Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Trailwind > Trailwind
Old 09-20-2020, 12:47 AM   #1
Disco Stu's Avatar
1951 18' Clipper
1965 17' Caravel
Ballarat, Victoria , Australia
'49 Trailwind resto
After a very long wait to get our little trailer to Australia, it arrived in awful condition. There's no use complaining about that, it is what it is so we got straight into fixing the little jigger up.
Here it is in it's new home, the day it arrived!
Disco Stu is offline   Reply With Quote
Old 09-20-2020, 01:00 AM   #2
1960 22' Safari
in the wilderness , The great Mojave Desert
One picture is not enough.
I'd rather be boon docking in the desert.
WBCCI 3344 FCU
AIR# 13896
CA 4
Yes, we have courtesy parking for you. About an hour North of Los Angeles.
Goin camping is offline   Reply With Quote
Old 09-20-2020, 01:05 AM   #3
Disco Stu's Avatar
1951 18' Clipper
1965 17' Caravel
I've read a lot about the pipe frames but have never seen one up close. Wow, I can't believe how big a part of the whole structure the plywood floor is! Anyhoo, it's junk so We'll make a new one.
ID:	379049   Click image for larger version
Old 09-20-2020, 01:06 AM   #4
Disco Stu's Avatar
1951 18' Clipper
1965 17' Caravel
Working on it...
Old 09-20-2020, 01:16 AM   #5
Disco Stu's Avatar
1951 18' Clipper
1965 17' Caravel
We've done a full shell off on a 1970 25' before, compared to that one the top came off so easily with the little fork and some tyne extensions.
ID:	379052   Click image for larger version
ID:	379054   Click image for larger version
Old 09-20-2020, 01:24 AM   #6
Disco Stu's Avatar
1951 18' Clipper
1965 17' Caravel
I was quite happy to see that the edges of the floor were not rotted away so I was able to trace the floor shape off onto four fresh sheets of Thermolite ( same as your Coosa board ). I found the point to swing an arc from and we'll have perfect semicircular ends and straight sides.
ID:	379056   Click image for larger version
ID:	379058   Click image for larger version
Old 09-20-2020, 01:38 AM   #7
Disco Stu's Avatar
1951 18' Clipper
1965 17' Caravel
That's it so far (first week ), I'd like to get the chassis done in the next couple of weeks. I found some particularly helpful threads here, most of all Submariner's Liner build.
I'll use a 100NB pipe in medium wall, 1.6 or 2.0mm sheet for the cross members, and 100 x 50 x 2.5 or 3mm RHS to make it more of a ladder frame and to support the spring hangers and shackles. New axle / hubs / brakes.
We've ordered some orange speckled Marmoleum for the floor too....
Old 09-20-2020, 01:45 AM   #8
Disco Stu's Avatar
1951 18' Clipper
1965 17' Caravel
This is the file so far to get the cross members laser cut.
Old 09-21-2020, 12:32 AM   #9
Disco Stu's Avatar
1951 18' Clipper
1965 17' Caravel
Thinking about it further, I think I'll swipe Submariner's idea with the plates and fasteners instead of welding cross members directly to the pipe and RHS.
The top three parts will be 3mm, folded into a channel for more support under the flooring under each end.
Name:	Screen Shot 2020-09-21 at 4.25.38 pm.jpg
Old 09-24-2020, 08:19 PM   #10
Disco Stu's Avatar
1951 18' Clipper
1965 17' Caravel
I've done a bit more work on the chassis design, the steel has been delivered, just waiting on the laser cut parts.
There's no hitch available in Australia that looks anything like factory so I'll mount this one on a plate inside the drawbar pipe.
ID:	379438   Click image for larger version
Old 09-24-2020, 08:23 PM   #11
Always learning
Lance M's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Lance M
Cool trailer. I look forward to seeing the work.
Lance
Lance M is offline   Reply With Quote
Old 09-24-2020, 08:27 PM   #12
Iansk's Avatar
1977 31' Sovereign
Sunset Valley , Texas
Nice work! Following along...
I want to know more about the trailer’s home, that place looks like my dream house...
Ian
Iansk is offline   Reply With Quote
Old 09-24-2020, 10:23 PM   #13
Disco Stu's Avatar
1951 18' Clipper
1965 17' Caravel
Thanks guys!
Ian, It's part of an old war time explosives factory, built in 1940.
So, it's even older than our oldest trailer....
Old 09-25-2020, 08:24 AM   #14
Iansk's Avatar
1977 31' Sovereign
Originally Posted by Disco Stu View Post
Thanks guys!
Wow.
Well, from that one photo I'm in love...
Great to see the work you're doing on the trailer, your CAD skills are impressive.
I really appreciate your attention to detail and innovative approach.
Ian
Old 09-25-2020, 11:09 PM   #15
Disco Stu's Avatar
1951 18' Clipper
1965 17' Caravel
Hitch time...
Saturday Morn here, I spent a few hours getting the hitch fitted, all went to plan.
I cut a plate into the pipe and turned up some little crush spacers in the lathe, should be heaps strong.
ID:	379490   Click image for larger version
Old 09-25-2020, 11:12 PM   #16
InsideOut's Avatar
1956 22' Safari
2015 27' Flying Cloud
Conifer/Evergreen , Colorado
Images: 108
Very cool! Are you going to flip the body around so the door is on the other side?
Shari
RMVAC | ACI - CO Unit (Formerly WBCCI) | BIRDY - our 1956 Safari | 1964 Serro Scotty
Old 09-25-2020, 11:18 PM   #17
Disco Stu's Avatar
1951 18' Clipper
1965 17' Caravel
Hi Shari, there's no need to do that in our state but I believe it's required in some states in Australia.
This trailer was built before the vehicle design rules were introduced so it's exempt from the rules.
Stu
Old 09-25-2020, 11:21 PM   #18
InsideOut's Avatar
1956 22' Safari
Images: 108
Thanks - I always wondered how the worked. Interesting that it's State-by-State...good for the grandfather clause too!
I'll be following your resto - it's always fun to see these 'oldies but goodies' being brought back to life!
Shari
Old 09-26-2020, 07:32 AM   #19
MsRivet's Avatar
2004 28' International CCD
1948 22' Liner
1963 22' Safari
Oakland , Florida
Send a message via Yahoo to MsRivet
Hey Stu!
I’ll be watching as well. Spectacular work so far. Your skills are AbFab!! I’ll take the building as well. Can’t wait to see your progress. I know the distance is great but hopefully you can one day meetup with GoatBoy and get those grand old caravans together!!!
Safe Travels ~
MsRivet
Not all those who wander are lost.
Living the Dream ... Plan B
The 75 year journey of our Airstream Liner . . .
https://www.airforums.com/forums/f60...ey-176336.html
MsRivet is offline   Reply With Quote
Old 09-26-2020, 07:56 AM   #20
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Serious skills and materials.
GCinSC2 is offline   Reply With Quote
trailwind :: 1949 Airstream Trailwind Goatboy Airstream Registry Discussions 0 01-23-2018 07:02 AM
Ohio Design Thesis - Resto/Redesign Cursh General Repair Forum 227 07-20-2013 07:31 PM
New Member - double resto in FL ahuker Member Introductions 4 07-23-2007 08:59 AM
website - '68 Caravel resto Stefrobrts 1966-68 Caravel 5 08-19-2006 01:40 PM
1st post-resto trip Stefrobrts On The Road... 9 05-09-2005 12:33 AM
