Old 08-23-2017, 06:31 AM   #21
Nags Head , North Carolina
Originally Posted by OTRA15 View Post
Thanks and welcome to the forum!
According to this source, the Yeti manufacturing chain is a little more complex than that:
http://thecoolerbox.com/are-yeti-coolers-made-in-usa/
Almost every page on the Pelican site says "Made in USA" somewhere on the page.
See also:
http://www.pelicancases.com/Compare-...i-Coolers.aspx
http://www.coolersonsale.com/pelican-coolers-vs-yeti/
http://thecoolerexperts.com/where-the-coolers-are-made/
I cannot vouch for the accuracy of any of this, so the above links are:
----- For everyone's information, and for what it's worth! -----
Cheers,
Peter
FYI -- FWIW
PS -- The main difference I can see is that the Pelican line mostly has mechanical latches, and the Yeti has rubber latches which require more strength to operate IMO. With DW's arthritis, a simple mechanical latch seems easier to use IMO.
FYI and FWIW.
Ive never looked to far into it. I have a friend that works off-duty security at yeti in Austin.. Seen Pics of the interior of the warehouse. Thanks for the welcoming. Ive been researching for over a year on her for my upcoming purchase.. Hailing from Outer Banks NC..
oldsaff is offline   Reply With Quote
Old 08-23-2017, 06:52 AM   #22
ExStreamin's Avatar
2014 30' International
Ellicott City , Maryland
We have three Yeti coolers and the 65 seems to be the one we use most and is great. Any larger and I think it would be too heavy and awkward for one person to pick up (empty). Once full it takes two people to move around.
ExStreamin is offline   Reply With Quote
Old 08-23-2017, 07:01 AM   #23
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
The "gotcha" with these coolers (Yeti or Pelican) is that they are big and heavy. If you are used to a "20 quart" Coleman, a 20 quart one of these will be a bit of a surprise. The insulation in the walls is a lot thicker. The weight adds up. Get one with wheels ....
Old 08-23-2017, 07:17 AM   #24
1972 25' Tradewind
Hockley , Texas
You might also check out the Rtic coolers. Half the price of Yeti, but the same roto-molded design. Free shipping too, I believe. I've had both and from my experience, they perform exactly the same. Durability is the main reason I'll pay the extra money. They will last forever. And yes, lock them down or keep them inside. They will disappear otherwise.
hbf442 is offline   Reply With Quote
Old 08-23-2017, 07:21 AM   #25
urnmor's Avatar
2012 25' Flying Cloud
Berlin , Maryland
I was looking at the RT
IC however they just lost a case to YETI where they have to pay an undisclosed amount of money and also change what they make. So I am concerned about where they will be in the future.
urnmor is offline   Reply With Quote
Old 08-23-2017, 08:18 AM   #26
I have had a Yeti 65 for years and it has worked great for road trips. I normally precool with some ice packs and drop in a couple of pounds of dry ice before we get started on a trip. Anything close to the dry ice will freeze solid. Dry ice is nice since it doesn't make everything all wet inside the cooler and doesn't take up much room. After the dry ice is gone I switch over to regular ice. I normally start off with a packed cooler so by the time the dry ice is gone I have room for ice.
Yeti was the best when it first came out but there are other molded ice chests on the market that are just as good if not better. The Orca and Siberian cooler look promising. I have a Pelican 65 as well but the overall size is larger and I keep gong back to the Yeti.
It is normally the wife and I lugging around the cooler and a 65 is the biggest we can handle when fully loaded. The rubber feet on the bottom make it very hard to slide around. It is nice when you travel but placing it in the bed of the truck can be fun.
Good luck!
AirTime23 is offline   Reply With Quote
Old 08-23-2017, 08:42 AM   #27
Mollysdad's Avatar
Probably better security than Ft. Knox.
I don't know, I can leave my Igloo sit out in the campground and buy an ice maker for less money.
Yuppie status symbol, I swore I'd never buy another Pelican product after I busted my knuckles a hundred times on the old latches.
I loved my Storm cases, and then Pelican bought Storm/Hardigg.
Old 08-23-2017, 08:48 AM   #28
1972 25' Tradewind
Hockley , Texas
The lawsuit is settled and the new design is being sold now. Basicallly, the appearance is different. I have both the old and new design, from a distance you can't tell the difference. Their corporate headquarters and a retail showroom is in Cypress, Texas.
Old 08-23-2017, 10:33 AM   #29
Sag Harbor , New York
PS -- On another thread someone mentioned that Cabela's has its own line of super coolers, with favorable pricing. FYI.
On using dry ice, these coolers are so air-tight that the general suggestion is to not lock the lid down, as the off-gassing of the CO2 will create internal pressure which could damage the cooler.
FWIW!
Old 08-23-2017, 03:25 PM   #30
Boxite's Avatar
2008 22' Safari
Cannonball wrote: "I have the Yeti "Roadie" cooler. They are very durable, very heavy, and very expensive. I lock it in the bed of the truck. We use it primarily with dry ice as a "freezer" for longer trips. I would suggest you check out www.thewirecutter.com for their article on coolers. I bought their recommended cooler and am very happy with it. I do not lock"
You WILL be at the Sept rally...right?
