Old 08-04-2020, 11:43 AM   #1
LAFAYETTE , Colorado
Entry door bolts
How large a hole do I need to drill in the aluminum wall on the inside of trailer to access the nuts that hold the door hinges. Mine need tightened.
TY PECK is offline   Reply With Quote
Old 08-04-2020, 12:02 PM   #2
Al and Missy's Avatar
2002 30' Classic S/O
Fleming Island , Florida
On my trailer they are behind the door trim molding. The size of the hole depends on how accurately you can place it as well as the size of the nut. I think I'd just locate the 4 holes as accurately as possible and then drill them so the edge would be just under the molding, i.e. as big as possible without showing.
Dealer fixed mine for $150 while I was in having a panel replaced.
Be careful - the nuts are not secured in any way. If you drop one, it will be in the wall forever. A nut plate would have cost what, $0.75?
Replacement Keys for Entry Door/Water Input door? Marlin4622 General Repair Forum 4 09-22-2018 07:11 AM
1964 door in a Door entry door hinges recycled Windows, Doors, Locks & Vents 1 09-18-2013 06:07 PM
Airstream outside entry door with screen door & trim netlace Doors & Locks 1 10-02-2009 05:53 PM
Door hinge bolts/access hole ViewRVs Airstream Motorhome Forums 9 04-29-2003 08:44 AM
Loose exterior door hinge bolts JoeGillis Doors & Locks 2 10-21-2002 11:11 AM
