 on the tongue. TVís were the Mercedes GL63 (Tow Rated 7500lbs) and the Lexus variant of the Toyota Land Cruiser (7500). No problems at all so far. Havenít yet checked what removing 140 lbs of AGMs and adding back in only 52lbs in Lithiums (net weight loss 88lbs) effect on scale tongue weight. Additional weight loss coming: ordered 2 Viking composite propane tanks which are 26lbs empty vs. 110lbs for the original tanks (another 84lbs net weight loss for a total of 172lbs dry weight off the tongue)Ö.Iím guessing if I moved the lithiums back (out of the batt box to inside the trailer) it would reduce the tongue weight even more. Probable future weight gains will be adding your Dexter setup and upsizing the OEM wheels (Iíve got about a 11Ē drop from TV reinforced Hitch to AS).
RMNummi
2014 AS23D
Old 11-28-2021, 08:43 AM   #13
2015 30' International
FREDERICK , Maryland
According to their website they are DOT approved
https://vikingcylinders.com/support/...ertifications/
Our cylinders are approved for use by the DOT and TC, and are actually far safer than steel propane gas tanks. Viking Cylinders propane tanks do not corrode or break down over time, and fire tests have proven they will not BLEVE. BLEVE is the technical abbreviation for Boiling Liquid Expanding Vapor Explosion. In laymanís terms this means our cylinder will not explode in a fire. Instead, the resin will burn off and the plastic liner and casing will melt. The LPG will then ďbreatheĒĚ through the cylinder wall and burn in a controlled manner. But donít forget propane is highly flammable and should be handled carefully. Improper use can be dangerous.
Viking Cylinders propane tanks are produced by Hexagon Ragasco, the worldwide leader in composite LPG cylinders. (You can learn more about Hexagon Ragasco here.) There are more than 12 million of these cylinders in service with families and businesses around the globe, and we have an outstanding safety record.
Doc Foster is offline   Reply With Quote
Old 11-28-2021, 09:17 AM   #14
Longmont , Colorado
If DOT approved the Viking tanks do look appealing. Downsides for me are still 1) None of my local fillers are listed on their "Find a Filler", 2) You only get 22lbs of propane in a 30lb propane tank size. Still seams like an expensive/exotic way to shave off a few pounds. At least with Lithium batteries you are getting other advantages along with weight savings.
Old 11-28-2021, 09:20 AM   #15
drmox's Avatar
2022 22' Bambi
Villa Park , Alabama
Here's an idea:
It is totally not feasible, is certainly illegal, would look stupid, but is fun to think about. Fashion a rack across the rear bumper of the Airstream, and mount a whole row of propane tanks. That would reduce your tongue weight, give you all the propane you could ask for, and would really keep tailgaters at bay.
drmox is offline   Reply With Quote
Old 11-28-2021, 09:25 AM   #16
RMNummi's Avatar
Cool
Originally Posted by drmox View Post
Here's an idea:
I really like that idea... kinda James Bond/spy movie too..when being chased by the bad guys, just hit the release button and boom.
RMNummi
2014 AS23D
Old 11-28-2021, 12:55 PM   #17
2014 19' International
Aloha , Oregon
I installed Viking tanks on our 23D. They come with filling certificates showing the DOT registration number and DOT special permit number in case it is necessary to convince the filler that it is OK to fill the cylinder. So far, no problems. I bought them because basically lighter is always good. The difference in weight compared to a full 30-lb steel cylinder is 23 lbs each which is 46 lbs of something else I can have influencing tongue weight but more importantly it is 23 lbs less to lug to the trailer from the propane filling station. Iím not specifically trying to lower tongue weight - just maintain it. My CAT scale trailer weight is 4820 lbs last time I measured it and my Sherline tongue weight is 740 lbs, or 15% of trailer weight, so I donít really need those extra 46 lbs for stability.
PeterDB is offline   Reply With Quote
Old 11-28-2021, 02:31 PM   #18
2002 19' Bambi
Lafayette , California
Probably not good idea! Safety in an accident comes first to mind (such as for those tailgaters). In addition, you can find a number of threads warning that the frame is not able to support much weight on the back end of an Airstream.
Tim
Tim A. is offline   Reply With Quote
Old 11-28-2021, 02:39 PM   #19
2019 30' Classic
2021 Atlas
Charlotte , North Carolina
For some reason, I thought the composite tanks were only certified for 5 years rather than 10. Is that still true as well under the new DOT certification?
2019 Classic and 2005 Land Yacht 396 XL and 2 cats
LilPeanut is offline   Reply With Quote
Old 11-28-2021, 09:19 PM   #20
RMNummi's Avatar
Did you have to purchase the new base for the tanks?
RMNummi
2014 AS23D
Composite LP tanks? Daquenzer LP Gas, Piping, Tanks & Regulators 4 07-09-2021 09:54 PM
17# Composite Propane Cylinders Airrogant LP Gas, Piping, Tanks & Regulators 15 11-24-2020 12:40 AM
Tanks, Tanks, Tanks PSU1981 Plumbing - Systems & Fixtures 8 09-02-2019 10:34 AM
composite LP tanks tarnished LP Gas, Piping, Tanks & Regulators 5 04-29-2012 12:19 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
