Originally Posted by DaveG
OP said, ".....to work with the quick disconnect lp gas connector on our AS?"
The problem will be with pressure. The AS quick connection is already regulated.
Yes??
So why is what I showed wrong?
That blue round thing is NOT a regulator, it's an adapter. The hose has the quick connect on the RV end, and Torjic sez:
"The Torjikョ QUICK必EY makes connecting a low-pressure propane appliance to your RV's low-pressure female quick-connect easy. Simply remove the existing manufacturer's hose and regulator from the appliance and replace it with the QUICK必EY. Pair the QUICK必EY with the proper low-pressure male x female quick-connect hose like this one and you are set!"
Cuisinart's web site was no help. I found this on Torjic's site. It's the only thing that was a possible match.
The grill shown in the image was the Cuisinart CGG-180 as the OP indicated.
Of course, I may be missing the point since I haven't actually used MY low pressure port, but I assumed it's post regulator.
