12-01-2017, 07:17 AM
#321
1963 22' Safari
2020 27' Globetrotter
State of
To my knowledge it was never used in production, just in Wally's personal trailers. I'm excited to get it in, worried a little about it's longevity, but in the pictures we see lots of area rugs etc too, so that should help. We're a no shoes in the trailer kind of family, so hopefully that will limit the pebbles and the like. We went with a natural finish so it should be easy to sand and repair or replace any damaged tiles over time.
Scott & Megan
VAC LIBRARIAN WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
12-03-2017, 10:23 PM
#322
1963 22' Safari
State of
I will have picture updates soon. Lots of slow projects lately. I’m looking for a little help on the toilet mounting. Can someone help me understand what type of mount the stock toilet was supposed to have to the tank?
Scott & Megan
12-05-2017, 07:54 AM
#323
1958 18' "Footer"
Idyllwild
Take a look at my Post #16 because it shows the original toilet
But then look at #81 because it shows my modifications to the holding tank and has the fitting removed. I The fitting was a weld in female pipe fitting that was glassed in.
I couldn't find any repair parts at the time & decided to replace my toilet simply because I didn't want to have to deal with that while camping.
12-05-2017, 06:39 PM
#324
1963 22' Safari
State of
Thanks for the pictures! You don't happen to still have that fitting do you?
I've been looking at the valve, it looks in good condition, the gasket at the flap looks dry but I think I can get a buddy with access to a hobby style laser cutter to make me a copy. I'm thinking of trying to polish, or at least burnish the base and leave it raw aluminum. I like that we can control how much water goes in the bowl, versus the combined flush and dump valve on the modern ones. I do have concerns about the flush valve so if anyone has a spare I'd be interested in picking one up.
thanks!
As a minimum I can find a weld on or floor flange and mount that to some stainless and bolt on with a good tank sealer.
Scott & Megan
12-06-2017, 07:41 AM
#325
1958 18' "Footer"
Idyllwild
I'll look but it will take a few days, pretty sure I tossed it when nobody wanted the toilet or other parts
12-06-2017, 06:32 PM
#326
1963 22' Safari
State of
Thanks!
It’s been a frustrating week. All backwards motion. This past weekend I stripped the paint carefully off the sliding Formica over Masonite doors, but then realized the plastic was discolored from the spray paint and stickers. I went back and forth about new vs original but we couldn’t live with the staining. I didn’t notice it until they were up and I had better light After trying everything I decided to go ahead and paint them a close color to the original Formica.
The last two days they were carefully prepped then painted again
Tonight I installed them. I have to touch up the cabinets themselves since they only had one coat on the outside due to the riveting to install. I liked it overall though, but..
I
I quickly discovered that the formica served an important function. Due to how thin the doors are, they flex and they rub against each other at times. The Formica can handle the rubbing, the painted surface can’t. It scuffs. Soooo I wasted 4 evenings of work but learned something. When I make the front counters I will buy enough laminate to remake all 5 upper cabinet sets of doors in as close a laminate as I can find.
Scott & Megan
12-10-2017, 09:16 PM
#327
1963 22' Safari
State of
I was able to get a lot accomplished this weekend.
First off my preway stove search is complete. Lots of cleaning but I have a good one now.
I sanded the floors, and did some second applications of filler on elevator bolts where the filler shrank a little. I’ll get to sanding again tomorrow.
The last of the holes up front are patched and primed. The last roof locker was stripped to bare metal, primed and painted today. It was the worst one because of the heat from the wood stove they had under it.
The power is on! It’s great to have outlets and lights finally.
I’ve decided to install the tub completely before the cork goes in to avoid the aluminum skirting from possibly scraping the floor.
Test fitting.
All the aluminum needs to be sanded and painted this week then I can assemble, Mark for the drain and get it all fastened in place.
Is it black? I can’t tell. It’s dark for sure. Looks very close to the same darkness as the black cabinet knob.
Scott & Megan
12-13-2017, 06:12 PM
#328
1963 22' Safari
State of
FOUND!! Wally Byam's '55 Cruiser - 1956 European Caravan trailer
Scott & Megan
12-14-2017, 03:21 PM
#329
1965 26' Overlander
Tulsa
, Oklahoma
Excellent work!
12-15-2017, 12:02 PM
#330
1977 23' Safari
Niagara on the Lake
, Ontario
You’re attention to detail is amazing,
I’ve restored a few cars and it’s easy to find pictures and unrestored original cars to look at and see how they were built. You’ve got a much more difficult task working from pictures and you’re doing an incredible job of it.
