Old 11-16-2020, 03:23 PM   #1
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Replacement, Upgrade Vintage Airstream Entry Door Lockset
I need some experienced advice please. I want to upgrade the entry door lockset on my 1975 Overlander 27'. It currently has a KT lockset. The trailer entry door has a formed aluminum frame, not the thick cast aluminum one of the sixties trailers. I estimate the lock setback is about 1 1/2", not the the long 3 1/2" needed for the cast door frames, e.g 1969 Globetrotter Bargman L-100 lock set with that long bolt length.
Rebuilt KT locksets are horribly expensive and not worth it. And they are not available right now anyway. I need a better alternative than that.
I know I have to make a patch for the door skin to upgrade the lock set. I know some modification to the screen door frame may be needed. And I may have to reposition the striker in the door jam.
My father in law some 25 years ago replaced the lockset on the family 86 Limited 34' we inherited. It is worked well through the years. Here are photos of that lockset. This lockset says TriMark on the back of the lever handle. It is about 3" wide and about 4" high. I see similar locksets for sale, but don't know a good brand. I don't want a keyless entry system. Just another thing to go wrong.
What have you vintage Airstreamers done to upgrade your locksets? What lockset did you buy, and what modifications were needed, and lastly: does it work well?
Thank you kindly,
David
ID:	383384   Click image for larger version
Name:	1907 Curb-800x600.JPG
WBCCI #8607 VAC Region 11
KnowledgeBase trailer renovation threads: 69 Globetrotter, 76 Sovereign, 75 Overlander, 66 Trade Wind Such fun !
dbj216 is online now   Reply With Quote
Entry door lockset JLGT5107 Doors & Locks 3 11-05-2009 05:54 PM
need door knob/lockset '61 Overlander wildcat455 Doors & Locks 1 12-01-2003 11:59 AM
'61 door lockset repair/replace wildcat455 Doors & Locks 5 08-23-2003 07:33 PM
vintage door hardware/lockset wildcat455 Doors & Locks 0 08-21-2003 08:04 PM
