Old 04-13-2020, 04:19 PM   #1
redthies's Avatar
1974 29' Ambassador
1963 19' Globetrotter
Whiterock , British Columbia
Foam entry door “travel lock”??
Has anyone seen this before? One of my clients sent me the photo and said she had seen it on here. Search came up empty. It’s a cool concept that I would buy into (literally) if they were available. I’ve got lots of polished trailers leaving my shop with less than stellar door latches.
redthies is offline   Reply With Quote
Old 04-13-2020, 04:30 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
A very common devise sometimes refereed to as a "Wally Lock"
Mostly used on vintage trailers because of the suicide door and having a door latch of questionable integrity. If the door opens in transit (and they can) serious damage can be done to the trailer.
I made one when I had a vantage trailer.
Richard
Old 04-13-2020, 04:52 PM   #3
Glenritas's Avatar
1969 25' Tradewind
Shasta Lake , California
You can make it out of wood and glue a foam or felt strip to the contact side.
Glen & Jane 1969 all electric Airstream 25' TradeWind
2014 Toyota Tundra
1998 Chevy Tahoe
WBCCI #6269
My Build Thread https://www.airforums.com/forums/f11...ml#post1997059
Glenritas is offline   Reply With Quote
Old 04-13-2020, 07:00 PM   #4
redthies's Avatar
1974 29' Ambassador
I’m painfully aware of what can, and does happen with the doors. I was looking for info on whether there is someone making these commercially. I have the skills etc to make these, but my time is worth significantly more than what they should cost if someone manufactured them.
If nobody does sell them, I’ll make some up.
Thanks for the info guys!
Old 04-13-2020, 08:52 PM   #5
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Where is that thread which gives the Biblical description of this device, and the rending of.garments and gnashing of teeth for failure to use one?.
Old 04-13-2020, 09:00 PM   #6
1967 17' Caravel
Pocatello , Idaho
There are a couple of those threads, and I recently PMed one of the guys who said they made them but I never heard back.
As an elderly toolless female, I need to buy one, not make it.
Vivian
Landshark is offline   Reply With Quote
Old 04-13-2020, 09:04 PM   #7
1966 22' Safari
Fredericksburg , Texas
The “thingy” shown in your first post fits great on most of the 60s. I found on the 55 I had to do a little modifying. I did as Glen mentioned, glued a piece of foam, or felt, on the back edge to keep from scratching the finish. I have made and given dozens away to campers I’d met. They give an ease of mind concerning the door flying open while traveling.
Bubba L is online now   Reply With Quote
Old 04-13-2020, 10:28 PM   #8
redthies's Avatar
1974 29' Ambassador
Bubba, did you just cut them out of plywood and glue felt to it? I might whip a few up. I’ve got a ‘65 out for polishing right now, and I want to make sure it comes home the 4.5 hour drive with it’s new shine being the only thing worth discussing, not the big dent in the side...
Old 04-14-2020, 03:38 AM   #9
batman's Avatar
1964 22' Safari
modesto , California
Here is one thread on the subject, The prophecy of the wedge...
https://www.airforums.com/forums/f48...ge-200171.html
-Dennis
batman is offline   Reply With Quote
Old 04-14-2020, 06:08 AM   #10
1966 22' Safari
You can cut them out of hardwood ply plywood, light sand and get a rattle can of lacquer to seal it. You can also paint if you want. Once dry, glue a piece of felt to the back. I use hardwood for those. Mainly because I have small wooden projects I mess with and I have scrap mesquite, cherry and walnut left over. Different style door grab bars over the years may require some wedge modification. Good luck
Old 04-14-2020, 11:15 AM   #11
Steamy1's Avatar
2015 23' FB International
2007 19' International CCD
Steamboat Springs , Colorado
The Fiamma Safe Door security lock was the best solution. Locks in the open or closed position. Added benefit of having another locking mechanism to secure the main door.
Steamy1 is offline   Reply With Quote
Old 04-14-2020, 11:32 AM   #12
1967 26' Overlander
Spartanburg , South Carolina
We tied a bright colored bungee around the door knob of our '67 and hooked it to the hand hold. Can see it to verify in my rear view mirror.
Jacob D is offline   Reply With Quote
Old 04-14-2020, 03:02 PM   #13
1967 17' Caravel
Pocatello , Idaho
Just googled the Fiamma lock, and it requires drilling holes in the doorframe.
NOT FOR ME--no holes in my coach! It's hard enough keeping water out of all the accidental openings in ones coach, so drilling more holes on purpose is simply not going to happen.
If worse comes to worst, I will use a bungee--maybe that is the safest anyway, although not very elegant for an Airstream!
Vivian
Old 04-14-2020, 03:55 PM   #14
Steamy1's Avatar
Yes; it does require drilling two holes into the door frame edge. I used Sikaflex 221 along with two large rivets. The mounting plate is pressed against the door jamb and is very secure and water tight.
Like I said, it is functional and secures the door. Works for us.
Old 04-28-2020, 03:06 PM   #15
redthies's Avatar
1974 29' Ambassador
I’ll check that Fiamma out Steamy. Thanks
Old 04-28-2020, 06:00 PM   #16
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
OlyPen , Washington
Images: 90
Here is the article and a pattern of sorts: http://www.airstreamcentral.com/arti...tch/Page1.html
it wasn't foam - but nicely finished wood. Freshair recommended birch ply I think.
1964 Overlander | 2020 Mercedes GLE
AirForums Custom Search
Janet H is offline   Reply With Quote
Old 04-28-2020, 06:19 PM   #17
Mollysdad's Avatar
Seen it? Yes. But they're not commercially made. Most folks make their own. The reason being that the outside handle varies so much between models.
Most are simply plywood cut and painted.
I think it's brilliant!
Old 04-28-2020, 06:21 PM   #18
Steamy1's Avatar
When I first purchased this for our Bambi, it was available through Fiamma USA. When I went to purchase another one for our 23FB, I was able to purchase it using Ebay from an RV supplier in the UK. I had never purchased from an overseas vendor but it was delivered without a hitch.
Old 04-28-2020, 07:19 PM   #19
redthies's Avatar
1974 29' Ambassador
Thanks Steamy. I’ll see if I can get one this side of the pond first, but otherwise the UK is fine. All our blinds come from there...
Old 04-29-2020, 06:36 AM   #20
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Vivian
It does not fasten on the surface of the coach. It fastens to the door jam. Should not leak.
Thief damaged my FC cargo door lock attempting to gain entry now key wont open lock luckysgt663 Doors & Locks 14 04-01-2019 02:57 PM
Updated keyless entry lock BAUER LOCK sc17842 Doors & Locks 6 03-22-2016 09:53 PM
1964 door in a Door entry door hinges recycled Windows, Doors, Locks & Vents 1 09-18-2013 06:07 PM
Entry Door Lock Set Hunt ends at Inland Grady White 1959 - 1965 Ambassador 3 12-16-2004 09:08 PM
Numeric Entry Door Lock Combination/reprogram Tom & Janet Salhus General Motorhome Topics 6 06-09-2004 11:06 PM
