Old 11-28-2021, 08:31 PM   #21
CMHM's Avatar
2021 27' Globetrotter
Malibu , California
Very interested to hear more about these Viking tanks. Can someone post photos of them on the Airstream. Did you have to make any modifications?
CMHM is offline   Reply With Quote
Old 11-28-2021, 10:13 PM   #22
drmox's Avatar
2022 22' Bambi
Villa Park , Alabama
Originally Posted by RMNummi View Post
I really like that idea... kinda James Bond/spy movie too..when being chased by the bad guys, just hit the release button and boom.
Instead of a release button, I was considering something more along the lines of a giant flamethrower.
drmox is offline   Reply With Quote
Old 11-29-2021, 11:41 AM   #23
drmox's Avatar
2022 22' Bambi
Originally Posted by Tim A. View Post
Probably not good idea! Safety in an accident comes first to mind (such as for those tailgaters). In addition, you can find a number of threads warning that the frame is not able to support much weight on the back end of an Airstream.
Tim
Oh wow, I suppose I could have made it more clear that I wasn't being serious, and that I was in fact joking.
Perhaps we need a good Just Joking emoticon.
Old 11-30-2021, 08:21 AM   #24
2013 23' International
Aloha , Oregon
Did you have to purchase the new base for the tanks?
Yes. The Viking cylinder base diameter is larger than the steel tanks so a new base plate is required. It comes with a new hold-down mechanism as well that matches better to the wider and easier on the hands handles on top.
PeterDB is offline   Reply With Quote
Old 12-04-2021, 07:54 AM   #25
RMNummi's Avatar
2014 23' International
Saint Petersburg , Florida
Where did you get yours? Brick and Mortar or Amazon?
R
RMNummi
2014 AS23D
2022 AS Basecamp 16X
TV #1 2017 Mercedes AMG GL63
TV #2 2017 Lexus LX570
TV #3 2020 Mercedes GLE580
TV #4 2012 Porsche Cayenne Turbo
RMNummi is offline   Reply With Quote
Old 12-04-2021, 09:48 AM   #26
Aloha , Oregon
Direct from Viking.
Old 12-07-2021, 06:13 AM   #27
RMNummi's Avatar
On it! Ordering this week. Really interested to head over to CAT scales and check tongue weight…. Those AGMs weighed a ton, Renogy’s replaced light as feathers. Now for the Propane Vikings….
RMNummi
2014 AS23D
Old 01-15-2022, 07:47 PM   #28
SWH
2021 Interstate 24GT
Cordova , Tennessee
Curious how it went with the Viking tanks? We ordered a Caravel 16RB, which has pretty high tongue weight (490 lbs) relative to weight of trailer (3500 lbs), so I’m also looking to shave weight from the tongue. It looks like the Viking replacement for the Caravel 16RB would be the 17 lb model as it looks like from Airstream specs the Caravel has 20 lb. (rather than 30 lb.) steel tanks.
SWH is offline   Reply With Quote
Old 01-15-2022, 07:54 PM   #29
SWH
Cordova , Tennessee
In addition to your experience with the Viking tanks, curious about your satisfaction with the Renogy lithiums? I was planning to go with Battleborn since that’s what Airstream uses with their lithium package… did you consider both? Thanks.
Old 01-15-2022, 07:56 PM   #30
2017 28' International
Jim Falls , Wisconsin
Why not just drive with one tank full the other empty? When you get to your destination you can fill the tank if needed. Seems much cheaper than the Viking tanks. I don’t think 40 extra pounds is going to “brake the bank.” Now if you don’t want to lug those big tanks around I can understand.
Here are the specs off the site:
Viking Cylinders Lightweight Composite Propane Tank is designed to replace heavy propane cylinders. It’s 50% lighter than steel and comes with a comfortable ergonomic handle that allows for stacking and easy carrying. The outer walls are translucent, allowing you to see exactly how much propane is left in the tank. Each cylinder has a wide, stable base that prevents it from tipping over. Rugged, noncorrosive 3-layer composite.Unlike steel and aluminum tanks, Viking Cylinders will not BLEVE in a fire. BLEVE is the technical abbreviation for Boiling Liquid Expanding Vapor Explosion. In layman’s terms this means the cylinder will not explode in a fire. Instead, the resin will burn off and the plastic liner and casing will melt. The LPG will then “breathe” through the cylinder wall and burn in a controlled manner.Specifications:– Propane Capacity: 22 lbs– Propane Volume at 60 F: 5.24 gallons– Butane Capacity: 26 lbs– Water Capacity: 53 lbs– Height: 22.5 inches– Diameter: 12 inches- Ship Weight/Unfilled Cylinder Weight: 13.5 lbsDOT Approved. Tanks come with an initial certification which lasts for 5 years. After this time period elapses, the tanks can then be re-certified for an additional 5 years of usage.
