10-27-2020, 05:53 PM
2021 20' Caravel
Arlington
plugging in at home
Okay, I've looked at the forum a lot the past couple of weeks, and posted a couple of times, receiving lots of good information. Thank you to DennisL and several other people who have already helped me with pre delivery questions.
But as a total newbie, I have a charging question. BTW, we just took delivery of our AS today, a beautiful 2021 Caravel FB20. Couldn't be more excited.
During our walk through, I asked the tech about charging when not in use.
I'll be locating a power pole beside our parking area, so I asked him if I should just plug it in once a month or so to keep the batteries topped off.
His response was, these AGM batteries won't over charge, so just keep it plugged in all the time.
I certainly tend to believe he knows his stuff, but if I'm not mistaken, this information is counter to what I've read on this forum.
So what's the deal, all you engineering types ? Is there consensus on this ?
10-27-2020, 06:00 PM
2002 25' Safari
Dewey
With a multi stage converter, you should have no problem leaving it plugged in all the time. My trailer has a Progressive Dynamics and a pair of 6 volt AGMs and stays plugged it when we are home. You have a new Airstream and your converter should be fine.
Richard
10-27-2020, 06:08 PM
2004 30' Classic Slideout
Fenton
, Missouri
Some of us have converters which aren't smart and if we stay plugged in all the time while the trailer isn't in use, the batteries will overcharge and the electrolyte will boil away, thus ruining the batteries. I think the new trailers and those who have replaced their originals have smart chargers now that go into a maintenance mode and only supply a minimal charge necessary to maintain the batteries.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
10-27-2020, 06:10 PM
Evergreen
Agreed. My 2020 has a smart controller and I leave it plugged into a regular 120V outlet when it's in storage.
Dennis
Past:
Airstream International Serenity 23FB
Newmar Ventana 3715
10-27-2020, 06:20 PM
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach
We leave Lucy Plugged in all the time when we are home. We do not have any fancy converter or batteries. We have been doing this for 14 years and have never had an issue.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
10-27-2020, 06:26 PM
2021 20' Caravel
Arlington
Thank you everyone. This helps a lot. I have so much to learn, but thankfully I found the site that will help me do just that!
10-27-2020, 07:10 PM
2018 25' International
Slidell
, Louisiana
When you have the electrician make up the electrical service be sure he knows it is for an RV and that it requires 120V 30 Amp 1 line, 1 neutral and 1 ground. You may want to run 220 (2 line) to the pole for some other reason but not for the trailer.
I keep my converter active with my AGMs full time. You can also completely disconnect them, as that is a good strategy. It is a bit risky to leave them connected and charge intermittently. You don't want your batteries to discharge below 50% (12.1 V resting) if you can help it.
10-27-2020, 10:49 PM
2021 20' Caravel
Arlington
[QUOTE=BayouBiker;2426881]When you have the electrician make up the electrical service be sure he knows it is for an RV and that it requires 120V 30 Amp 1 line, 1 neutral and 1 ground. You may want to run 220 (2 line) to the pole for some other reason but not for the trailer.
I keep my converter active with my AGMs full time. You can also completely disconnect them, as that is a good strategy. It is a bit risky to leave them connected and charge intermittently. You don't want your batteries to discharge below 50% (12.1 V resting) if you can help it.[/QUOTE
Brian, thanks for the info. I will let him know.
10-28-2020, 03:51 AM
2012 25' FB International
Trent Woods
, North Carolina
Sorry to just jump in, but no one has said this yet. If you have solar, there is no reason to stay plugged in to keep your batteries topped off. That is the beauty of even a small solar panel; it will provide sufficient amp-hours to make up for any parasitic loads and self-discharge.
Larry
10-28-2020, 04:09 AM
2017 16' Sport
N/A
, N/A
plugging in at home
Larry
Can be a challenge in snow belt areas and where snow and ice stay longer than weeks. Efficiency depends upon them being clean also hindered by low winter sun angles, probably works with attention.
