Go Back   Airstream Forums > Airstream Community Forums > Airstream Lifestyle > Stella's Kitchen
Old 03-15-2008, 08:00 PM   #1
Sugarfoot's Avatar
1958 22' Flying Cloud
1956 30' Sovereign of the Road
1963 16' Bambi
Southeastern Area , Tennessee
Volcano Stoves ~ anyone use one?
OK, it's y'all's fault . . . sorta.
I got to reading the Dutch Oven thread (a good thread, BTW) and went investigating Dutch ovens on the web when I ran across this little gem. It's called a Volcano Stove. Albeit, not the cheapest camp kitchen item on the market, it looks to be extremely versatile. It can be fired with wood, charcoal brickettes, or with an optional propane burner attachment. It can be used as a portable campfire similar to Campfire-in-a-Can, Yukon Legend, or Port-a-Fire. There is even a collapsable version for saving packing space.
Yep, had to have one, it's on it's way. But I'm curious to know if anyone in Airstream land has had experience with this stove. I found the best prices and free shipping at EndlessVariety.com.
Traveling With Elvis
life with a 1956 Sovereign of the Road
Sugarfoot is offline   Reply With Quote
Old 03-17-2008, 07:11 AM   #2
DJ Bassett's Avatar
1999 25' Safari
Sequim , Washington
That Dutch oven thread got me to pull out my ovens and get them ready for the season. I also saw that Volcano Stove. Lots of gadgets out there, but this one looks like it would be quite functional, especially where friends and campground operators would take exception to one digging a Dutch oven cook hole in their lawn.
I'll be looking for your reports on the new stove!
DJ
Credo quia Absurdum
DJ Bassett is offline   Reply With Quote
Old 03-19-2008, 03:56 PM   #3
Jimandrod's Avatar
2008 28' Safari SE
Placitas , New Mexico
Looks pretty interesting - I'm lookng forward to hearing more about it.
Jimandrod is offline   Reply With Quote
Old 03-19-2008, 04:52 PM   #4
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Home made variety
I saw something very similar last year. It was bigger and I just couldn't figure out what was so familiar about it, so I asked the owner where he'd gotten his neat fire basket/stove. Turned out he'd gone to the junkyard, taken the basket out of an old washer, drilled three holes through the bottom, and made legs out of old bolts, then used it as a fire basket for over four seasons. slap a grill on top and it was a cookstove. Said his was almost burned through by now so he would be looking at curbs and dumps for a replacement.
I like the look of this though, and I agree it's a decent thing to use when the campground objects to on-the-ground cooking. I plan to use my Weber baby-Q the same way. Hope it's sturdy enough.
Paula
Old 03-19-2008, 05:43 PM   #5
Excella CM's Avatar
1978 31' Excella 500
Venice , California
You can do some pretty efficient cooking on just a large size barbeque lighter-sort of a lower tech Volcano stove.
Excella CM is offline   Reply With Quote
Old 03-27-2008, 07:54 PM   #6
Sugarfoot's Avatar
1963 16' Bambi
It here . . .
The Volcano arrived. I bought the collapsible one and just from looking at it out of the box it's pretty cool and I'm looking forward to using it. The stove is 12.5 inches across so a 12" dutch oven ought to fit in there just perfectly above the coals. But I don't have a dutch oven (yet) and probably won't get a chance to try it before the Cherry Blossom Rally.
I'll get some pics up when I start experimenting.
Old 05-08-2008, 06:19 PM   #7
Sugarfoot's Avatar
1963 16' Bambi
Volcanic Adventures
Last week I finally got a chance to play with the Volcano when camping at Shellmound on Nickajack Lake. Yeah, right, try it at the Cherry Blossom Rally ~ what was I thinking?
Here's what you get in the box: The stove itself, a propane burner with hose, regulator, and attachments (if you ordered it), a small grate, and larger grate, and a heat diffuser that fits over the propane burner when used. The grates and difuser are heavy-duty weighing as much as the stove itself. All fits nicely into the zippered balistic nylon storage bag.
