Old 12-20-2018, 07:07 PM   #1
Al and Missy's Avatar
2002 30' Classic S/O
Fleming Island , Florida
Strange Leak at Outside Storage Doors
I'm in the middle of a interior repair to mitigate water damage from a roof vent that didn't close all the way (to be reported in another thread). I have the bedroom stripped from the subfloor up to the level of the bed tops, i.e. I have removed the flooring and the floor mounted furniture. This demolition gave me a good view of the inside of the storage doors as I was working.
A rainstorm came up and suddenly there was a slight stream of water running across the floor. The source was the roadside storage compartment door, but in a very odd way. Water was coming up over the gasket, apparently wicking up due to capillary action between the door and the gasket.
These are new seals. I had J. D. Sanders order them about a year ago. When the first set came in they didn't look like the ones I assumed to be the originals in that the door didn't touch the seal when closed leaving a gap of 1/4" or slightly less. David ordered me some new seals after I sent him sketches, pictures and measurements. They looked like the originals but may have been slightly less tall.
Has anyone run into this problem, and if so, what was the solution? I'm thinking of ringing the edge of the doors with a strip of rubber sheet about 1/8" thick and 1" wide.
Al
Old 03-31-2020, 08:57 AM   #2
1993 29' Excella
Crystal Lake , Illinois
Let me know, PLEASE, what you come up with, as I'm experiencing the same thing on my Excella storage doors.
I'm new to Airstreams, but not to fabrication. I am starting to convince myself that my storage doors, BOTH OF THEM, were improperly fitted during original installation. The bottom piano hinge is mounted too far away to allow the door to seal against the inner rubber seal/gasket around the opening. There's an 1/8" to 1/4" gap when the door is closed, and even pushed in by hand.
I'm thinking that either some sort of rubber seal around the perimeter of the door to take up the space, or to drill out the hinge rivets, and move the door "in" towards the seal, re-drill and rivet.
Thoughts?
Airstreamfan is offline   Reply With Quote
Old 04-06-2020, 10:57 AM   #3
Thoughts?
I haven't solved it yet, but your thoughts are about the same as mine. I have some flat seal that I bought for another use and I may try that next time I have the trailer at the house.
Al
Old 04-06-2020, 12:35 PM   #4
pjshier's Avatar
2017 27' International
Wasilla , Alaska
Before you get out the drill...
...try my favorite McMaster Carr. They have two of most things and one of everything. Check out their selection of foam and rubber and silicone and ... sealing material in all shapes and profiles.
2017 Int'l Serenity 27FB
2020 F250 powered by converted solar
pjshier is offline   Reply With Quote
Why did Airstream change from front hinge doors to suicide hinge doors? arcamedies Airstream History 28 08-15-2019 12:06 AM
Strange Window Leak thinktankair Windows & Screens 8 02-17-2014 06:54 PM
storage doors on outside of trailer silvergirl53 Doors & Locks 5 06-04-2012 09:29 PM
Strange toilet leak Anniedog Sinks, Showers & Toilets 4 09-26-2008 11:20 AM
HELP! need panel doors on outside storage happydaze Doors & Locks 1 12-13-2007 08:38 PM
