Old 06-02-2019, 07:42 PM   #1
2007 23' Safari SE
Woodstock , Connecticut
Exterior Door hinge pin problem
I recently saw a post on the hinge pins that want stay in place. I am having the same problem. The post I saw had a video from the mother ship about a new pin that has a channel in it to use a "c" clip to hold the pin in place. Anyone who could direct me in the right direction would be much appreciated.
Curtis
airforus is offline   Reply With Quote
Old 06-02-2019, 08:10 PM   #2
1977 Argosy 24 Rear Door
Chesapeake , Virginia
Following as I need a replacement for a broken pin
ArgosyJeff is offline   Reply With Quote
Old 06-03-2019, 05:34 AM   #3
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Ours also got loose, when I painted the hinges I staked the pins. 9yrs SFSG.👍
Name:	DOOR HINGE CORROSION REPAIR 007.jpg
ID:	342385   Click image for larger version
Obrigado, hora de descansar.
Tahawus
Old 06-04-2019, 04:52 AM   #4
2007 23' Safari SE
Thanks. Mine had been staked at some point, but has not worked. Have a new pin/clip on order.
Curtis
Exterior door hinge pin portageking Doors & Locks 13 12-14-2014 10:19 AM
Hinge pin problem-'96 Excella sander17 Doors & Locks 6 07-14-2006 06:20 AM
Top door hinge pin works out during travel? Kistler Our Community 4 06-20-2005 07:04 PM
door hinge worn not the pin silver 67 Doors & Locks 5 08-11-2004 08:30 PM
Door hinge pin. wyhjr Doors & Locks 3 10-20-2002 03:36 PM