ID:	60125 Click image for larger version
When lifted by the bail handle, the stove opens easily and the legs extend. The top of the stove is 12.5 inches in diameter. You can compare the size against a fairly standard camp fire ring.
ID:	60127 Click image for larger version
I set up to cook with a charcoal fire. The small grate fits into the bottom of the stove and the large fits on top to act as your grill or cooking surface. I used a charcoal chiminey starter to make coals than placed the appropriate on the lower grate. There is a vent at the base that can be adjusted for more or less air flow.
ID:	60129 Click image for larger version
Stay tuned . . . .
Old 05-08-2008, 06:25 PM   #8
Sugarfoot's Avatar
1963 16' Bambi
Adventures in Cooking
OK, I’ve NEVER cooked with a Dutch oven before. I went to the Lodge factory in South Pittsburgh, TN, just a few miles from my campsite. Those Lodge camp ovens are HEAVY. So I’ve wimped out for now with a GSI anodized aluminum #12 Dutch oven. I would really like to have a well-used vintage #12 Griswold or such, but I’m still searching. I swear the old ones are lighter weight than the newer Lodge versions.
Remove the upper grate and a 12 inch Dutch oven fits perfectly into the Volcano. So I mixed a quick test batch of biscuits, inverted a pie pan in the oven, preheated the oven, and placed them on foil in it. In about 20 minutes this is what I had. Not the best batch I’ve ever made, but certainly not the worst. I need more Dutch oven practice ~ it really is an art. I have since been told that several Mason jar canning rings in the bottom make the best trivet ever for Dutch ovens.
ID:	60132 Click image for larger version
Then I fired up more coals and tried a rice/vegetable dish in my trusty #8 Griswold skillet. It turned out perfectly.
ID:	60134 Click image for larger version
Bottom line: So far I love it, glad I bought it. If you use Dutch ovens, this is your answer when you can’t dig a pit.
I’ll try the propane next time. It stands to reason temperature control would be similar to any other gas stove and easier to manage. Eventually I’ll try using the Volcano as a free-standing wood campfire pit, but it will require appropriately sized wood.
Old 05-08-2008, 07:54 PM   #9
2005 30' Classic
Images: 12
I have one. Very nice to have when you are trying to use a 12 inch dutch oven when it's windy. You don't spend all your time getting a new batch of coals going to keep the heat, and it doesn't require as many brickets to cook with as it traps the heat and keeps the wind from cooling the pot.
It's very easy to setup and collapse.
My only beef with it is it's made by Camp Chef for Camp Chef dutch ovens: Lodge and Cabela's 12 inch dutch ovens don't fit like they should.
GetOutDoors is offline   Reply With Quote
Old 05-08-2008, 08:32 PM   #10
We can tow it!
tin sista's Avatar
1996 28' Excella
Where the water tastes like wine , Michigan
Images: 82
Thumbs up Great thread folks!!
Sweet!! we tried using our dutch oven this spring when it was super windy, and being total dutch oven newbies even with a wind shield and oven thermometer, it didn't work so great the temps were too hard to control for us (recognizing our newbie status here) so I'm thinking this volcano thing looks good!! thanks for the great thread and photos sugarfoot!!
Steph in MI Air# 6996-
I Hockeytown USA!!
tin sista is offline   Reply With Quote
Old 05-08-2008, 10:12 PM   #11
DJ Bassett's Avatar
1999 25' Safari
Sequim , Washington
Thanks for the report and the fine photos! Looking forward to more of both.
DJ
Credo quia Absurdum
Old 05-29-2008, 07:31 PM   #12
Sugarfoot's Avatar
1963 16' Bambi
Now we're cooking with gas!
No photos right now, but I've tried the propane attachment. It assembles quickly and easily. Regulating cooking temps are naturally easier and more precise with the propane. Cooking is basically the same as your gas stove. We didn't do anything fancy this time, only popcorn in the dutch oven which we ate in short order.