I'm already concerned about being considered a Snob since we own an Airstream.... I buy cheap coolers to defray the matter....
Seriously,... be careful when using dry ice in closed compartments such as autos, airplanes, small rooms etc., as you'll remember that dry ice is carbon-dioxide and as the ice melts will fill the space with CO2... and that gas "sinks"...and can kill, including yourself, pets, etc.
NO warning will be given... no headaches, no dizziness, no shortness of breath.... you'll simply pass out.... and die if not rescued.
Old 08-23-2017, 06:05 PM   #31
urnmor's Avatar
Berlin , Maryland
Thanks to all who provided input. I went ahead and purchased the Tundra 45 directly from Yeti. It was not all that expensive, although it was not cheap as coolers go, after they gave me a military discount, free transportation and some Yeti ice. Will use it on our trip to Cape Cod in two weeks.
Old 08-23-2017, 08:40 PM   #32
Cannonball's Avatar
2024 23' Flying Cloud
San Antonio , Texas
Will be at Sept Rally. I am going to become King. Your point about the offgassing is well taken, but the Yeti is always in the bed of the truck, never inside.
Cannonball is offline   Reply With Quote
Old 08-23-2017, 10:30 PM   #33
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
They are good once "cool" and opened sparsely
Get some dry ice... put in center vertical and horizontally... place a disposable bowl or container upside down or a wad of dry towels..
Close for 30 minutes.. but don't latch. There should be a gas cloud escaping... now, In goes the frozen items around the dry ice with a good space around... that's where the towel works well. Close and latch.
For fridge cold stuff, same technique.. but smaller chunk of dry ice when when items are cool remove remaining dry ice and fill with fresh ice.. as close h purchase as possible.. it melts fast.
Leave closed and plan your open time.. so prior arrangements work best. Once cold, it will keep if unmolested..
BTW, the dry ice can freeze the plastic and ruin any ice chest if it touches very long... also, don't touch the dry ice with bare hands .. be careful.
Peace and Blessings..
Channing
WBCCI# 30676
Old 08-24-2017, 12:12 AM   #34
Dana Point , California
Purchased a Yeti Tundra 75 and loved the way it performed. It held ice for six days in a bear box during the summer. The only significant complaint we have is that roto molded coolers are heavy and difficult to maneuver around a camp site or within the tow vehicle-Yeti was no exception. We recently purchased a cooler that works equally well with additional features that include multiple drain ports, bottle openers and, most importantly, wheels. The brand is KYSEK, online reviews and product evaluations have been very good. Purchased a 35 QT (BTW-Yeti's model numbers are not the same as their capacity) from Costco at a significantly lower price than the Yeti 45. We use a Yeti Hopper for drinks and the cooler for perishables. Both the Yeti and KYSEK work with dry ice as well.
Tralien is offline   Reply With Quote
Old 08-24-2017, 01:58 PM   #35
KK4YZ's Avatar
2020 28' Flying Cloud
2017 23' Flying Cloud
Hiawassee , Georgia
Hey, I think I need to get a Tundra for my Tundra
KK4YZ is offline   Reply With Quote
Old 08-24-2017, 02:28 PM   #36
Boxite's Avatar
2008 22' Safari
We're gonna call you "KingFish!"
Old 08-26-2017, 05:20 PM   #37
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
[QUOTE=Cannonball;1998388]Will be at Sept Rally. I am going to become King.
Careful.....your already sparse hair ain't gonna fit.... Kingfish
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a great dog.
bwoodtx is offline   Reply With Quote
Old 08-26-2017, 06:27 PM   #38
2017 25' Flying Cloud
Gold Country , California
Where does one buy dry ice?
NorCal Matt is offline   Reply With Quote
Old 08-26-2017, 06:38 PM   #39
Kevin245's Avatar
Yeti Coolers
We have a local grocery store that sells it. You can usually buy it from local welding, or welding gas suppliers.
William C. Swinney
Old 08-26-2017, 07:00 PM   #40
Post #11 here has some leads on dry ice.
[click on arrow in quote to go to the full post]
The threads mentioning "dry ice" often have interesting discussions about these "super coolers" --
https://www.google.com/search?q=dry+...=airforums.com
. . . with some folks using one cooler in the tow vehicle for dry ice storage of frozen food. In a recent thread for instance:
[click on arrow in quote to go there]
Engle coolers- Worst customer service Vagante Off Topic Forum 6 07-07-2017 08:19 PM
Swamp coolers for TT, RV? ldetsf Furnaces, Heaters, Fireplaces & Air Conditioning 10 12-21-2006 06:55 PM
Thermoelectric coolers Bumperstickr Refrigerators 11 11-07-2005 07:53 PM
Lock up your coolers- bears love beer! Moonshot Off Topic Forum 8 08-22-2004 01:22 PM
protecting the radiator and other coolers PeterH-350LE Airstream Motorhome Forums 18 04-28-2003 07:00 AM
