Go Back   Airstream Forums > Airstream Community Forums > Airstream Lifestyle > Stella's Kitchen
Old 06-13-2007, 05:10 PM   #21
Images: 59
All this talk about beans is giving me gas. Any good quality Arabica bean works for me.
My thing is the water. Here in Minnesota we have very good water quality. I use only untreated water directly from the Prairie Du Chien aquifer. No chlorates, thank you.
Old 06-13-2007, 05:48 PM   #22
wheel interested's Avatar
2007 23' International CCD
Lapeer , Michigan
Nothing fancy, boil water in the teakettle, pour it into the thermos/travel cup and pop in a Folger's coffee single. Same routine I use for starting the morning from a rest stop, then hunt for a doughnut.
Caroljb
photography
wheel interested is offline   Reply With Quote
Old 06-13-2007, 05:56 PM   #23
Wabbiteer's Avatar
Jupiter , Florida
Saint Paul, MN tap water comes out at 8.4pH and is so alkaline an alka-seltzer nearly levitates above the water with a whirring noise, and dissolves in about twenty seconds... and when summer algae blooms in the shallow lakes they use for summer supplement it smells like a fishing pond straight from the tap... Its a buck a gallon for decent water in this neck of the woods...
The days are short and the night is long and the stars go tumbling by.. . ~Airstream~
Old 06-13-2007, 06:20 PM   #24
Images: 59
Originally Posted by Wabbiteer
Saint Paul, MN tap water comes out at 8.4pH and is so alkaline an alka-seltzer nearly levitates . . .
The last lab report was even higher than 8.4pH. Minneapolis and St Paul both use the Mississippi River and surface water.
Water from the Prairie Du Chein aquifer may be hard, but it doesn't stink in the summer.
Old 06-13-2007, 06:36 PM   #25
1960 22' Safari
in the wilderness , The great Mojave Desert
Originally Posted by ScottW
I use the propane stove to heat water and brew the coffee in a french press. Can also heat water on one of our coleman white gas stoves, outside.
Don't make more than we can drink in one sitting, so keeping it hot isn't a problem.
^ Thats what we do too.
I'd rather be boon docking in the desert.
WBCCI 3344 FCU
AIR# 13896
CA 4
Yes, we have courtesy parking for you. About an hour North of Los Angeles.
Goin camping is offline   Reply With Quote
Old 06-13-2007, 10:08 PM   #26
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, we have a pot just like the one in post #3; I think it is a Coleman. And we only use bottled water. Oh yeah, so far we haven't even used it yet, we have been useing the 110 volt coffee maker. We have not been without 110 power since we bought the stove top model.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
Old 06-13-2007, 10:47 PM   #27
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Wow I'm psyched
I'm a coffeeholic and the lexan grinder is a GREAT idea. The two best things for coffee are: Filtered water and Fresh beans freshly ground.
Even Starbucks admits that coffee is 99.7% water so while I do drink tap water without reserve, when traveling especially I use bottled for coffee. Let's face it, water tastes different in different areas, and what you carry in your fresh water tank can go a bit off too over time.
Paula
Old 06-14-2007, 07:10 AM   #28
Aria's Avatar
1967 20' Globetrotter
Sauquoit , New York
Interesting and informative...that's the Forum style. With our coffee we usually want some toast. How do you prepare toast? Aria
Aria is offline   Reply With Quote
Old 06-14-2007, 08:23 AM   #29
Sugarfoot's Avatar
1958 22' Flying Cloud
1956 30' Sovereign of the Road
1963 16' Bambi
Southeastern Area , Tennessee
Originally Posted by Mel
We also use a Melitta into a thermal carafe. I think the cone method is much easier to clean than a french press. (For us, the easier the better when we're camping!)
Me too, boondocking or not. If I'm not in a hurry, sometimes I use the french press for full flavor. But I insist on fresh ground. I have a small old-fashioned Armin Trosser coffee grinder powered by elbow grease.
Traveling With Elvis
life with a 1956 Sovereign of the Road
Sugarfoot is offline   Reply With Quote
Old 06-14-2007, 10:25 AM   #30
jzelle's Avatar
2006 28' Safari SE
Halifax , Nova Scotia, CANADA
French press is the way to go. It makes such good coffee that we have tossed out the electric drip percolator.
Our french press is a 33 ounce insulated stainless steel model that keeps coffee hot for hours.
John
If you need to turn on your air conditioner,you've gone too far south!
2006 Safari SE 28W/LS,
2006 Silverado 2500HD/LT EC SB 4x4 Duramax/Allison,
Hensley Arrow , Honda EU2000i (propane),
160W Solar, 400W sinewave inverter,
3-stage smart charger, Xantrex battery monitor,
Sirius satelite radio
jzelle is offline   Reply With Quote
Old 06-14-2007, 10:50 AM   #31
Aria's Avatar
Sauquoit , New York
Sugarfoot, We usually grind our coffee beans at home just before we leave.
Where did you purchase Armin Trosser Coffee Grinder? Thanks Aria
Old 06-14-2007, 11:04 AM   #32
Silver Threads's Avatar
2000 25' Excella
Kingston , Tennessee
Boondock coffee maker
We actually bought this at walmart for 38.00 before we got the Stream when we had planned on going tent camping. We actually tried it out on a small coleman stove and it worked great. Problem i guess would be storage. Just an idea. Then again, you should be able to sit it on top of the gas stove when not boondocking. Too bad we gave it all away, darn! Its called a Coleman Camp Coffee Maker.
