Old 03-28-2015, 08:27 AM   #1
Racheli's Avatar
2013 27' FB International
Casper , Wyoming
Control panel not working
I'm probably in the wrong forum but here it goes. Control panel and fridge in 2013 international not working. All lights work. They both were working- showed water levels, pump working and now nothing. Fuse box diagram is faded so not sure where to start. Any ideas?
Racheli is offline   Reply With Quote
Old 03-28-2015, 09:00 AM   #2
Racheli's Avatar
Casper , Wyoming
Found the blown fuse, but now every time we turn on water pump the fuse blows. How to fix?
Old 03-28-2015, 09:17 AM   #3
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Check the electrical connections at the pump, make sure they are secure. Your pump may have gone bad also. Either way sounds like youve got a dead short to ground so better investigate further.
mayco is offline   Reply With Quote
Old 03-31-2015, 12:25 PM   #4
Racheli's Avatar
Casper , Wyoming
Okay thanks so much! We're getting it checked out today. Now it seems we have battery problems also. Woke up to a weird smell, thought it might be the propane but batteries are real hot. Hopefully some of this is still under warranty....
Old 04-17-2015, 07:51 AM   #5
Lotus
2016 27' International
Nebo , North Carolina
Likely batteries are overcharging due to faulty charger not shutting down correctly. Correct immediately. Dangerous situation.
JimGaskill is offline   Reply With Quote
Old 04-18-2015, 11:49 AM   #6
Racheli's Avatar
Casper , Wyoming
Found out batteries are fried, we didn't know you had to check the water in them. Put brand new batteries in, water pump still not working and now it seems when we use the hot water, the same fuse is blowing. So it's seems something electrical is going on. I have to take it to Windish in Colorado to get checked out. It's under warranty until October so hopefully most of this will be paid for. The batteries weren't though of course..
Does Dodge RAM's Integrated Sway Control Work Well With Friction Sway Control? interstateflyer Towing, Tow Vehicles & Hitches 9 08-13-2014 11:05 AM
Help! Battery not charging, outlets not working when plugged in AirGal04 Electrical - Systems, Generators, Batteries & Solar 9 06-06-2014 10:15 PM
control panel gauge not working , get reading on probes batt Electrical - Systems, Generators, Batteries & Solar 2 08-22-2013 08:38 AM
12V partially working/Control Panel Issue? rayandre 1970 - 1973 Overlander 21 06-01-2013 05:18 AM
Power Jack/Control panel not working TinLiz Towing, Tow Vehicles & Hitches 5 06-27-2012 12:41 PM