It has an air intake mechanism below the burner that can be adjusted with a thumb screw. Interestingly, if you close it completely to air and it becomes a tall inefficient but fuel-rich flame just like the propane portable campfires. Kinda gives a whole new meaning to the name "Volcano" stove. Eventually I'm going to try some ceramic logs and push the multitasking on this thing a little further.
Old 10-19-2009, 10:43 AM   #13
Rather not , Utah
A new link
I was reading your post and followed the link you gave but the page it went to said it could "not load the infomation requested." So, I found the people who make the Volcano. They're here.
Griller is offline   Reply With Quote
Old 10-19-2009, 11:00 AM   #14
Kevin245's Avatar
This Thread Makes Me Hungry
Ummmm.....I'm thinking that some of Dacia's "Bread Pudding" sure would be good about now.
William C. Swinney
Old 10-21-2009, 07:56 AM   #15
Sugarfoot's Avatar
1963 16' Bambi
Y'all and that "bread pudding". I think it's really the Jack Daniels sauce that you want. You just have to come to the Can Opener to have a taste.
Old 10-21-2009, 09:22 AM   #16
Kevin245's Avatar
Sauce....Why I never considered such a thing...
Well maybe just little bit...
Ohhh who am I kidding...
William C. Swinney
Old 10-21-2009, 09:24 AM   #17
Salt Lake City , Utah
Hello All...
I have been using Volcano Stoves for many years now and wouldn't part with my odd collection. Although I don't have the propane attachment, I know what these stoves can do. They sure put out a lot of heat with a minimal amount of fuel.
A few years back, the word here in Utah was that they were going out of business, which was hard for me to believe. I still see them selling locally and it doesn't surprise me because they have such a good product. Some of the best bbq's I ever had were grilled on Volcano Stoves. I've even seen people use them indoors at large events, but wouldn't recommend that inside an rv or camper.
You won't be disappointed once you get the hang of cooking on these type of stoves!
That's my five cents worth...
agentsteel is offline   Reply With Quote
Old 10-21-2009, 10:10 AM   #18
Mexray's Avatar
1978 28' Ambassador
Morada , California
Looks a lot like me Cobb SS cooker, which I read about here on Airforums...
Cobb Portable Grill from Cobb America - The Ultimate Cobb portable grill, BBQ, Smoker and Cooker.
Except the Cobb won't accept a dutch oven...
I love the Cobb for it's easy and efficient operation - most meals use only about 8-10 briquets...
I cooked a whole chicken on the Cobb using 10 briquets, and added some wine/water into the 'moat' in the bottom for added moisture, and the chicken was great after about one hour...the 'dome' on the Cobb gives the dutch oven effect...
The whole rig is SS, so no rust, and when home, you can toss it all in the dish washer for a good cleaning...
I actually bought ours online from Target for the best price I found for a grill with some options...
The Volcano looks like a great oven as well...
Ray & Pat; Morada, CA
Old 10-21-2009, 11:23 AM   #19
Mexray's Avatar
1978 28' Ambassador
Morada , California
If the Cobb is of interest, I found another site with an extensive review of the grill...
Cobb BBQ
The current model has SS mesh around the bottom that stays cool while in use - not the black material shown in the review...
Old 05-22-2010, 09:38 AM   #20
2004 28' International CCD
Maple Plain , Minnesota
Volcano Stoves
Just bought one myself and have only used it once so far. Have the propane attachment and the fire-resistant cloth dome (made from similar cloth that forest-fire fighters carry as a safety blanket). This should allow me to eliminate top coals on the dutch oven and/or use the system in snotty weather.
The dome was in the $30 range, pricey but seemed to make sense. I'm going to make some slip-over tubular leg extenders to raise the stove up off the ground for easier tending
I'll send photos soon as I use it again. Maybe early next week.
tomp1937 is offline   Reply With Quote