John & Tammy Adams
Silver Threads Custom RV Curtains
2000 Airstream Excella | AIR 15902
https://www.etsy.com/your/listings
Silver Threads is offline   Reply With Quote
Old 06-14-2007, 11:52 AM   #33
DJ Bassett's Avatar
1999 25' Safari
Sequim , Washington
Make it Fresh and Don't Keep it Hot
[QUOTE=balrgn]So how do you make Coffee and keep it hot while your boondocking?
Coffee Brewing Methods
Right up there with bacon, whole-hog sausage, and Free-Range RedNeck eggs...Coffee! Make it fresh and when it cools...do it again.
Some very fine approaches listed! And, yes, the water and the beans are the foundation.
My favorite 5 ways of brewing coffee...
5. Sniffing out the best smelling A/S in the morning. Be sure to bring trade goods, your own mug and a very helpless-looking demeanor.
4. Boil water in the washed (optional) bean can from last night, remove from the fire, drop in 1/2 crushed eggshell and 1 handful of coarse ground coffee. Let sit for 3 minutes, add one small glug of cold water to settle the grounds, bite the end off and light the Romeo y Julieta Pyramides vintage #6 cigar and get ready for the launch. Amenities of this method: lead and other metals from the can, ashes from the fire, grounds in your teeth, 2nd & 3rd degree burns on your fingers from picking up the can, total privacy and undisturbed seclusion for masculine, morning macho meditation (cigar smoke repels most upright-walking organisms and Ruby, my JRT.)
3. Stove top espresso in Stainless Steel maker
2. Toddy Cold Water Extract Coffee Concentrate. Make it before the trip. Concentrate yield is about 1 quart per pound of coffee. I use this one after a week of #s 4 & 3. This method is a low acid brew that has the added advantage of being a very high quality instant. Just pour 1 shot of the concentrate into a preheated mug. Add boiling water and you are there. To prepare, buy 1 lb. of very coarsely ground coffee (caf or decaf or mix of both). Place felt filter and plug into bottom of brew decanter. Add coffee. Add Reverse-Osmosis (RO) water and let sit overnight (12-16 hours). Pull plug and set onto supplied glass receiver decanter. Allow concentrate to drain for a couple of hours. Refrigerate concentrate till ready to use. I use Grolsch Beer bottles for taking the concentrate camping. They have a wire-bail ceramic stopper with a rubber gasket and are indestructible.
1. Chem-X drip coffee maker. Just another drip method using delicate and artful glass (not plastic) brewer. Have had this one for 25 years or more and it miraculously has not exploded.
DJ
ID:	39221   Click image for larger version
Credo quia Absurdum
DJ Bassett is offline   Reply With Quote
Old 06-14-2007, 01:15 PM   #34
Aria's Avatar
Sauquoit , New York
We have a Chem-X like the one on the right in your photo. Do you leave this on the propane stove?
Old 06-14-2007, 02:19 PM   #35
Sugarfoot's Avatar
1963 16' Bambi
I got it on eBay for 9 bucks.
Old 06-14-2007, 10:18 PM   #36
DJ Bassett's Avatar
1999 25' Safari
Sequim , Washington
My Chem-X has never been on the stove. I boil the water in a whistling kettle.
Credo quia Absurdum
Old 06-14-2007, 11:14 PM   #37
VE7REZ / W6
hamradio's Avatar
Desert Hot Springs , California
Send a message via AIM to hamradio
I roast my green beans in a hot air popcorn popper till they are a nice dark brown .... let it rest a day ... ... grind it on a burr plate grinder and then measure 6 grams per cup when I brew it in a drip cone filter into a hot pot (like you see in any good coffee shop). It stays warm for a few hours if we don't drink it all right away. When you drink real fresh roasted coffee its hard to drink it any other way!
hamradio is offline   Reply With Quote
Old 06-15-2007, 09:28 AM   #38
DJ Bassett's Avatar
1999 25' Safari
Sequim , Washington
Green Beans
Now that gets my attention.
Where do you get your green beans and how do you determine the quality?
DJ
Credo quia Absurdum
Old 06-15-2007, 09:52 AM   #39
DJ Bassett's Avatar
1999 25' Safari
Sequim , Washington
Alternative Coffee Heating Methods
Originally Posted by Excella CM
I simply stck the antenna for my handheld CB (linear amp'd, of course) and press talk. The RF(maybe it's BS, I forget) does the rest
Professor Excella,
I seem to have a dim memory on something else like this.
Somewhere in the Pacific, Freeman Dyson lit a cigarette off of a nuclear test blast.
Seems he calculated the wavelength of the particular light from the blast, fashioned a sort of dish and placed an alligator clip at the focal point of the dish and inserted the cigarette.
When he turned around after the blast, the cigarette was lit. (Curve of Binding Energy by John McPhee)
Is your vice-grip tool from Hansford Nuclear Reservation? Roast the bean when crushing?
Guess you wouldn't need a flashlight very early in the morning or when enjoying coffee after dinner.
DJ
Credo quia Absurdum
Old 06-15-2007, 09:56 AM   #40
Sean Michael's Avatar
Birmingham , Alabama
I'm a coffee enthusiast (use a Rancilio Silvia/Rocky combo at home), and am looking closely at the Bunn "My Cafe" system.
It makes one cup at a time, as needed, using pods of just about any size. Plus, there's no carafe -- so cleanup will be a breeze.
Anyone use a pod system?
Sean Michael is offline   Reply With Quote
The Official Coffee Of Airstream moosetags Airstream "In the News" 40 03-17-2009 06:26 AM
Coffee Makers Tarheel General Appliance Topics 7 12-01-2004 09:33 PM
Coffee to go Turtle On The Road... 3 05-28-2004 11:00 PM
Newsweek Article On Vintage AS montanaandy Our Community 14 07-31-2003 02:15 PM
