Old 08-22-2020, 08:07 AM   #1
1975 Argosy 26
Corrales , New Mexico
Tips on Creating a new Access Door from old water heater opening
We have removed the old heavy water heater and replaced with a tankless one. There is a hole now and we are okay just patching it but wanted to know before we do, if anyone has successfully converted the water heater cavity into a usable storage compartment. It seems a shame to waste the space with a patch (area isnít accessible from the interior. Any help greatly appreciated!
rushhome6 is offline   Reply With Quote
Old 08-22-2020, 01:35 PM   #2
1965 17' Caravel
Olathe , Kansas
Had a similar problem. If you want you can get polished aluminum tread plate at Loweís or Home Depot. I used the rivets that leave threaded inserts and got some of the fasteners from the hardware store to fasten it with. Mine are threaded and have knurled ends so you can finger tighten or use hex wrench. I donít mind the look and it shows well against the other polished aluminum. I have a storage box on the rear that is treadplate so it looks like I did it on purpose.
Lcrupper is offline   Reply With Quote
Old 08-22-2020, 01:54 PM   #3
Airstream Driver
PeterH-350LE's Avatar
1994 30' Excella
1992 35' Airstream 350
Images: 51
Attachment 376577
Attachment 376578
Why not do it right and install an original Airsteam door. This one on Ebay is a little too small, but that could easily be taken care off by a spaces piece of alu on the bottom
https://www.ebay.com/itm/Vintage-use...4AAOSwowBdjCos
AIR #13
PeterH-350LE is online now   Reply With Quote
Old 08-28-2020, 09:08 AM   #4
1975 Argosy 26
Thanks PeterH-Airstreamer ! Iíve been looking at that door for a month. Trying to decided if itís worth the trouble.
Old 08-28-2020, 09:51 AM   #5
Airstream Driver
1994 30' Excella
Images: 51
I hope you got it, since it says sold
AIR #13
Water Heater Switches Creating a Direct Short and Blowing 15 Amp Fuse 4riveteers Electrical - Systems, Generators, Batteries & Solar 11 11-11-2017 12:09 PM
Old cathedral door opening sound. jmpgino Hitches, Couplers & Balls 9 06-05-2015 09:30 PM
Creating a wider side opening Glamper1 Sprinter and B-van Forum 2 05-26-2015 06:23 PM
Framing for New Water Heater Opening silver-man 1960 - 1964 Overlander 3 04-25-2011 11:17 PM
