Old 09-08-2014, 12:39 AM   #1
LivLoveLaugh's Avatar
2012 30' International
South Western , Pennsylvania
sliding doors on overhead cabinets
We're having problems with the sliding cabinet doors in our 2012 CCD International.
1. The two sliding doors over the rear bed keep popping out while driving. We've been lucky so far as the just land on the bed, but sooner or later one will end up breaking if this keeps on happening.
2. The doors above the kitchen area will not stay shut. We all ready had some damage due items coming out.
Looking for solutions to keep the doors from popping out and staying closed.
Sometimes I pretent to be Normal....
but it gets boring, so I go back to being me
LivLoveLaugh is offline   Reply With Quote
Old 09-08-2014, 07:46 AM   #2
Could be caused by lack of proper running gear balance.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 09-08-2014, 08:02 AM   #3
2009 28' International
Columbia , Illinois
We roll up a 1/2 sheet of paper towel into a little cylinder and poke it thru one of the holes in the doors to keep them from opening.
sinjin is offline   Reply With Quote
Old 06-25-2015, 07:55 AM   #4
TRIPPPIN's Avatar
2012 25' FB Eddie Bauer
Southwestern Ontario , Ontario Canada
Send a message via MSN to TRIPPPIN Send a message via Yahoo to TRIPPPIN
I was looking for a solution and found this older thread. I had the same trouble and discovered the left and right doors have a specific tracks front and behind. Look in the upper track and you will see a spring clip one in each track on the left and on the right. Install the doors so when they are closed they have to be pushed over the spring clip to wedge them tight. You can bend the spring clips to hand down more to increase tension.
TRIPPPIN is offline   Reply With Quote
Sliding screen door for the sliding door! weirdstuff Sprinter and B-van Forum 29 02-28-2014 09:19 PM
Removing overhead cabinets, 19 Bambi Scupper General Interior Topics 1 03-20-2013 11:57 PM
Fixing overhead cabinets mamos Cabinets, Counter Tops & Furnishings 1 11-11-2008 08:14 AM
73 sovereign international overhead cabinets kayaker41 Cabinets, Counter Tops & Furnishings 3 04-23-2007 12:01 PM
310 Overhead cabinets jkleven Airstream Motorhome Forums 7 07-23-2002 01:08 PM
