Old 06-22-2015, 12:51 PM   #1
2015 25' FB International
Advance , North Carolina
30-Amp Power Cord - LEDs not working
Not an emergency here, as everything electrically appears to be working just fine - even battery charging. Neither the LED on the end of the cable, nor the LED on the power hatch door will come on. They both worked fine just a couple of weeks ago, but haven't worked at the last 3 different campsite visits. It's just one of those little nagging aggravations... I use those little LEDs to verify there's power at the post and at the camper.
Any ideas?
Bruce AD4ET & Marcia KE4JZE
WBCCI #5027
TinCloud is offline   Reply With Quote
Old 06-22-2015, 12:58 PM   #2
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
I didn't have a good experience with the Furrion LED's with my '12 28' Intl CCD. They died after a couple of months. Eventually, I ended up replacing the 30amp cable, and the LED's on the replacement lasted a couple of months. Just didn't have good luck with them, though I really like the Furrion product line.
_________________
"SilverLeaf II" 2015 30' Classic
2019 RAM 2500 Limited 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 06-22-2015, 01:56 PM   #3
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
Bruce, Me too. The led's lasted about 6 trips for me and both are out. There are plenty of posts on the failure, it is not repairable. I bought a Marinco cord, which I like better anyhow.
Larry
lsbrodsky is offline   Reply With Quote
Old 06-22-2015, 02:12 PM   #4
JDS
2014 Bowlus Road Chief
JDS's Avatar
Cumming , Iowa
Larry
I did exactly what Larry did.
John S.
JDS is offline   Reply With Quote
Old 06-22-2015, 04:21 PM   #5
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Electrical Receptacle Wall Plug AC Outlet Ground Tester - Circuit Testers - Amazon.com
This.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 06-22-2015, 04:25 PM   #6
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
One of my Furrion LEDs was dead from day one. Did you try the other one on your trailer?
2019 Ford Expedition Platinum
Old 06-23-2015, 10:06 AM   #7
2014 25' FB International
Metuchen , New Jersey
They may come on again.
The LED indicator on my cord was "hibernating" since last fall and this past weekend decided to show it's beautiful blue eye. =)
GenXair is offline   Reply With Quote
Old 06-23-2015, 10:28 AM   #8
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
The one in my cord went out after a couple years, the receptacle light still works. Been plugged in in the sun for about 18 months total so the cord is showing lots of surface sun damage, have to consider it a consumable item after a few years' heavy use.
I agree about the convenience of the light, nice to know power is at the trailer when you flick the pedestal breaker on.
Doug and Cheryl
Old 06-23-2015, 12:04 PM   #9
Thanks All! Sounds like I'm not alone here with this LED problem. I checked around and found that a new cord with LED will be about $90. Who knows, as GenXair says - they may come back on! So, I think I'll just deal with no LED for a while longer. Thanks for the input.
WBCCI #5027
Old 06-24-2015, 08:04 AM   #10
dcasr's Avatar
1990 29' Excella
Travelers Rest , South Carolina
The little lights are nice, but the important thing is full power coming through. My lights are still working after six years. I use a shore power line protector to filter the shore power and guarantee that it isn't reversed polarity, over or under voltage, or otherwise messed up. At a fairgrounds in St. Augustine last March the power jumped to 150 volts and my line protector caught it and shut down the connection. The line protector has lights on it to tell me when it is powered, testing, fully on, or an incident has occurred. Can be put on either end of an supplemental 30 amp cord.
WBCCI 2456 Georgia Unit 32
1990 Excella 29' Centramatics
2016 GMC Sierra Crew Cab 2500 HD 4x4
6.6L Duramax + Allison, 3.73 axles
dcasr is offline   Reply With Quote
Old 06-27-2015, 10:27 PM   #11
chaseav's Avatar
I started a post about this back in January, not 2-3 weeks after buying my Intl. I liked the LED indicator on the heads but they went out. The ones on the AS itself still work though. There is/was a campaign to replace/repair/update the cord or the receptacle thingy from the factory but apparently mine was in fact complied with prior to departure. My dealer told me they would give me a new cord but these guys have been so good I refused it and chose wondering about my polarity. Just another way I like to "live riveted" I guess!
chaseav is offline   Reply With Quote
30 Amp Power Cord Devoman Electrical - Systems, Generators, Batteries & Solar 12 05-15-2015 01:57 PM
Two LEDS remain on while on shore power? Airborne6 Electrical - Systems, Generators, Batteries & Solar 15 05-15-2015 06:28 AM
Replace POWER-HOG-HOT HALOGENs w/LEDs = Easy al66pine Lights - Interior & Exterior 4 11-01-2008 11:27 AM
30 amp power cord trouble davidz71 Electrical - Systems, Generators, Batteries & Solar 1 03-12-2003 06:29 PM
