Old 11-07-2020, 11:51 AM   #1
Castaway's Avatar
2012 25' FB Flying Cloud
Celina , Ohio
Outdoor shower door lock
I can insert the key and wiggle it in the slot but am unable to unlock the outdoor shower door. I tries some silicone but it did not help. Any suggestions short of forcing it open?
Gary
Castaway is offline   Reply With Quote
Old 11-07-2020, 12:15 PM   #2
2018 25' International
Slidell , Louisiana
The shower door and fresh water key is different than the storage key, perhaps that is the issue?
Brian
Old 11-07-2020, 02:07 PM   #3
Castaway's Avatar
Celina , Ohio
I have tried both keys and I get the same response.
Old 11-07-2020, 02:17 PM   #4
2018 27' Globetrotter
Elbert , CO
Have you tried pushing in on the door while trying to turn the key? Sometimes if the hose and head haven't been put in "just so", they push out on the door and put the latch into a bind. Pushing in a little lets the latch return to its flat position and it can be turned.
djb75 is offline   Reply With Quote
Old 11-07-2020, 03:08 PM   #5
Slidell , Louisiana
In addition to the pushing trick, get a paper clip or a lock pick and stroke the tumblers to try to free them up. It is most likely a stuck tumbler. WD40 or corrosionX will help a lot more than a silicone lube if the tumblers are corroded.
Brian
Old 11-08-2020, 10:40 AM   #6
2019 30' Classic
Charlotte , North Carolina
Had this exact thing happen. The lock hasp had rusted itself to the strike plate. You need to break that bond. Try rapping on the lock with a hammer lightly but firmly. Hard to get lube back there with the door closed.
When you get it open, wire brush both sides and lube it up.
LilPeanut is offline   Reply With Quote
Old 11-08-2020, 10:40 AM   #7
MaineStreamer's Avatar
2007 20' Safari
Old Orchard Beach , Maine
Try WD40 spray.
Marty Womer
Old Orchard Beach, Maine
Trailer name: Quarantina
2019-2021 President, Northeast Mountaineers Airstream Club
MaineStreamer is offline   Reply With Quote
Old 11-08-2020, 11:44 AM   #8
:SPACE A" S/O 11 Air19745
guskmg's Avatar
2006 34' Classic S/O
Fort Worth , Texas
My locksmith says to only use WD-40 on outside locks because it is an excellent moisture inhibitor.
guskmg
Old 11-08-2020, 04:02 PM   #9
2018 30' Classic
Sanford , North Carolina
The locks can rust. We just drilled it out last week. Before doing so, know the lock is a specialty lock made exclusively for AS, ranging from $35-$75. Looks like every other lock, but it’s measurements are unique to them. We had to drill a bigger hole into the shower door and manipulate a similar lock. Good luck.
GoinStreamin is offline   Reply With Quote
Old 11-09-2020, 02:21 PM   #10
Castaway's Avatar
Celina , Ohio
A combination of WD 40 and tapping the lock solved my problem.
Gary
Old 11-09-2020, 03:44 PM   #11
Castaway's Avatar
Celina , Ohio
Thanks Guskmg and LilPeanut.
Gary
Outdoor Shower Lock STUCK GoinStreamin Exterior Storage Compartments & Access Doors 13 06-06-2020 01:35 PM
outdoor shower door jgerardi General Appliance Topics 2 03-03-2012 10:18 PM
Outdoor shower part numbers 67caravel Sinks, Showers & Toilets 20 09-07-2006 12:59 PM
Pondering outdoor shower.... Boondocker Sinks, Showers & Toilets 6 02-02-2006 05:06 AM
Outdoor shower idahosafari Sinks, Showers & Toilets 19 04-12-2004 07:48 AM
