Old 11-01-2016, 07:20 PM   #1
1975 31' Sovereign
Crosby , Texas
Induction Cooking
Thinking of taking out old stove top gas unit and exchanging for induction stove unit. Has anyone done this? Problems? Two burner vs one burner? Particular brand?
dghaas is offline   Reply With Quote
Old 11-01-2016, 08:29 PM   #2
Southwestern , Ohio
Aside from the obvious difference that you can use the gas stove when you are not connected to electric power, don't see any reason you couldn't do this.
Do you know what kind of electric current an induction cooktop will draw? Presumably your trailer has the 120 Volt - 30 Amp electric service which was universal in the 70s and it may not be enough to run the induction cooktop, particularly if you want to run the air conditioner at the same time.
Nuvite-F is offline   Reply With Quote
Old 11-02-2016, 05:23 AM   #3
Long Island , New York
Many residential induction cooktops require 240 volts AC. Maybe smaller ones are OK with 120 volts? Pretty heavy amperage ratings though IMO.
OTRA15 is online now   Reply With Quote
Old 11-02-2016, 06:14 AM   #4
urnmor's Avatar
2012 25' Flying Cloud
Berlin , Maryland
I replaced our electric stove last year with a Samsung Induction stove an love it. Easy to clean and the surrounding area by the burners do not get hot, however, I would not replace my AS gas burner with a one top induction range. Instead what I did was buy a portable one that runs off of 120. IMO this gives you the best of both worlds: an extra burner and the option to cook inside or outside on it. There are many portable induction tops on the market and they run the gamut in price. I bought one from Vollvath and use it both at home and when camping.
Anyway that is what
urnmor is offline   Reply With Quote
Old 11-02-2016, 06:48 AM   #5
Great suggestion! Do you know how many amps it draws?
We went with a one-burner Iwatani butane stainless portable unit, rated at 15,000 BTU as I recall, which also works for boondocking without electric. It lives in the tow vehicle near the campground picnic table, along with coolers and 12-volt mini-oven and tea kettle. In effect a small kitchenette next to the AS, which is handy for early risers.
The small butane fuel cans are sold in most campground stores, as they also power other devices, especially for tent campers.
Old 11-02-2016, 08:17 AM   #6
urnmor's Avatar
Berlin , Maryland
Sorry I don't know however I have never had a problem using it at a campsite that had electricity. I am not sure if I used it when running our generators. I doubt it would be a problem as it is 110 especially if one is not running HP or AC
Old 11-02-2016, 08:55 AM   #7
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , NC Highlands County, FL
The problem with using any added electric appliance is there is not enough available power.
120 volts
x 30 amp (electric service)
3,600 watts (total wattage)
3,600 watts
-1,800 watts (for a two burner induction cook top)
1,800 watts (not enough for air conditioner and converter at the same time)
add edit:
when a campground is full sometimes voltage drops, so there is even less available watts when this happens
Alan
Old 11-02-2016, 01:22 PM   #8
2019 27' Globetrotter
Salem , Oregon
I have a portable induction cooktop that is small use 1800 watts. Works great and when I have electric it is faster than gas. I can also use an extension cord for use on picnic table.
Info for this unit which Fagor Induction Pro cooktop can be found here.
www.fagoramerica.com
Dave
NoResults is offline   Reply With Quote
Old 11-02-2016, 01:33 PM   #9
Nice looking!
http://www.fagoramerica.com/applianc...on_cooktop_pro
1800 watts / 120 volts means 15 amps, right? For the full-on highest setting, I guess. Well within the capacity of most campgrounds but you would want to use a #12 AWG extension cord. Is our outside duplex outlet rated for 15 amps? Not sure, but this burner and a toaster at the same time might trip the breaker.
Thanks for the link.
Peter
Old 11-02-2016, 08:34 PM   #10
Gearheart's Avatar
1973 Argosy 24
Kitchener , Ontario
Originally Posted by OTRA15 View Post
Nice looking!
Peter
Yep. 1800 watts uses up the capacity of the breaker. Don't be making toast or coffee or drying your hair at the same time.
Gearheart is offline   Reply With Quote
Induction cooktop? shermantic Electrical - Systems, Generators, Batteries & Solar 9 12-28-2015 12:27 PM
Portable Induction Cooktop urnmor Stella's Kitchen 17 01-11-2015 11:47 AM
Induction Cooktop BAB Stoves, Ovens & Microwaves 22 01-13-2014 10:30 PM
Ceramic/Induction Cooker Top/Hob degs123 Stoves, Ovens & Microwaves 2 04-25-2010 03:15 PM
Cooking Pots John Stella's Kitchen 51 03-18-2008 10:57 PM
