Old 05-25-2022, 02:05 PM   #1
castle rock , Colorado
Ebike Hitch
I know Airstream doesn't recommend a hitch on the rear, but has anyone welded a hitch to the frame on the rear of the trailer to support a couple e-bikes? Total weight for bikes would be about 130-140#'s. I would think if it was installed properly there wouldn't be an issue?
Thanks!
Cottwood is offline   Reply With Quote
Old 05-25-2022, 03:25 PM   #2
jeffmc306's Avatar
2019 27' Globetrotter
McHenry , Illinois
Cottonwood,
check out the video from Keep Your Daydream on their Airstream bumper modification with a hitch welded in. Fast forward to 6:38 to see the fabricator doing the install.
A word of caution: hanging that much weight beyond the end of the trailer can cause issues with trailer sway. It’s like a pendulum that will wag the dog.
We went a different direction and put two full size eBikes between the twin beds. I made it out of 2x8 lumber and a pair of Kuat Dirtbag fork mounts. Keeps them safe from the weather, prying eyes and no worries about weight hanging off the back.
Good luck with your quest!
ID:	416496   Click image for larger version
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
jeffmc306 is online now   Reply With Quote
Old 05-25-2022, 04:06 PM   #3
2022 28' Pottery Barn
¯\_(ツ)_/¯ , California
Cottwood-
Check these out:
https://www.airforums.com/forums/f54...ck-233506.html
https://www.torklift.com/tailored-hitch
WellSaid11 is offline   Reply With Quote
Old 05-25-2022, 07:06 PM   #4
Originally Posted by jeffmc306 View Post
Cottonwood,
. I am wondering how much issue I would have with sway? I will use a weight/anti sway distribution hitch. We are only getting a 25 ft trailer and pulling it with a 3/4 ton ram diesel pickup that weighs around 7700 #s.
I would think with that light of a trailer it’s not going to affect me much? I have motorcycle for the bed or I would put the ebikes there.
Old 05-25-2022, 07:56 PM   #5
jeffmc306's Avatar
McHenry , Illinois
Cottonwood, you definitely have enough tow vehicle to handle the trailer and weight distribution/anti-sway hitch will help too. The unknown is how much sway the bikes hanging off the back will add.
They’ll be several feet away from the bumper. Marc from KYD seems to be happy with his setup but he’s only got standard bikes on the back; not 135 lbs. of eBikes.
Towing speed will make a big difference too. If you keep it to a reasonable level (65 MPH or under) you’ll have less chance for sway. The older I get the more risk-adverse I am. The motorcycle in the bed, towing the AS with eBikes on the back would make me a little too anxious.
FYI: Several forum members chose folding eBikes that fit in 50 gal. totes and put them inside the trailer, truck bed or even the back seat of the truck. YMMV.
2018 FC23FB
WBCCI# 10258
RETIRED!
Old 05-25-2022, 08:03 PM   #6
SilverWind's Avatar
2022 20' Basecamp
1968 17' Caravel
Los Osos , California
Wishful thinking. Prevailing wisdom says don't do it.
SilverWind is offline   Reply With Quote
Old 05-25-2022, 08:36 PM   #7
The motorcycle only ways 325#. Truck payload is 2170. Is the hitch weight more than what airstream says it is? They say 875#. Even if it is a 1000#, I should be well under on payload. My wife and I weigh a combined 260#, plus a 12# dog. I don't know if that would have a bearing or not?
Old 05-25-2022, 09:00 PM   #8
jeffmc306's Avatar
McHenry , Illinois
Your real-world hitch weight will be closer to 1000 lbs. Our 27’ GT is around 1100 lbs fully loaded including full fresh water tank. 25’s tend to be a little heavier on the tongue.
We tow with a gas RAM 2500 (2940 lbs. payload) and never felt any sway using a Blue Ox SwayPro and 1000 lbs. bars.
It’s too bad you can’t fit the bikes in the truck bed along with the motorcycle (or leave the cycle at home?).
2018 FC23FB
WBCCI# 10258
RETIRED!