10-28-2020, 06:18 AM
Trent Woods
, North Carolina
Surely is true and although I have not lived North of 35 degrees for over 20 years just a piddly little book-sized solar panel keeps my truck lead acid battery fully charged, since I don't use the truck very often. It shouldn't take much of a charge rate to do the same for trailer batteries. Covered in snow is an entirely different kettle of fish.
Larry
10-28-2020, 06:24 AM
2009 34' Panamerica
2005 28' Classic
Still
, in the thick of it
I have multistage converters and have left them plugged in 24/7 for entire seasons, no issues and lead/acid batteries tend to last me 6-7 years and roughly 10 days worth of boondocking on average, so it's a safe bet to keep it plugged in.
You must have a multistage converter though. As jcanavera points out, if you don't you WILL cook the batteries. I am unsure what Airstream is putting in the coaches nowadays in terms of converters, but both of mine came with single stages that I quickly replaced after having cooked up a a pair or batteries after a year or two's use.
Also, one somewhat related suggestion. Make sure you have active surge suppression wherever you find you are parking it. Now more than ever, there are a lot more electronics in Airstreams and RVs in general. Once of prevention and such.
10-28-2020, 06:32 AM
1988 25' Excella
1987 32' Excella
Knoxville
, Tennessee
Probably fine to just leave it plugged in. That is what I do. Mine is a much older trailer with a new 3 stage converter. However, there is another alternative to leaving it plugged in. Put it on a timer, like a garden timer, and just have it come on for an hour or two a day.
10-28-2020, 06:53 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Welcome Aboard 👍
SWMBO effect....We leave nothing plugged in 24/7/365 unless we are in the abode.
"Cloudsplitter" is stored on the pad and battery charge checked when thought of, wireless Victron.
POI..."won't overcharge"...is not gospel. When we had AGM's in "Cloudsplitter" I charged fully, isolated them and left the in over the Winter. 11 Seasons, they are still good and serving as back-up for the basement sump pump.
POOI...."Cloudsplitters" OEM Converter pooped the original Interstates at the dealership,(extended SP) and the second set in 2 Seasons for the same reason.👎
Today...45*
10-28-2020, 08:36 AM
Tampa
Here's an option.
I use a trickle charger on the batteries and disconnect from the trailer.
I chose the NoCo Genius, 3500. I wired the pigtail to the battery terminals, one on battery one and the other on battery two so the load is even.
Then it's just a matter of plugging in the NoCo.
*I gave up on Battery Tenders, I have four and all died over time. I realize they are very popular.
10-28-2020, 03:12 PM
2014 25' FB Flying Cloud
Fitchburg
, Wisconsin
All good advice above.
Here is something else to think about: If the dealer tech really thinks AGM batteries can't be over charged (unless your charger is maintaining them on float at 13.9 to 13.1 volts at your location in winter) I doubt that he knows his stuff.
10-29-2020, 07:17 AM
2021 20' Caravel
Arlington
Thanks again to everyone who attempted to help me understand what I’m getting into here. And the suggestion about solar is excellent. Hadn’t thought of that, but it makes perfect sense especially in TX.
11-01-2020, 11:47 AM
2013 20' Flying Cloud
2014 16' Sport
2019 23' Flying Cloud
Dunedin
[QUOTE=rushmo;2426852]
FYI. We have a Facebook page if you haven’t joined it. Airstream 20s. Lots of helpful folks there too. Judy
11-02-2020, 09:27 AM
2021 20' Basecamp
South Easton
, MA
Is there any issue w keeping trailer plugged into standard 15\20 amp outlet on side of house instead of 30amp other than not being able to run as many appliances while its sitting there in the yard?
11-02-2020, 09:52 AM
Evergreen
I don't believe there's any issue with that approach. You won't be able to run your air conditioner/heat pump.
Dennis
Past:
Newmar Ventana 3715
