Old 03-29-2018, 03:08 PM   #1
2014 27' FB International
Hooper , Utah
Covers for Airstream Air Conditioners
I have been told to NEVER cover an Airstream with one a fabric protective cover like to see on other kinds of trailers because it will ruin the Airstream finish. What about covers for just the Air Conditioners such as: ADCO 3021 White RV Air Conditioner Cover sold by AMAZON? Are there any advantages or disadvantages in covering just the air conditioner?
albret is offline   Reply With Quote
Old 03-29-2018, 04:53 PM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
The best way to protect an air conditioner shroud is to paint it. The plastic used to form an A/C shroud will degrade in sunlight and become brittle. Painting the shroud protects it from UV light both when the trailer is stored and when it is in use. Unlike a fabric cover that only protects against UV when the unit is stored.
The only benefit to a fabric shroud cover is to keep dead leaves, bugs, and other detritus out of the air conditioner. But if you're going to get up on your roof to apply or remove a fabric cover, you could get up on the roof to clean out the shroud instead so that detritus doesn't build up in the first place.
Atwood Air Command Air Conditioners Lumatic Furnaces, Heaters, Fireplaces & Air Conditioning 35 10-08-2020 08:14 AM
1 Micro Air 2 Air Conditioners | Dilemma MarkJUrban Electrical - Systems, Generators, Batteries & Solar 17 10-30-2018 02:43 PM
Airstream Sterling 27FB Travel Trailer 2 Air Conditioners 50 Amp Service eBay Watch Airstreams on eBay 0 07-10-2013 12:50 PM
99 Airstream CUTTER**CAT 300HP SERVICED MAY 2012**2 Air Conditioners*35 FT eBay Watch Airstreams on eBay 0 05-17-2012 08:20 PM
99 Airstream CUTTER**CAT 300HP SERVICED MAY 2012**2 Air Conditioners*35 FT eBay Watch Airstreams on eBay 0 05-10-2012 08:10 PM