Old 05-25-2022, 09:44 PM   #9
2019 30' Classic
Belen , New Mexico
I built this rack in the “Fiamma” style three years ago. It has carried two Pedago Platinum Interceptors for over 12000 miles and has held up well. I’m very happy with it. It’s made out of aluminum tubing and kee-light fittings.
ID:	416521Click image for larger version
Ephraim is offline   Reply With Quote
Old 05-26-2022, 02:51 AM   #10
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
It's not just about how much weight your trailer and tow vehicle can handle. It's also about where that weight is carried.
You're talking about cantilevering 140 pounds off the rear bumper of the trailer, far away from the center of gravity and the axles. Even if it's well within the capacity of the trailer & TV, the further you put weight behind the axles, and the more weight you put there, the more you increase the likelihood of a sway event occurring.
There are good reasons Airstream doesn't recommend doing this.
Richard
11018
richard5933 is offline   Reply With Quote
Old 05-26-2022, 06:59 AM   #11
Attachment 416521Attachment 416522
Those Pedego's weigh 60-65 #'s a piece correct? Do you have any plans for building that rack? Have you had sway issues? What do you tow with? What trailer do you have? Did you weld a receiver on? What did it weight? What does the rack weigh? Thanks!
Old 05-26-2022, 08:09 AM   #12
2019 30' Classic
Belen , New Mexico
Ebike Hitch
There is no set of plans though I could take some measurements and post them along with a parts list. I still consider this a “beta” version though I haven’t made any changes to it in 18 months. There are some things I would do differently though. I have the Tim Allen syndrome and it is way overbuilt. I used too thick of tubing. (Equal to schedule 80 pipe) I would use schedule 40 aluminum pipe next time as that is what the fittings were designed for. The only welded portion is the base mounts where I fabricated two flanges to mount on the frame. Haven’t found a better way to do that. The main support legs and the bicycle holding tray were bent on a tube bender. The rest was just “measure and cut to fit”.
I did put an extra self tapping screw into each joint because I feared the set screw would back out but I’d probably just use locktight if I built it again.
The actual wheel and bike frame clamps are Thule purchased off of their web site.
There have been zero sway issues with this carrier. When I first posted the first version of it on the forums, I believe one of the first comments was that it would cause sway and the trailer would roll. I’m still trying to figure out if that person was a chicken little impersonator or if the comment was sarcastic. After 12000 miles there have been no issues at all.
The airstream is a 30 Classic RBQ pulled by a 2006 Dodge Ram 2500 with a 5.7 Hemi.
There is nothing welded onto the airstream for this bike rack. The bottom flanges are bolted to the frame with self tapping bolts (three on each side) and the top braces are screwed with #12 screws to the body. Those screws were tough to put it. I predrilled the holes and the screws cut there own threads through the struts but had to use a socket wrench to install them. The top flanges have three holes but only two are aligned with the body frame. The third hole has a screw but it’s just for looks as it carries no strain.
I haven’t weighed the rack as it was built in place but based on the published data of the tubing and fittings it probably weighs in at about 20 pounds or so. I have stood on it (275 lbs) and it didn’t even creak. It has withstood some pretty rough roads as well with both bikes on it.
It will hold the bikes with the batteries but we tend to travel with the batteries pulled and in the airstream for theft reasons.
The changes I still have planned:
The tray folds up when not used but has to be held up by a bungee cord. It would be nice to have some sort of latch there.
It needs a license plate holder and tail lights so I can cover the bikes when traveling. If the weather is bad they get pretty dirty back there.
The bottom rail needs to be raised about an inch for better access to the rear hatch. Another inch would allow the 50A anaconda to slide under the rack into the hatch for storage.
Nothing is anodized so you get black oxide on your hands when you mess with it. When done, I’ll disassemble it and have it anodized.
eBike Lafitte Off Topic Forum 44 07-05-2020 07:26 AM
ebike holder from AS- want one? waninae39 On The Road... 1 08-30-2019 10:03 AM
An exquisitely bad idea, AKA the hitch of death or the sway-enhanced hitch Jammer Hitches, Couplers & Balls 8 01-20-2010 04:40 PM
Bambi Hitch Height - Equalizer Hitch Shank campadk Hitches, Couplers & Balls 3 08-31-2006 11:48 AM
