You are looking to protect your 2016 19' International? (Forum members using the cellphone app don't see your profile - it's handy to include it in a post like this for them.)
I'd suggest looking under your A-S to see what you really need to protect. The tanks are insulated and heated by the furnace. Do you want something to protect it in storage, while not running the furnace? Will shore power be used to run this heat source? Proper winterization is a good alternative for an unoccupied trailer.
There are stick on tank heaters, but they wouldn't do much sitting on the outside of the insulation. There is heat trace available for the exposed drain valves, which works best when you fasten some kind of durable jacket over the top.
Some folks install skirting when they will be in one place for a long time in harsh conditions.
Give us a better idea of your intentions, and you will get some useful feedback! Or search the forum for some of the key words above.
Happy Camping!
-Don
(That man in that tiny can)
(Same man, Bigger can)
