Originally Posted by Halford1
I like the hood over the stove. did you have any trouble with hood with its power loss? Has it been improved?
I just bought Tekonsha RF to add to the FC soon.
The bunk was gonna be mainly the storage for our clothes and if needed, a guest.
Looking forward to it!
No problem with the range hood. Runs as advertised. The bunk is far better as a storage shelf in my opinion. Use the plastic bins under the bed for storage.
I recently had warranty work performed on the accordion bathroom door. It was delaminating a bit with all the heat our here in SoCal.
The Dometic Frig is a concern only when very hot outside. A few posts suggest placing additional exhausts fans outside to pull air out of compartment. I did that and it is a significant upgrade. Along with a battery operated Valterra or equivalent fan inside to blow air around.
I too have the RF Prodigy. Works as advertised. Good signal strength from trailer to hand control. Pairing is a challenge but once successful it performs well.
And 60 lbs of propane lasts a very long time! Furnace and Water Heater are quite efficient.
