Old 01-07-2021, 08:06 PM   #1
2021 25' Flying Cloud
Bentonville , Arkansas
Some Advice
Hi,
We are buying our first Airstream with my wife and have been offered multiple options to include with the purchase. I wanted to ask someone with more experience if those options are really needed it.
6 Years but/bump coverage
Cilajet Ceramic coating
Tire and Wheel protection.
Any guidance will be very much appreciated
Javy
Delgaditos is offline   Reply With Quote
Old 01-07-2021, 08:21 PM   #2
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Greetings from the Florida Panhandle
We have purchased two new 25FB's since 2005. I would not buy any of those options.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
Old 01-07-2021, 08:25 PM   #3
Brian
Thank you so much for your prompt response.
Old 01-07-2021, 08:31 PM   #4
2017 25' Flying Cloud
Lakewood , Illinois
Originally Posted by Delgaditos View Post
Hi,
Javy
There is so much to upgrade once you own it those options would be # 332, 333, 334 on a long list.
nedmoto is offline   Reply With Quote
Old 01-07-2021, 08:42 PM   #5
2018 25' International
Slidell , Louisiana
There are several threads on each of those.
As Brian indicated the verdict is none of those pay out.
The warrantee is overpriced, you can get one after the sale much cheaper, and if you're handy you should get used to doing the repairs yourself, mostly so the trailer is not in the shop so long and for many of us the shop is so far away.
The coating is effective, but there are less expensive options to keep the trailer nice.
There are easy UV tire protection treatments for $10 from the auto store. If they could guarantee the wheels won't develop filiform corrosion under the clear coat, maybe that is worth it but it won't stop it so....
Old 01-07-2021, 08:51 PM   #6
jeffmc306's Avatar
2019 27' Globetrotter
McHenry , Illinois
I'm with Brian on this one.
Delgaditos, I'm with Brian on this as well. Your new Airstream comes with a 3 year warranty so that covers everything inside.
Take some of that money and buy a good tire pressure monitor like the TST system. I went to the local Discount Tire near us and had them replace the Airstream rubber valve stems with Dill metal ones. The manager looked at our tires and said since they were almost new he would offer their Certificate for Repair, Refund or Replacement. So, I now have road hazard coverage with free replacement for any damage for a few dollars more than the cost to install the new stems and balance all four wheels and tires.
Check the forums for tips on waxing your Airstream. I use the Airstream recommended Walbernize . I like to wash and wax my trailer in the spring and fall. By doing it yourself you'll get familiar with the exterior of your unit and check for anything loose or damaged. Same goes for your tow vehicle
Good luck with your new Airstream and welcome to the community and forums!
Jeff
ID:	386455   Click image for larger version
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
jeffmc306 is offline   Reply With Quote
Old 01-07-2021, 09:20 PM   #7
I know it is overwhelming
Old 01-07-2021, 09:21 PM   #8
Thank you very helpful.
Old 01-07-2021, 09:23 PM   #9
Jeff
We are super excited, thank you for your great advice....
Old 01-08-2021, 07:51 AM   #10
"Cloudsplitter"
Welcome Aboard👍
Take the $$$$ for all those "must have" options, put it away and save it for all the things you feel you don't need now, but find you WILL need later.
Sweet Streams 👍
Old 01-08-2021, 08:26 AM   #11
Palm Springs , California
Jeff
What size AS is that Jeff?
Txforetravel is offline   Reply With Quote
Old 01-09-2021, 04:34 PM   #12
jeffmc306's Avatar
McHenry , Illinois
Txforetravel, we have a 27’ Globetrotter. I see you’re currently looking. What Airstream model / size are you thinking about?
-Jeff
2018 FC23FB
WBCCI# 10258
RETIRED!
Old 01-09-2021, 05:56 PM   #13
-Jeff
Picking up a new 2021 27’ FBQ Globetrotter on Friday.
Old 01-09-2021, 08:48 PM   #14
Sag Harbor , New York
Javy
Welcome to the forum!
FYI on the main desktop version of this site [not the App], the blue search box above works great. It is powered by Google, and automatically adds the search term "site:airforums.com" to look through all the posts here.
For instance, a search for "Cilajet" yields these results:
https://www.google.com/search?ei=bXn...4dUDCAw&uact=5
"Walbernize" -- https://www.google.com/search?q=Walb...=airforums.com
. . . and so forth. The search engines finds lots of info which is often spread all over the place here.
You could also add that search term to any search engine, I would guess. In the old days you might have had to add this:
"AND site:airforums.com"
Good luck,
Some of my 12volt is working but some not. b1gflip Electrical - Systems, Generators, Batteries & Solar 4 03-13-2018 07:35 AM
Some GFI protected circuits work and some don't. Two Peas On The Road... 21 02-02-2016 04:27 AM
Some progress and Some Questions SCopp 1970 - 1973 Overlander 3 02-03-2013 07:25 AM
Some call it a hobby, some, an addiction balrgn 1974 - 1977 Overlander 45 08-18-2008 07:32 PM
Some Advice Please Paulus Magnus Our Community 23 06-18-2003 11:27 AM
