Old 06-17-2015, 10:18 PM   #1
Napking
Skee75's Avatar
2015 30' International
Plymouth , Minnesota
Film on skylight
Here's one for you. When I was pulling all the warning stickers off my appliances, etc.. I started to peel one off the interior of my front skylight. As I removed the sticker, a thin sheet of clear film came off with the sticker. This made the skylight perfectly clear. My back skylight did not have this sticker on it, and I can't tell if the film is on it or not. The skylight is not clear though. Could someone compare their skylights and tell me if they have my set up or if both are clear.
Thanks.
Skee75 is offline   Reply With Quote
Old 06-17-2015, 10:50 PM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
That is a protective layer for manufacture and install.
Save up for Maxims.. You will want to change to them ASAP.. They are far more energy efficient and "hurricane" wind speed rated. And they do NOT sweat(condensate) inside your AS...
Edit... Get some gorilla duct tape and stick it near a corner of the underside(inside) of your "skylight". Lift the tape and any "film" should also lift with it.
Peace and Blessings..
Channing
WBCCI# 30676
Old 06-18-2015, 09:05 PM   #3
Napking
Skee75's Avatar
Great. Thanks for all your help.
Old 06-23-2015, 03:02 PM   #4
Lotus
2016 27' International
Nebo , North Carolina
Front sky light is clear. Rear has slight "frosting". You step out of the shower directly under this skylight. It is privacy.
JimGaskill is offline   Reply With Quote
Old 06-24-2015, 09:35 PM   #5
Napking
Skee75's Avatar
Perfect. Thanks for the explanation.
Old 06-24-2015, 10:05 PM   #6
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
If they look in, they will never do it again.... Eeeeeeek!
Channing
WBCCI# 30676
Rear window reflective film jaiman Windows & Screens 4 04-06-2018 03:10 PM
Use your Airstream in film and photo shoots creativefilm Commercial Listings 7 02-03-2006 09:08 PM
Use your Trailer and Tow Rig in photo shoots and film! creativefilm Commercial Listings 15 10-04-2005 04:54 PM
bad tint film in double pane window wcdelorme Windows & Screens 11 05-16-2003 02:53 PM
film on windows badagle Windows & Screens 4 05-01-2002 03:41 PM
