06-01-2018, 08:51 PM
#521
2007 22' International CCD
Corona
06-02-2018, 04:58 PM
#522
tallahassee
Originally Posted by goransons
Thanks guys. We will have it on display in Salem, likely without water and gas systems done. We plan to camp in it for the vintage rally in August on the Oregon coast, that gives me a 6 weeks to finish up and test systems and shake downs on it.
We sold our 51 SS Clipper, our 65 Overlander, 49 SS Clipper, and 65 Streamline Duke to take on this one. It is certainly more than I ever imagined doing.
We appreciate the ideas and the compliments but it just wouldn’t feel right to charge admission.
But, as Paula also suggested, do consider a donation jar. You have done such a wonderful job on this trailer but you’ve also paid the piper for many of those parts.
August has to be better somewhere than it is in Tallahassee. This one time, I sure wish I was closer to the west coast.
Carol
06-02-2018, 08:17 PM
#523
1963 22' Safari
2020 27' Globetrotter
State of
We’ll mull it over. Who knows what rules they have too. We’ve never been to an international.
Today I made tons more sawdust.
The beds needed base mounding and a board to hold the mattress in place.
The covers to hide the kitchen water lines also were made today. I’ll get pictures up once they are in place.
I finished the poly on the 6 doors, those will go on tomorrow.
I also finished the marker lights and started the bike rack install. I’d have finished but my work bench hit my box of stainless mounting hardware. I finally found it but called it a day.
I hope to get everything mounted up in the morning and start on the front couch.
We found a portable typewriter from the era for the second shelf.
I need to pull tires so I can get the rim blasted and painted.
Scott & Megan
VAC LIBRARIAN WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
06-03-2018, 04:28 PM
#524
1963 22' Safari
State of
I thought I’d get the drawer slides done but didn’t even start them. I did get all the doors mounted and the latches on. Most of the morning was cleaning hardware. I thought I’d get them in, finish the drawers and swap the tires, if I had about 6 more hours to work on it I’d have it done. After work tomorrow I can get back at.
Bathroom wardrobe doors
Kitchen doors
I forgot the table picture.
The little stuff takes so much time...
If anyone has 4 twist latches I’m on the hunt for some.
Scott & Megan
06-03-2018, 05:19 PM
#525
tallahassee
Scott,
Do you have a current list of the things you are still looking for? Perhaps some of us can help find those items. If you don’t mind posting it, that is. Truth be told, I don’t know what latch you need so if there are photos or something to help identify it, let me know.
Carol
06-03-2018, 08:20 PM
#526
1963 22' Safari
State of
Sure! thankfully the list is rather short.
H20 original lock cylinder (not the VTS replacement)
50's era long spout kitchen faucet.
4 (or more, some are pretty toast) oddie latches and catches - white or black knob, chrome/nickel finish
2 of the fiberglass chairs (Eames, perhaps Herman Miller) for the dining area. I figure those are a more local thing, I just haven't come across them yet.
I'm still looking for one more sconce shade that has the right plastic insert.
Thanks for keeping an eye out!
Scott & Megan
06-06-2018, 08:38 PM
#527
tallahassee
All I’m finding are the knobs! Nothing to go with them.
06-06-2018, 10:23 PM
#528
1958 26' Overlander
Battle Ground
bargman lock cylinder
Scott I've got two lock cylinders without keys that I believe are originals. I'll take them into a locksmith and see if he can make keys for at least one.
Did the latch assembly work out OK otherwise?
06-07-2018, 10:23 PM
#529
1963 22' Safari
State of
I think the inside unit is working correctly. It’s got a much stronger spring and significantly tighter pivots. I need to settle up with you on it! Thanks for checking on the lock. I also have a possible lead on a NOS lock cylinder but haven't seen it yet.
Scott & Megan
06-09-2018, 03:14 PM
#530
1963 22' Safari
State of
The next saga. The axles in general are in great shape. Out of an abundance of caution I replaced all the bearings and seals, as well as the wheel studs and lug nuts (some looked stretched/bent).
The issue is I need to find a source for the brake adjustment spring. One broken this one is pretty rusty.
I’m having problem finding a spring with both hooks facing the same way. 4” long
Here’s it back on the ground. Back axle is done for now. I pulled the parking brake hydraulics out. I’ll update that this summer. This always only had one axle of brakes on the road.
Here’s the rear wheel back together
Scott & Megan
06-09-2018, 06:29 PM
#531
1958 26' Overlander
Battle Ground
In your photo the hooked ends face out instead of in towards the coils. Does that make a difference? Would the other style work?
06-09-2018, 06:32 PM
#532
Overkill Specialist
2020 30’ Globetrotter
2014 23' International
Dadeville
, Alabama
06-09-2018, 07:43 PM
#533
1963 22' Safari
State of
FOUND!! Wally Byam's '55 Cruiser - 1956 European Caravan trailer
Gmfl it won’t work with the hooks facing different directions. We tried that one. I think I found one that will work through vintage camper.com.
http://www.vintagecampers.com/viewpart.php?partID=2338
I’m hoping it will work
Scott & Megan
06-09-2018, 08:05 PM
#534
1963 22' Safari
State of
I did get decals on. The reproduction Mexico decal and the caravan decals. Most of my day was axle work.
Scott & Megan
06-14-2018, 09:04 PM
#535
1963 22' Safari
State of
School’s out for summer!
I started summer off by finishing the street side drawer slides and reassembling the bed.
Tomorrow I’m finishing up the wheels, my brake springs arrived.
I’m hoping to also finish up the living room couch frame. It won’t have cushions in Salem, sorry folks. Between the amount of work left and the cost that will have to wait.
I started installing the Zenith radio this afternoon, I’m waiting on an adaptor for the external antenna. I miss radio shack.
I also received some vintage aluminum tumblers we bought that match what they used. They are Italian made Heller brand
Working from the back to the front finishing little jobs. Please know it won’t have running water or gas by Salem. That will have to wait until July.
Scott & Megan
06-14-2018, 09:10 PM
#536
2012 Avenue Coach
Corpus Christi
Great work, as usual. Thanks for the update.
06-14-2018, 09:17 PM
#537
1966 22' Safari
Fredericksburg
Scott, you’re almost there. Things are really falling into place. Hopefully we’ll finish our 55 and make it up the west coast in 2019 to see your project. Good luck and keep it up, Bubba
06-16-2018, 07:24 AM
#538
1967 26' Overlander
Haute-Aboujagane
, New Brunswick
I am amazed by your attention to details. I have been following along with your progress.
06-18-2018, 06:56 PM
#539
1963 22' Safari
State of
I’ll have pictures with curtains tomorrow but I’ve reached a stopping point so we can start packing for Salem.
I still have gas and water lines to run, wheel well trim, some cabinet trim, the front couch cushions, finishing up the lid over the fridge vent and the spice rack etc. I’m just burned out with it and need a break!
Spice rack started, need to do the Formica and trim on it, paint the fridge door and install the filler strip to the right of the fridge. Those all will wait. I’m happy how the rack turned out
I have a few chips to repair but hours of scrubbing and degreasing and the Preway looks better. It sticks out just like Helen’s front kitchen with Krefft.
The tool pile is getting smaller.
Scott & Megan
06-18-2018, 07:14 PM
#540
2012 Avenue Coach
Corpus Christi
Bravo.