1977 Safari Land Yacht
2005 Toyota Tundra SR5
2022 Toyota 4Runner SR5
12-15-2017, 10:08 PM
#331
1951 21' Flying Cloud
Sacramento
Just catching up to your progress and I’m absolutely amazed—probably one of the most impressive restos on this site which is saying something.
So bummed about your fridge. Have you considered shimming up and raising the surrounding galley cabinets and fixtures to accommodate it? Of course being 10+ inches taller than what you were thinking the difference might be too much to overcome, but thought I’d throw it out there. Hate to see all your work go for naught!
12-15-2017, 10:42 PM
#332
2007 27' Safari FB SE
NW Oregon in a nice spot
, Oregon
By far the best post going on this forum in my opinion. Just weighing in so I don't miss any updates. I only dream that I could do what is being done to this trailer.
12-16-2017, 09:56 AM
#333
1963 22' Safari
State of
Wow guys thank you. I appreciate it. Unfortunately going taller with the cooktop wouldn’t allow a usable surface to cook without a foot stool. Now I just hope to find a buyer for the wrong one!
I’m heating the trailer this weekend with the cork inside to finish acclimating it for install this week
In the meantime I am cleaning the shop getting ready to into cabinet rebuild mode.
One cabinet that was virtually complete I really want to save is the wardrobe that shares the tub plumbing. The tub side still had its original laminate, just one coat of paint. I thought perhaps the paint stripper discolored the laminate doors so I tried a straight razor on this panel. Same issue. The lighter color is where the paint had flaked off. The darker is where I did the scraper. The question is what in the environment took off the brown that strippers and scrapers don’t. I would think maybe UV but the windows were boarded up with plywood. Any thoughts? I’ve got to figure out something. I don’t want to throw this piece away.
Scott & Megan
12-17-2017, 06:21 PM
#334
1963 22' Safari
State of
After trying every cleaner in the garage I had I decided to try and bleach the panel. I tried some toilet bowl gel with bleach. I figured it would stay wet longer. After 4 hours I scrubbed it again and wiped it clean. I scraped the paint off the lower half. I hadn’t done everything up above but the test was successful enough I’ve recoated and will let it soak over night. It’s in my shop with good ventilation. The gray is the original color, dark brown stained and the lighter brown after one treatment. Keeping my fingers crossed.
Tomorrow night I should have an update on the cork floor which starts tomorrow morning.
Scott & Megan
12-18-2017, 03:10 PM
#335
1963 22' Safari
State of
Cork going down. It’s remarkably easy to install but very time consuming to come up with a nice mix of all the variety of shades.
Contact cement down
Almost dry.
Main traffic pattern in
I just finished putting glue down on the other areas, and moved my stacks (they need to be flat anyway). Tonight I’ll install the last full tiles. Tomorrow morning I can cut the edge tiles and install those.
Scott & Megan
12-18-2017, 04:23 PM
#336
1963 22' Safari
State of
All the full tiles down.
Scott & Megan
12-18-2017, 04:46 PM
#337
2016 30' Classic
Naperville
Originally Posted by goransons
This is my favorite thread. You do good work.
Ed
2016 Classic (with ProPride)
2016 Silverado 3500HD Diesel drw
1995 & 2004 Gary Fisher Hoo-Koo-e-Koo emergency vehicles
12-18-2017, 05:33 PM
#338
Central
, Mississippi
Good work and smokin' fast!
12-18-2017, 05:48 PM
#339
1963 22' Safari
State of
Thanks you guys. Not real fast though. The layout took me about 3 hours, and I spent several hours sorting and mixing the tiles before that. Once the glue was down the tiles went in really quickly. The cuts will take awhile, but thankfully I don't have that many.
I'm a big fan of the contact cement. Unlike a vinyl product, you set the tile, it's pretty much instantly stuck, but then you hammer it in place with a rubber mallet, it specifically tells you not to roll it on.
By the way for anyone wondering, the tiles came from Globus Cork in New York. They've done cork floors a long time. They have endless options for stain and tinting colors, and will cut the tiles in any size, and for that matter any shape you want. Everything is made to order so I actually ordered this floor 2 months ago. Thankfully we have a few warm days this week then a long window of very cold so I'm trying to get it down plus the one more top coat of sealer while I can keep the trailer warm and not go bankrupt when the power bill comes.
Scott & Megan
12-18-2017, 05:53 PM
#340
Western
, Massachusetts
Wally would be proud.
Great thread.