Price: 192.50.
Daquenzer is offline   Reply With Quote
Old 01-15-2022, 08:42 PM   #31
CMHM's Avatar
Malibu , California
I filled my regular tanks at Uhaul this week and started chatting to the guy. I asked him about the composite tanks and he said they are not allowed to fill them up, and said I would hear the same at other gas stations and propane distributors.
I love the idea of these tanks but when you’re out camping there is usually just one spot to get propane and this is too risky if they refuse to fill them up.
Old 01-15-2022, 08:47 PM   #32
Did they say why they aren’t allowed to fill them? Not advocating, just wondering.
Old 01-15-2022, 09:33 PM   #33
waltb's Avatar
2014 25' Flying Cloud
San Luis Obispo , California
Send a message via AIM to waltb Send a message via Skype™ to waltb
I have no problems filling my Viking composite tanks. They are certified, show them the certification that came with the tanks. Shouldn’t be a problem.
2014 Flying Cloud - 25' RB
2016 Tundra
Air# 42643; WBCCI# 3884
waltb is offline   Reply With Quote
Old 01-16-2022, 03:04 PM   #34
CMHM's Avatar
Malibu , California
He said “UHaul classified them as not safe”. He said he has to take a picture of each tank and expiration date and upload it in order to issue the receipt.
Old 01-16-2022, 03:21 PM   #35
Doesn’t quite make sense, because everything I have read is composite tanks are suppose to be safer. There was a recall in 2013 on composite tanks, but they weren’t on Viking tanks. I think there is some misinformation out there on these. Again, not advocating, because in my opinion they are too expensive for the amount of LP they hold.
Old 01-16-2022, 07:44 PM   #36
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
All it takes is one tech at one U-Haul location to have a serious problem filling the composite tanks for the company to just say 'no' to any future interactions with them. They have no obligation to handle customers' tanks and can set policies as they please.
When I had an old forklift at my shop I used to take its tanks to the U-Haul to be filled, and at some point they must have had an issue because they told me they could no longer fill them there and could only fill 'standard' vertical 20 & 30-lb tanks. Had to search out a proper propane dealer after that.
Richard
11018
richard5933 is offline   Reply With Quote
Old 01-16-2022, 09:08 PM   #37
I can see that for UHaul, but what about all the other LP tank fillers? I can’t imagine one person at U-Haul having a problem will make all the others turn away business. Something doesn’t smell right.
Old 01-18-2022, 08:50 AM   #38
Wake forest , North Carolina
Did the airstream cover fit with your new base plate and cylinders? Thanks
Jim Plyler is offline   Reply With Quote
Old 01-18-2022, 09:20 AM   #39
Silvr_Bullet's Avatar
2017 16' Sport
N/A , N/A
Viking Composite Propane Tanks
Don’t want to name the retailer, not sure if they are still in business, but the saying went something like ( not reflective of the product ) ‘ We sell garbage but we stand behind it’ if you can’t assure yourself that you may not be able to fill it wherever, we’ll you can finish the sentence.☹️
Silvr_Bullet is offline   Reply With Quote
Old 01-19-2022, 06:46 AM   #40
RMNummi's Avatar
Inre: Renogy
Perfectly functioning. Only issue is they speak “Renogy” via communications port and absent an add on shunt won’t interactively communicate with other mfg’s devices for detailed info. If it wasn’t for Renogy perfectly fitting the old style short Airstream Battery box and BB not… I probably would have opted for BB.
R
RMNummi
2014 AS23D
Composite LP tanks? Daquenzer LP Gas, Piping, Tanks & Regulators 4 07-09-2021 08:54 PM
17# Composite Propane Cylinders Airrogant LP Gas, Piping, Tanks & Regulators 15 11-23-2020 11:40 PM
Tanks, Tanks, Tanks PSU1981 Plumbing - Systems & Fixtures 8 09-02-2019 09:34 AM
composite LP tanks tarnished LP Gas, Piping, Tanks & Regulators 5 04-29-2012 11:19 AM
