Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Exterior Storage Compartments & Access Doors
Old 08-07-2013, 08:07 PM   #1
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Stainless Steel Water Heater and Furnace Doors
Has anyone purchased the stainless steel water heater and furnace doors that Airstream sells? Any comments regarding their quality or installation? I was thinking about updating my Classic's doors.
Are there any other sources other than Airstream?
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
Old 08-07-2013, 08:10 PM   #2
Retired.
. , At Large
A fellow forum member has his trailer in for some repairs, and has those on it. I can ask his permission and snap a few photos if you would like, and he doesn't mind.
Old 08-07-2013, 08:13 PM   #3
dkrug's Avatar
2012 30' International
Bad Axe , Michigan
We purchased from Airstream. We also did the stove vent and outside shower. Huge improvement.We did the installation ourselves. Just finished the outside shower today.
Now, if we could just find a potable water door....
2012 30' International Serenity
1947 Spartan Manor
2005 28' Safari LS - traded
1977 31' International Sovereign - sold
2012 Ford F250 Superduty Crewcab
WBCCI# 1007 Air#2158
dkrug is offline   Reply With Quote
Old 08-07-2013, 08:14 PM   #4
matthorr's Avatar
2012 25' FB International
Colorado Springs , Colorado
They are an easy install and look great. The furnace cover requires you to install a gasket to seal around the blower fan (just copy where the original has a gasket inside the door). We also had to bend the tabs that hold onto the hinges for the furnace door to get the old one off. You reuse the hardware and vent inserts on both.
matthorr is offline   Reply With Quote
Old 08-07-2013, 08:20 PM   #5
dkrug's Avatar
Bad Axe , Michigan
Matthorr has a very nice bunch of pictures posted on the outside shower and a description that helped us.
1947 Spartan Manor
Old 08-07-2013, 08:22 PM   #6
jcanavera's Avatar
Fenton , Missouri
Images: 143
I just had the Classic home this past week and noticed that the stove vent is popping its paint. I didn't realize that it is white painted silver/grey. I might try to paint this though (even though this is available in stainless also). I don't like pulling stuff off that has been water tight. My luck is that I'll start a leak.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
Old 08-08-2013, 05:04 AM   #7
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
I bought the stove vent and it went on easily. The original plastic one had begun to crack, now I won't have to worry about it again.
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Old 08-08-2013, 05:19 AM   #8
rperrym's Avatar
2017 27' Tommy Bahama
2016 30' Flying Cloud
2014 27' FB Eddie Bauer
Hot Springs Village , Arkansas
Outside Shower Door, posted by dkrug
Did you have to modify the opening to install the outside shower door?
Did you use a gasket? Someone posted they had to enlarge the opening to install the new shower door.
Rick
rperrym is offline   Reply With Quote
Old 08-08-2013, 05:35 AM   #9
Gilmurr's Avatar
1998 30' Excella 1000
Halifax , Nova Scotia
I have been polishing our Airstream and I tackled the hot water and furnace doors as well. I have some finish work to do but they look great....and less than the cost of the Stainless Steel ones from Airstream. Doing that did justify buying the Range vent from Airstream. Just arrived the other day and easy to install.
ID:	192684   Click image for larger version
David & Andrea
'98 Excella 1000 Classic 30ft
2007 Toyota Tundra Dbl Cab
Gilmurr is offline   Reply With Quote
Old 08-08-2013, 06:34 AM   #10
dkrug's Avatar
Bad Axe , Michigan
Rick
Yes, the opening had to be enlarged a bit and the corners squared up. The new stainless shower came with two gaskets. One for the opening and one for the shower door.
1947 Spartan Manor
Old 08-11-2013, 10:11 AM   #11
2011 25' FB Flying Cloud
Anywhere & , Everywhere
Here is a link to the Colonial site that shows the Airstream SS accessories installed:
Bike Rack - from Colonial Airstream: Exterior Upgrade & Appearance Package for Airstream International &*Flying Cloud Travel Trailers
For some reason the water heater cover has rivets and the furnace cover doesn't. Gives you a chance to see what both styles look like.
Al - K4GLU is offline   Reply With Quote
Old 08-18-2013, 04:41 PM   #12
mefly2's Avatar
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town , *** Big Sky Country ***Western Montana
What I like most about the stainless furnace and water heater doors is the durability in a lower exposed area ... and easy maintenance (scotch-brite pad or WD-40) ... although soft material, the stainless is not as soft as the aluminum.
Old 08-18-2013, 05:25 PM   #13
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
The job is not complete until the mud duaber wasp guards are in place:
Mud Dauber Screens to Protect RV Furnaces - PPL Motor Homes
I installed them after the stainless steel doors were in place on the first trailer and will also install them on the new one.
Old 08-18-2013, 07:33 PM   #14
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
I have replaced the furnace, HW heater, stove vent, shower with the SS panels. Such an improvement! Also, used the Furrion chrome units for the two 30 Amp plug-ins and the chrome Furrion CATV unit. The only cheesy plastic left is the water door and the plastic electrical outlet. There are a bunch of us looking to replace those as well!
_________________
"SilverLeaf II" 2015 30' Classic
2019 RAM 2500 Limited 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 02-14-2014, 03:42 PM   #15
subfan1's Avatar
2019 23' International
La Habra , California
For those that installed the ss stove vent, did it come with a gasket and did you seal the edges?
2019 GMC Sierra Denali
2019 23CB International
subfan1 is offline   Reply With Quote
Old 02-14-2014, 06:46 PM   #16
BAB
BAB's Avatar
2015 30' Classic
Yes it came with a gasket, and yes I sealed it...
_________________
ProPride 3P
AIR# 58452
Old 02-14-2014, 07:36 PM   #17
subfan1's Avatar
Thank you I'm going to confirm that we have a gasket when we get home after this weekend and then seal it. What sealant is recommended?
Old 02-14-2014, 07:42 PM   #18
BAB
BAB's Avatar
2015 30' Classic
Gosh, I did this so long ago....think I used either SikaFlex or Parbond....
_________________
ProPride 3P
AIR# 58452
Old 02-14-2014, 08:38 PM   #19
dznf0g's Avatar
Oswego , Illinois
I used parbond.
-Rich-
Old 02-14-2014, 09:25 PM   #20
Ottawa , ON
I remember seeing a paragraph in the installation manual for my new furnace strongly warning against using those screens. I can't recall if they mentioned why, and of course, the book is well-buried in the trailer, under several feet of snow.
Upon remembering this, I had a closer look at the ad for this that you posted, and I realized that it was not Suburban's suggestion that we buy those screens, but rather PPL's.
I would not use the furnace with them on during the heating season. Suggest checking with Suburban/Atwood if you want more information.
