Old 06-05-2020, 10:47 AM   #1
2018 30' Classic
Sanford , North Carolina
Outdoor Shower Lock STUCK
We have a 2018 30’ Classic and the lock for the outdoor shower door won’t open. We have 6 copies of the correct key and all I can think of is that the interior latch device has probably rusted. Any suggestions of inexpensive, proven fixes would be greatly appreciated. Thank you in advance.
GoinStreamin is offline   Reply With Quote
Old 06-05-2020, 10:52 AM   #2
2019 30' Flying Cloud
Homosassa , Florida
Push in on the lock area and see if it will turn.
Tater is offline   Reply With Quote
Old 06-05-2020, 11:07 AM   #3
2018 30' Classic
We’ve tried that and lubricant. Thanks.
Old 06-05-2020, 11:13 AM   #4
Homosassa , Florida
Have you tried gently tapping it as tou try to turn the key.
Old 06-05-2020, 11:26 AM   #5
Mollysdad's Avatar
I think I'd call a locksmith before I risked damaging that stainless door.
Rust on a 2018 lock?
Call me crazy, but I'd try all the other compartment keys, like the baggage door, the water fill, etc.
Old 06-05-2020, 12:25 PM   #6
Ray Eklund's Avatar
2019 27' International
2014 25' International
Fort Saunders , Wyoming
Options and more options
- Did this key work previously? I have to assume it did.
- A locksmith would cost more than replacing the entire lock and key.
- Try the original key and put pressure towards the door. Have a pliers on the end of the key and try a little bit of leverage. Just enough, but not so much you bend the key is the idea. Torque. If the springs operating the tumblers within have a crust... this will break it loose.
- Do the above and pull the key OUT just barely and repeat. If that works, play with the key and lock assembly still in the door and just look it over. Hate to close it and it quits working... again. The flat latch inside the door could be a too snug. Press the door and compress the rubber gasket some... and try it again.
- Since you probably will not be using the outdoor shower, order a replacement lock and key assembly. Then drill out the center of the lock, start with a small drill bit, increase the diameter of the drill bit until these tumblers start coming out in pieces. Should be brass. You could have Calcium in the cylinder is my only idea.
- These locks are not the best and even inserting the key can bend a tumbler.
- If you are not going to be using the trailer for awhile, you drill it out and go to a locksmith and bring the whole unit. They can match it, or you contact the Airstream Dealer if there is one locally.
- These are not the smoothest operating locks when operating. Since I do not know what your tired... here is every option before I DRILL THIS DOG OUT and find one that is working smoothly before buying it. Have at least three keys that work. Test each one. Some may be off just a little and not work. How do I know? Guess. Good luck.
Human Bean
Ray Eklund is offline   Reply With Quote
Old 06-05-2020, 04:11 PM   #7
2018 30' Classic
Thank you. The keys have all worked before. We may drill it out and replace with a turn latch only.
Old 06-05-2020, 04:12 PM   #8
2018 30' Classic
All keys have been tried and the original 6 keys all worked previously. Thank you.
Old 06-06-2020, 10:08 AM   #9
2017 23' Flying Cloud
Mesquite , Nevada
After an afternoon towing on a bumpy road the exterior compartment lock was frozen, no amount of force and wd40 would budge it. The sun was going down and we needed items inside to hook up is had no choice but to break the lock with a screwdriver. Upon inspection it seems that the pot metal cylinder is a very cheaply made piece that was susceptible to vibration. I'm still looking for a suitable replacement for this lock/latch. In the meantime I can latch the door but not lock it.
Ken G is offline   Reply With Quote
Old 06-06-2020, 10:34 AM   #10
Mikebrady62's Avatar
Rogers , Arkansas
Sounds Perfect
I really don't feel a need for a lock there anyway. There is lot more things I could worry about than having someone drain my tank or steel a shower head.
Mikebrady62 is offline   Reply With Quote
Old 06-06-2020, 11:14 AM   #11
SilverFire
2007 19' Bambi
EUGENE , OR
Stuck Lock
You may want to lubricate generously with penetrating oil (with narrow diameter wand) and let it sit for an hour or two. After breaking cam lock loose wipe off any excess penetrating oil off and re-lubricate lock with Tri-Flow lubricant with P.T.F.E. only.
Locksmiths specifically recommend not using WD-40 or graphite lubricants any longer. They recommend lubricating with Tri-Flow.
Good luck
SilverFire is offline   Reply With Quote
Old 06-06-2020, 12:51 PM   #12
2018 30' Classic
Ditto...same here. I don’t need a keyed lock here.
Old 06-06-2020, 01:33 PM   #13
Mollysdad's Avatar
Well, yeah, but before he replaces anything, he needs the lock open.
The stainless shower compartment is a $245 item.
A locksmith is cheaper. Do it at your convenience, it's not like you can't move without the shower door open!
Give the screwdriver a try. Or a drill. Once you drill, a locksmith won't be able to help you.
Old 06-06-2020, 01:35 PM   #14
Tifton , Georgia
Before you drill, try to locate a product call Houdini. It is what locksmiths use to unfreeze locks. I've used it on a neighbor's car which has been sitting in her back yard for over 5 years. She wanted it hauled off but they couldn't get into it to get it out of park (didn't want 2 groves through her manicured yard). I sprayed Houdini into the lock, waited about 45 seconds, put in the key, jiggled it and then was able to operate the lock.
I use it on the TT every 6 months to lube the tumblers. Never had one stick.
xyzabe is offline   Reply With Quote
outdoor shower install? Is there a kit.... zedex Sinks, Showers & Toilets 9 12-12-2010 05:14 PM
Installing Outdoor Shower Killo1 Sinks, Showers & Toilets 24 03-31-2007 10:41 PM
Outdoor shower part numbers 67caravel Sinks, Showers & Toilets 20 09-07-2006 12:59 PM
Pondering outdoor shower.... Boondocker Sinks, Showers & Toilets 6 02-02-2006 05:06 AM
Outdoor shower idahosafari Sinks, Showers & Toilets 19 04-12-2004 07:48 AM
