Hey all. My wife and I are in the process of renovating our '88 34' Limited. I have four exterior compartment doors that need gaskets. I have found gaskets that will work for the interior portion. I'm wondering if the compartment door itself is supposed to have a gasket in between the two halves.
Had the same question when I replaced my serenity tool storage door. No gasket for that space. The gasket goes around the flange in the compartment and the door presses up against it.
2015 23' FB International
2007 19' International CCD
Steamboat Springs
I use Indoor Weather Stripping,Self Adhesive Foam Window Seal Strip for Doors and Windows Weatherstrip Gap Blocker. Using the double seal is wide enough to cover the entire edge of the door and results in a tight seal. Has lasted years.
