05-07-2011, 08:20 AM
#161
2011 25' FB Flying Cloud
Peculiar
, Missouri
Gringo, putting some instant under your tongue, or in your cheek is cleaner, easier, faster, and no tracks Besides, trying to keep your eyes open and focus to start the needle can be a challenge at times. Our old pots are reliable and can be multi tasked, but best of all is the aroma. The smell of fresh brewing coffee just seems to get the day started right.
Now if I can just convince my wife that it's ok for the inside of the cup to be a little brown we'll be ok
#162
1967 22' Safari
1960 Caravel
Edmonds
Originally Posted by blmitch5
Here is my solution! I got it as a Birthday present and LOVE it!
Oh common!! That's just cheating...
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
05-07-2011, 08:23 AM
#163
Peculiar
, Missouri
hmmm Ahab, I don't know but as I enjoy my second cup, I'll put it on my list of questions to ask my doc next time I see him, though I guess he'll tell me that breathing can kill me as well...enjoy
05-07-2011, 08:24 AM
#164
Peculiar
, Missouri
Brad, nice pot and it goes with you interior Happy B-Day...
05-07-2011, 08:32 AM
#165
Unfiltered coffee might raise your cholesterol, but it also reduces your risk of cancer. So what's worse?
05-07-2011, 08:50 AM
#166
Maniacal Engineer
Lopez Island
We use a Nissan stainless steel, vacuum insulated French press in the Tin Pickle; simple and easy. A drip coffee filter would be faster to clean, but this is doesn't require any attention after filling once.
- Bart
05-07-2011, 09:13 AM
#167
2006 19' International CCD
Olathe
, Kansas
Originally Posted by barts
I've got one of those as well. We use it when boondocking. I like my coffee.
05-07-2011, 09:20 AM
#168
Olathe
, Kansas
I do it the hard way as well. Nissan press and my favorite cup is from an Italian coffee pot (a 12 cup) that only makes 2 1/2 American cups.
05-15-2011, 11:35 AM
#169
Airstreamer
2012 27' FB International
Bellevue
I go to Goodwill a lot and found these mugs which are made of enamelware (sp?) and they are from Pottery Barn. I was so surprised to find out how these mugs keep hot beverages, well, so hot and for such a long time. Plus they are lightweight and very very durable. This is how we make our coffee:
{blog} ★ Just 5 More Minutes to Enjoy Non-Stop Outdoor Adventures and Culinary Discoveries in the Northwest with our Airstream ★Blogger for GoRVing.com
05-15-2011, 12:43 PM
#170
1978 28' Ambassador
Morada
This is what works for me.... It's also great for distilling small batches of sour-mash to fill up my mason jar servers...
Ray & Pat; Morada, CA
05-15-2011, 01:24 PM
#171
2010 25' FB Flying Cloud
Davenport
, Iowa
I thought this was camping. I make campfire coffee over the camp fire.
I have a large enamel coffee pot , NO insides. I use 2 gallons of water and bring to a boil. next add 1 lb of coffee and add it SLOWLY as not to boil over. next take one egg and break it shell and all to the coffee. Put the lid on and boil for another 10 minutes. This will last on the fire all day or until empty. Serves 8 - 10 people.
I leave the pot and ingredients out and the one who empties or up first in the AM starts the next pot.
09-25-2011, 01:32 PM
#172
2007 30' Classic S/O
Somewhere
, South Carolina
Camp Coffee
I think Airtandem and I are on the same page on this one.
This pic is staged, I do use this older Coleman on the weekends to perk the small Coleman SS perk pot and it does a fine job, actually the best working perk pot I have owned others were aluminum.
But if we have a get together then THE BIG POT comes out and goes over the open fire. It is a Mirro 11 qt ( 2 3/4 gallon) boiler and it is a doozie. Get it boiling, reduce heat, add grounds, slow rolling boil, let it rest to settle and line em up. I don't think I would even waste my time trying this one on the Coleman.
To put a size with the pot, it is about 17" tall to the bail handle and about 11 1/4" wide at the bottom.
As far as using pots that you want to keep clean on an open fire, I just rub liquid soap on the outside of the pot/pan up as high on the pot as I think is necessary, but always below the rim. Soap don't taste so good. Clean up is really simple, rinse, scrub as needed with steel wool or Scotch Brite and minimum elbow grease.
09-25-2011, 01:55 PM
#173
2019 27' Flying Cloud
Albuquerque
, New Mexico
Here's My Coffee Maker WHen We Boondock
We had the best coffee at the White Sands Rally!
Ken L 2019 Flying Cloud 27FB
2020 GMC Sierra 1500 Crew Cab 6.2L Max Tow Four Corners Unit WBCCI #5783
09-25-2011, 02:49 PM
#174
colorado springs
If wer'e going to be on shore power, we bring our home unit, a 58mm La Pavoni Pro. It has a manual lever to press the water through the grounds, so with some practice, you can compensate for changes in humidity, altitude, grind, and oil in the beans. OK the real reason is, it looks cool, makes a mean espresso, and has a powerfull steamer.
For boondocking I'm trying out 2 different setups. The first is a lexan camp espresso maker I got from the clearance table at REI. It has a normal grouphead setup for the ground and a chamber for hot water that seals tight, and a hand pump to preasurize the water chamber to run the water through the grounds. I couple that with and stove-top steamer for making mochas, latte's and hot chocolates for the kids. The other rig I've been tinkering with is a Bellman CX-25 (theyve had a dozen different names over the last few decades, but thats what theyre being sold as nowadays) I still need some more practice with that one however because results have been spotty. If its just coffee for me, Ill cheat and use those Starbucks Via packets. Just need hot water, no mess, little fuss and nothing to throw away except for the little pouch, which by the way, makes a handy spoon to stir it with
Champagne wishes and Caviar dreams!
Budwieser budget.
09-25-2011, 03:24 PM
#175
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Keep it simple...
09-25-2011, 03:31 PM
#176
Albuquerque
, New Mexico
Had One th the Sixties...
Originally Posted by ROBERT CROSS
Keep it simple...
...and forgot all about it. I loved it. Can you still buy these?
09-25-2011, 04:30 PM
#177
Overland Adventurer
1998 19' Bambi
Denver
Cafe
I use the entire garage of my Panamerica for mine.......
09-25-2011, 05:04 PM
#178
1967 22' Safari
1960 Caravel
Edmonds
Yep! Chemex
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
09-25-2011, 06:16 PM
#179
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
A little history....It just seems right with the Airstream.
"How's the coffee???"
"excellent"
10-02-2011, 05:43 PM
#180
Winder
, Georgia
Trader Joe's coffee is awesome! Big fan of the house blend....
