Update on bedroom wallcovering International
Just finished the wall covering project. I did some research on YouTube and decided to go with just washing the panels down and using peel and stick method without any additional prepping.The vinyl lays down nicely but you need to go slowly and lift back a to align now and then and smooth out horizontally, the trick is to keep your edge vertical. I found using a plastic cr card and a felt wallpaper smoother works great. I cut and laid the full sheets out for 2 days to acclimatize them as recommended.
Pic; prep for covering by removing TV and Dometic controller I pulled the switches but left them wired up and cut around these spaces.
Pic ; opposite wall done
The good thing about this is it can be reversed back at anytime.
Laurence
